ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Cisco ASA 5545 S2S VPN Traffic Bandwidth?
Hi All,
Does anybody no how I can actually monitor the amount of bandwidth my current traffic is using going across my S2S VPN tunnel?  Also, does anybody know the max bandwidth for the tunnels?
Thanks in advance.
Everyone's tags (3)
4 REPLIES 4
Highlighted
VIP Advocate
Re: Cisco ASA 5545 S2S VPN Traffic Bandwidth?
 - If the ASA supports the standard IF-MIB(s) for the VPN/(virtual interaces)  , it should be possible.
M.
Highlighted
Beginner
Hey Marce,
Ok, any idea how to check that?  And do you know the max bandwidth of the Ipsec VPN tunnels?
Tks.
Highlighted
VIP Advocate
 - By walking the ifindex from the relevant RFC mib. More general it is better to look into free bandwidth monitoring tools. Once configured they will detect those (vpn) interfaces too, if they are supported through SNMP. If the tool can handle them it will also show what the max-bandwidth is. Below is a link to common used bandwidth monitoring applications :
             https://www.pcwdld.com/bandwidth-monitors-best-free-network-tools
M.
Highlighted
Beginner
Hi All,
For the S2S VPN tunnel bandwidth throughput does anybody know if that total is bi-directional?  For example the cisco 5545 has a max bandwidth of 400M, does that mean its 200M up and 200M down? or 400M up and 400M Down?
3DES/AES VPN Throughput[6]
400 Mbps
Thanks in advance.
Content for Community-Ad
