02-24-2015 10:27 PM
I am experiencing an issue with Cisco ASA CX module, which is throwing the below error very frequently.
Solved! Go to Solution.
02-25-2015 07:46 AM
Looks like your are hitting the BUG ID : CSCun48868
https://tools.cisco.com/bugsearch/bug/CSCun48868/?referring_site=bugquickviewredir
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
02-25-2015 07:46 AM
- Ashok
02-25-2015 08:38 AM
I agree with Ashok.
I was seeing similar issues with a customer running ASA 9.2(2.4). Upgrading the ASA to 9.2(3) seems to have remedied the issue.
I'd also bring your CX release up to the latest patch level. Currently that would be 9.3(3.1) Build 13.
