07-01-2022 07:46 AM
Does anyone have the startup config that is running when first purchased? I reset the switch using the mode button and it lost the DHCP server and webui etc...
The switch is running and can console in but there is nothing setup.
Solved! Go to Solution.
07-01-2022 07:52 AM
every setup is different, so you need do from scratch :
check below videos :
https://www.youtube.com/watch?v=pvF_MDjbF6M
Once you have GUI you can explore config of DHCP and other stuff :
https://www.youtube.com/watch?v=AVjHVR0PFKs
07-01-2022 07:52 AM
07-01-2022 02:27 PM
Thanks Balaji,
Rebuilt the config in the end.
07-01-2022 09:03 AM
- In essence there is no startup-config on a new device and or configure the device from scratch.
M.
