Cisco CPNR SNMP
Islam_Hassanin
Hello Dears,
Kindly i’m trying to use SNMP to monitor Free Leases on CPNR for specific scope. i have configure scopes, traps and bind these traps to scopes.
the issue that OID for free leases not exist, i used below MIB and OID: https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.9.120.1.2.7&translate=Translate&submitValue=SUBMIT&submitClicked=true
but i’m getting:
CISCO-NETWORK-REGISTRAR-MIB::cnrNotifDHCPScopeFreeAddrLow = No Such Object available on this agent at this OID.
CPNR IP: 10.100.10.60 & Community: cpnr
Any Ideas ?
Islam_Hassanin
As per Cisco TAC, these OIDs can't be used to be pulled. they are just for Trapping alarms on the UI & CLI.
these errors usually have to do with the version of (CPNR in your case) installed. Which one are you running ?
marce1000
 - This one has it :  https://github.com/simonjj/SnmpMibs/blob/master/CISCO-NETWORK-REGISTRAR-MIB.mib , following the comment line above as @Georg Pauwen mentioned probably versioning related ,
 M.
@marce1000 @Georg Pauwen
i'm using CPNR v10.1, and i use this MIB file already as shown below:
Islam_Hassanin
