Cisco CSM installation on a virtual machine
vijay_sequeira
I just need to know whether Cisco Security Manager can be installed on a virtual machine?, Is it supported by Cisco ?and will it function properly?
Any documentation links to support the above would be most helpfull .
Vijay Sequeira
David Stanford
Install on a virtual server is not supported.
It has to be installed a server with a standard OS:
http://www.cisco.com/en/US/products/ps6498/products_installation_guide_chapter09186a00805e28a1.html#wp1030818
