Cisco Device Manager
rsaeks
I am trying to get this up and running, and when I attempt to get to any device, I am able to login through the web interface with my level 15 accounts, but all that I get displayed is the source to the runAPP.shtml file, and all the code.
Are there any workarounds to get this going? I am running this on a Windows XP SP2 machines with IE 6. I have tried it with 7 on a different XP SP 2 machine and get the same results.
Randy Saeks
David Stanford
Can you try this:
In IE go to TOOLS -INTERNET OPTIONS -ADVANCED tab and then scroll down to SECURITY.
Check the box that says ALLOW ACTIVE CONTENT TO RUN IN FILES ON MY COMPUTER.
APPLY and OK.
Also, in this same ADVANCED tab go to Java (Sun) and deselect if there's a checkbox there saying to use a certain plugin version
Then try it again and see if you have the same problem.
