Cisco ENCS 5412 WAAS
saeedek
Dears,
I have Cisco ENCS 5412 with Waas installed on it (Cisco ENCS 5412 WAAS )
how to login it and start configuration .
It's new device
8 Replies 8
marce1000
 https://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/vwaas/vwaas-641/encsw-quick/encsw-quickstart.pdf
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
thanks marce1000
but i need video or any material explained step by step.
Now i have Vwaas already installed on ENCS.
how i can login to ENCS ?
how i can login to Vwaas?
how can i start console configuration for Vwaas?
I had to figure this out on my own as well documentation is not so great.
1. Configure the CIMC
- Connect serial cable to cimc and do the following:
Connect to CIMC Serial Port
login: admin / password
Set CIMC IP:
scope cimc
scope network
set v4-address 172.31.x.x
set v4-netmask 255.255.255.0
set v4-gateway 172.31.x.1
commit
Set CIMC Password (admin)
scope user 1
set password
 **enter password twice**
commit
Enable Serial over LAN (Console access for Vwaas)
scope sol
set enabled yes
commit
dear pabubendorf
thanks for your reply.I have one question.
after i configure CIMC IP through CIMC console .i will use this IP for SSH when i connect to MGMT-CIMC
that is right ?
Correct.
To setup the Vwaas:
- Connect to Vwaas via CIMC Management Port
- ssh to ip assigned to cimc management port
-connect host (this will give you console access to Vwaas)
or
connect serial cable to console port on ENCS 54XX this will also give you console access to Vwaas
login: admin/default
To setup Vwaas - I like to use setup command easiest way to just get everything setup if you don't aready have a config built up.
**Few things to note**
- Vwaas Network Management Ports are the Built In Gige 0 or Gige 1, but they are called out in Vwaas as Virtual 1/0 or Virtual 1/1 I think.
- Vwaas intercept mode, options are wccp or appnav, unless you purchased an inline card than its Virtual Inline 3/0 or Virtual Inline 3/1.
After you have completed setup accept the settings and your done.  You should be able to SSH to the assigned Vwaas IP Address.
If your adding it to a WAAS Central Manager you will need to do CMS enable if its not in your CM Manager yet.
dear pabubendorf
many thanks for your support . i have one question can i access Vwaas through HTTP/HTTPS if yes how??
VloT
After initialization step, i have a 10.20.0.0/24 route in the wass routing table. I don't want this route to be involved in routing decision for traffic that need to be accellerated.
wae02#show ip route
Data Routes
Destination      Netmask          Gateway         Interface
0.0.0.0          0.0.0.0          10.10.90.97     Standby 1
10.20.0.0        255.255.255.0    --               Virtual 0/0
10.10.90.96     255.255.255.240  --               Standby 1
Management Routes
How can i remove/disable this automatic configuration?
