Cisco ISR 4xxx licensing store index - Througput licensing
Ahmed Dockrat
So I have a cisco ISR 4331 and have been told the router was supplied with a throughput license to scale the performance to 300mbps
Why does the router have 2 throughput licenses in different stores ?
Is this router correctly licensed for throughput as permanent or evaluation
ucs-dischem-bry-midrand-neo-mi#sh license detail throughput
Index: 1 Feature: throughput Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Index: 2 Feature: throughput Version: 1.0
License Type: EvalRightToUse
License State: Inactive
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Priority: None
Store Index: 6
Store Name: Built-In License Storage
Jerome BERTHIER
Just do "sh license".
If you find the feature "throughput" as "Life time / permanent / active", it is correct :
Index 9 Feature: throughput
    Period left: Life time
If not already set, you have to push definitively the performance to 300M using this command :
platform hardware throughput level 300000
Then reboot and it's done !
platform hardware throughput level 300000 & the reboot has been done.
But the license is showing 2 throughput licenses, one showing permanent & other showing evaluation so confused
