09-04-2012 11:56 PM
Hi ,
Im facing one issue with Cisco LMS 3.2
Issue : The logs is generating only for 10 days and post that im not able to see the logs. I have not done any config changes. The only change i have done is i have completely reinstalled the LMS. i did multiple troubleshoot but not able to resolve this isse. It would be great If any some one is able to help me in this isse. Thanks.
Juliet
09-09-2012 05:38 AM
Is there any purge policy you have set for your Syslog to purge syslog older than 10 days?
Please check them in Admin settings and if so, change it.
09-12-2012 11:22 PM
Dear Vinod
Thanks for ur response and the problem has been resolved.
The purge policy was set to 60 days only .The problem in reports viewing setting.
Syslog folder under LMS would store syslog reports of both the device as well as applications for defined folder size , which in your case was 1 MB ( same can be viewed under log generator option). The older reports would get deleted from the folder upon reaching the limit.
The only way to view device syslog is under following option : Reports -> Reports Generator in LMS GUI where we will have to choose syslog with desired attribute.
Juliet
09-13-2012 12:02 AM
This is great news!! You can close this thread if the issue is resolved.
-Thanks
