Cisco LMS 4.0.1 to Prime Infrastructure 2.x Upgrade
Heiko Kelling
Beginner
Beginner
we are using Cisco LMS and want to upgrade to Cisco Prime Infrastructure.
Now we have received the following license update: L-L-PI2X-100-U     -      LMS to Prime Infrastructure 2.x Upgrade 100 Device
and I wonder what is the best way to upgrade.
After a long search I found the following document on cisco:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/guide-c07-729990.html#wp9000727
There is only the talk of the upgrade from 4.2 LMS to Prime.
The problem is that we can not update to version 4.2 because of an error. Thats one reason why we need to upgrade to prime.
Is the only possibility now to export databases?
thanks in advance
AFROJ AHMAD
Hi Heiko,
Upgarding from LMS 4.0.1 to LMS 4.2  , you need a New Licesne . Are you getting that error..
Upgarding from LMS to PI is alomost like a new Installation of PI. because only thing you can IMPORT from LMS to PI is the device list .
you can download the software from the below link:
http://software.cisco.com/download/release.html?mdfid=284422771&flowid=45323&softwareid=284272932&release=2.0.0&relind=AVAILABLE&rellifecycle=&reltype=all
Installation  link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/install/guide/Cisco_PI_Hardware_Appliance_Installation_Guide/cpi_higmain.html
hope it will help
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
