Cisco LMS 4.2.3 - Nexus VDC - SNMP
brettmilborrow
Hi All,
I am having some trouble with getting inventory collection work for the VDC's of a Nexus 7k from LMS 4.2.3.
The collection works for the main VDC, just not any of the others.
I have verified (using SNMPWALK) from the LMS server that the snmp credentials in use on the LMS for these VDC's is correct.
We are using SNMP V3.
The error I am getting when trying to run an inventory collection is:
Device Collection Failed. Failed to fetch Containment details.
Does anyone have any experience with getting VDC's to work in LMS and may have seen this error before?
Thanks in advance.
AFROJ AHMAD
Hi ,
You are hitting the below BUG:
LMS 4.2.3 Inventory collection is failing for some of Nexus 7k devices
CSCuh49814
Development team is still working on the fix.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
