Highlighted
Beginner
Cisco LMS4.1 Not seen syslogs
Hello We have a network deployed Cisco LMS 4.1. The devices configured so that they send messages  syslog to LMS server. But the LMS does not display the logs. At the same time if you go to the file system at C: \ Program Files (x86) \ CSCOpx \ logs and open a file that syslogs, syslog switches are available with it. Who can tell what's the problem? I would be very grateful for the help.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Collaborator
Re: Cisco LMS4.1 Not seen syslogs
how to upload files to the forum:
the messages you posted are in the correct (EMBLEM) format and timestamping is ok, so they should be processed by LMS;
can you post a screenshot of your settings from
    Monitor > Fault Settings > Syslog > Message Filters
9 REPLIES 9
Highlighted
Collaborator
check if your LSM server is subscribed as a syslog collector:
    Admin > Collection Settings > Syslog > Syslog Collector Status
if not, subscribe it
force a syslog message by just telnet to a device, go into configure mode and exit and see if it arrives in the GUI now:
    Monitor > Fault Monitoring > Event Monitor
        change the tab in the right window to "Syslog"
if no message arrives, check the status of the following processes (they should be started) and restart them on CLI (DOS-Box with admin privileges):
    pdshow SyslogAnalyzer SyslogCollector
    pdterm SyslogAnalyzer SyslogCollector
    pdexec SyslogAnalyzer SyslogCollector
again, force a syslog message and check the Event Monitor
if still nothing happens enable debugging for the SyslogAnalyzer process:
Admin > System > Debug Settings > Config and Image Management Debugging Settings
    Set Application Logging Levels >> SyslogAnalyzer (scroll down)
        set Syslog Analyzer and Syslog Analyzer User Interface from INFO to DEBUG
again, force a syslog message...
check the following log files and post them on the forum:
    NMSROOT\log\SyslogCollector.log
    NMSROOT\log\AnalyzerDebug.log
Beginner
Thanks for answer. I will try in monday this.
Highlighted
Beginner
I've done this actions. But syslog not worked propetly.  Syslog coolector is subscribe in LMS.
SyslogCollector
propFileC:/PROGRA~2/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\C:\PROGRA~2\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
Unable to find the file C:/PROGRA~2/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\C:\PROGRA~2\CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
NMSROOT is C:/PROGRA~2/CSCOpx
propFileC:/PROGRA~2/CSCOpx\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
SyslogCollector - [Thread: main] INFO , 07 Aug 2012 18:52:32,703, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 07 Aug 2012 18:52:32,718, System Initialized.
SyslogCollector - [Thread: main] INFO , 07 Aug 2012 18:52:32,718, Queue Cap 100000
SyslogCollector - [Thread: main] WARN , 07 Aug 2012 18:52:39,281, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 07 Aug 2012 18:52:39,296, Service started...
SyslogCollector - [Thread: Thread-13] WARN , 20 Aug 2012 09:32:10,032, Unable to add monitor for Cisco-LMS-C
SyslogCollector - [Thread: main] INFO , 20 Aug 2012 10:57:29,119, Logging System Initialized.
SyslogCollector - [Thread: main] INFO , 20 Aug 2012 10:57:29,120, System Initialized.
SyslogCollector - [Thread: main] INFO , 20 Aug 2012 10:57:29,126, Queue Cap 100000
SyslogCollector - [Thread: main] WARN , 20 Aug 2012 10:57:35,870, Unable to resurrect connection to a subscriber.
SyslogCollector - [Thread: main] INFO , 20 Aug 2012 10:57:35,892, Service started...
AnalyzerDebug
[ Wed Aug 01  15:22:50 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for SyslogAnalyzer
[ Wed Aug 01  15:22:50 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as SyslogAnalyzer-RMELogLevelChange
[ Wed Aug 01  15:22:50 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Wed Aug 01  15:22:50 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],newsyslogqueue queue created with max size 100000
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],processorsyslogqueue queue created with max size 100000
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],Queue for new incoming syslogs created with size 100000
[ Wed Aug 01  15:22:51 MSD 2012 ],INFO ,[main],Queue for action processor created with size 100000
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1ded4c9 com.sybase.jdbc2.jdbc.SybStatement@63e563
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Action processors created
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@eac7c8 com.sybase.jdbc2.jdbc.SybStatement@1e22632
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@8491b8 com.sybase.jdbc2.jdbc.SybStatement@17af46e
[ Wed Aug 01  15:22:52 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@145c761 com.sybase.jdbc2.jdbc.SybStatement@24c672
[ Wed Aug 01  15:22:53 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Wed Aug 01  15:22:53 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Wed Aug 01  15:22:53 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1a1bc40 com.sybase.jdbc2.jdbc.SybStatement@14e40da
[ Wed Aug 01  15:22:53 MSD 2012 ],INFO ,[main],Action processors created
[ Wed Aug 01  15:22:58 MSD 2012 ],INFO ,[main],Service started...
[ Wed Aug 01  15:26:48 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,113,Inside ICSDatabaseConnection, MAX_COUNT =20
[ Wed Aug 01  15:26:48 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,54,Calling set MAX_COUNT
[ Wed Aug 01  15:26:48 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,56,Calling set MAX_COUNT done
[ Wed Aug 01  15:35:09 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for SyslogAnalyzer
[ Wed Aug 01  15:35:09 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as SyslogAnalyzer-RMELogLevelChange
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],newsyslogqueue queue created with max size 100000
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],processorsyslogqueue queue created with max size 100000
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Queue for new incoming syslogs created with size 100000
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Queue for action processor created with size 100000
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@c19fbf com.sybase.jdbc2.jdbc.SybStatement@1ded4c9
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Action processors created
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@2d502d com.sybase.jdbc2.jdbc.SybStatement@eac7c8
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@13af084 com.sybase.jdbc2.jdbc.SybStatement@8491b8
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@fe2558 com.sybase.jdbc2.jdbc.SybStatement@145c761
[ Wed Aug 01  15:35:10 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@6078e7 com.sybase.jdbc2.jdbc.SybStatement@1a1bc40
[ Wed Aug 01  15:35:16 MSD 2012 ],INFO ,[main],Service started...
[ Wed Aug 01  15:36:36 MSD 2012 ],INFO ,[ActionThread4],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,113,Inside ICSDatabaseConnection, MAX_COUNT =20
[ Wed Aug 01  15:36:36 MSD 2012 ],INFO ,[ActionThread4],com.cisco.nm.rmeng.util.db.DatabaseConnection,,54,Calling set MAX_COUNT
[ Wed Aug 01  15:36:36 MSD 2012 ],INFO ,[ActionThread4],com.cisco.nm.rmeng.util.db.DatabaseConnection,,56,Calling set MAX_COUNT done
[ Wed Aug 01  15:36:36 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,54,Calling set MAX_COUNT
[ Wed Aug 01  15:36:36 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,56,Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@904f75 com.sybase.jdbc2.jdbc.SybStatement@5098f9
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@16b277f com.sybase.jdbc2.jdbc.SybStatement@1ee2ea8
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@394ffa com.sybase.jdbc2.jdbc.SybStatement@b1bed2
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@76f1f4 com.sybase.jdbc2.jdbc.SybStatement@10704e1
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Thu Aug 02  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1d18084 com.sybase.jdbc2.jdbc.SybStatement@14c7deb
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@6a54f9 com.sybase.jdbc2.jdbc.SybStatement@f0bf3d
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@19b622d com.sybase.jdbc2.jdbc.SybStatement@4aad7f
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@c47220 com.sybase.jdbc2.jdbc.SybStatement@120a9d6
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@16e2b70 com.sybase.jdbc2.jdbc.SybStatement@1e5d007
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Fri Aug 03  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@bc8f01 com.sybase.jdbc2.jdbc.SybStatement@1509443
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.inventory.ics.server.ICSClient,startInvCollection,74, Request ID returned from the server is : 1343820911826
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,74,Invoking Config collection for syslog message
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,81,Before triggering syslog config fetch
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,83,Syslog Timestamp Fri Aug 03 13:47:35 MSD 2012
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,85,DCMA Endtime String 2012-07-20 12:14:01.793
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,90,DCMA Endtime String after formatting Fri Jul 20 12:14:01 MSD 2012
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,98,Buffer Time after adding 5 minutes Fri Jul 20 12:19:01 MSD 2012
[ Fri Aug 03  13:48:41 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,101,Triggering fetch on syslog since Timestamp > bufferTime
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@b2d28b com.sybase.jdbc2.jdbc.SybStatement@1cac3d
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@6fffd4 com.sybase.jdbc2.jdbc.SybStatement@104eff0
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@124b4a9 com.sybase.jdbc2.jdbc.SybStatement@d0c3d5
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1e8dd92 com.sybase.jdbc2.jdbc.SybStatement@12adac5
[ Sat Aug 04  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@80cf99 com.sybase.jdbc2.jdbc.SybStatement@bd7e7c
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@178f2b com.sybase.jdbc2.jdbc.SybStatement@b8584d
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@ad662c com.sybase.jdbc2.jdbc.SybStatement@f023c
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@15bf0c5 com.sybase.jdbc2.jdbc.SybStatement@11c34fb
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@da7b85 com.sybase.jdbc2.jdbc.SybStatement@1e373de
[ Sun Aug 05  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1cc2f42 com.sybase.jdbc2.jdbc.SybStatement@32c41c
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@16bb7b1 com.sybase.jdbc2.jdbc.SybStatement@e904c4
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@380f83 com.sybase.jdbc2.jdbc.SybStatement@828579
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@108d052 com.sybase.jdbc2.jdbc.SybStatement@1a4f8a6
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1c06877 com.sybase.jdbc2.jdbc.SybStatement@10a93e5
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Mon Aug 06  00:00:03 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@173b262 com.sybase.jdbc2.jdbc.SybStatement@c46dcf
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1aa8eb7 com.sybase.jdbc2.jdbc.SybStatement@7fc8a0
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@14cadc4 com.sybase.jdbc2.jdbc.SybStatement@1243618
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@5b644b com.sybase.jdbc2.jdbc.SybStatement@157e43
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@11483a0 com.sybase.jdbc2.jdbc.SybStatement@1cdae24
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Tue Aug 07  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@63dc28 com.sybase.jdbc2.jdbc.SybStatement@ae511
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for SyslogAnalyzer
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as SyslogAnalyzer-RMELogLevelChange
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],newsyslogqueue queue created with max size 100000
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],processorsyslogqueue queue created with max size 100000
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],Queue for new incoming syslogs created with size 100000
[ Tue Aug 07  18:54:30 MSD 2012 ],INFO ,[main],Queue for action processor created with size 100000
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@c19fbf com.sybase.jdbc2.jdbc.SybStatement@1ded4c9
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Action processors created
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@eac7c8 com.sybase.jdbc2.jdbc.SybStatement@1e22632
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@13af084 com.sybase.jdbc2.jdbc.SybStatement@8491b8
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@fe2558 com.sybase.jdbc2.jdbc.SybStatement@145c761
[ Tue Aug 07  18:54:31 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@6078e7 com.sybase.jdbc2.jdbc.SybStatement@1a1bc40
[ Tue Aug 07  18:54:36 MSD 2012 ],INFO ,[main],Service started...
[ Tue Aug 07  18:54:45 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,113,Inside ICSDatabaseConnection, MAX_COUNT =20
[ Tue Aug 07  18:54:45 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,54,Calling set MAX_COUNT
[ Tue Aug 07  18:54:45 MSD 2012 ],INFO ,[ActionThread0],com.cisco.nm.rmeng.util.db.DatabaseConnection,,56,Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@bd3b2d com.sybase.jdbc2.jdbc.SybStatement@17834de
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@d713fe com.sybase.jdbc2.jdbc.SybStatement@61a7e6
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1561437 com.sybase.jdbc2.jdbc.SybStatement@4936f3
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@b6b2a5 com.sybase.jdbc2.jdbc.SybStatement@8a9d2a
[ Wed Aug 08  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@5438e1 com.sybase.jdbc2.jdbc.SybStatement@1627b8b
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1a84b38 com.sybase.jdbc2.jdbc.SybStatement@1e26d42
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@731e90 com.sybase.jdbc2.jdbc.SybStatement@1db8f8e
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1adbfde com.sybase.jdbc2.jdbc.SybStatement@fb0b0
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@18ff27 com.sybase.jdbc2.jdbc.SybStatement@1177115
[ Thu Aug 09  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@150a0 com.sybase.jdbc2.jdbc.SybStatement@546169
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.inventory.ics.server.ICSClient,startInvCollection,74, Request ID returned from the server is : 1344351271121
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,74,Invoking Config collection for syslog message
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,81,Before triggering syslog config fetch
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,83,Syslog Timestamp Thu Aug 09 13:40:03 MSD 2012
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,85,DCMA Endtime String 2012-07-11 17:10:51.966
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,90,DCMA Endtime String after formatting Wed Jul 11 17:10:51 MSD 2012
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,98,Buffer Time after adding 5 minutes Wed Jul 11 17:15:51 MSD 2012
[ Thu Aug 09  13:40:26 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,101,Triggering fetch on syslog since Timestamp > bufferTime
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@12a2259 com.sybase.jdbc2.jdbc.SybStatement@1353d27
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@41dc79 com.sybase.jdbc2.jdbc.SybStatement@1f1a3a8
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@12f9ee1 com.sybase.jdbc2.jdbc.SybStatement@167f48c
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1e81d48 com.sybase.jdbc2.jdbc.SybStatement@1da691a
[ Fri Aug 10  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@2a2ae9 com.sybase.jdbc2.jdbc.SybStatement@673c9f
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@132c515 com.sybase.jdbc2.jdbc.SybStatement@291fc2
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1e41869 com.sybase.jdbc2.jdbc.SybStatement@1feae0f
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1556f4c com.sybase.jdbc2.jdbc.SybStatement@1fe0816
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@c50561 com.sybase.jdbc2.jdbc.SybStatement@e43b44
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Sat Aug 11  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1eef1eb com.sybase.jdbc2.jdbc.SybStatement@4c9c17
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@a3c5b6 com.sybase.jdbc2.jdbc.SybStatement@94cc7
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@8fa0f0 com.sybase.jdbc2.jdbc.SybStatement@18efa2f
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1cb4a6a com.sybase.jdbc2.jdbc.SybStatement@182815a
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@fa4dec com.sybase.jdbc2.jdbc.SybStatement@111e86f
[ Sun Aug 12  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@b2f2d6 com.sybase.jdbc2.jdbc.SybStatement@64cd4b
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@21a86a com.sybase.jdbc2.jdbc.SybStatement@1b7f97b
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@15c024c com.sybase.jdbc2.jdbc.SybStatement@15ea69f
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@10d4ade com.sybase.jdbc2.jdbc.SybStatement@1ae74f5
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@15c024c com.sybase.jdbc2.jdbc.SybStatement@19b08cc
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-4],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Mon Aug 13  00:00:06 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@80bc28 com.sybase.jdbc2.jdbc.SybStatement@1c10834
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1187984 com.sybase.jdbc2.jdbc.SybStatement@1d2052b
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@151574b com.sybase.jdbc2.jdbc.SybStatement@13a1324
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1bed674 com.sybase.jdbc2.jdbc.SybStatement@1f18cd5
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@154f6ff com.sybase.jdbc2.jdbc.SybStatement@123fab3
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Tue Aug 14  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@18df2e4 com.sybase.jdbc2.jdbc.SybStatement@4568f8
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.inventory.ics.server.ICSClient,startInvCollection,74, Request ID returned from the server is : 1344351271139
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,74,Invoking Config collection for syslog message
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,81,Before triggering syslog config fetch
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,83,Syslog Timestamp Tue Aug 14 13:11:38 MSD 2012
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,85,DCMA Endtime String 2012-07-20 12:15:02.426
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,90,DCMA Endtime String after formatting Fri Jul 20 12:15:02 MSD 2012
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,98,Buffer Time after adding 5 minutes Fri Jul 20 12:20:02 MSD 2012
[ Tue Aug 14  13:12:29 MSD 2012 ],INFO ,[Thread-2],com.cisco.nm.rmeng.dcma.client.RmeSaDcmaActionHandler,act,101,Triggering fetch on syslog since Timestamp > bufferTime
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1349665 com.sybase.jdbc2.jdbc.SybStatement@17df9ec
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1a32902 com.sybase.jdbc2.jdbc.SybStatement@d95bc3
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1787a6 com.sybase.jdbc2.jdbc.SybStatement@cab3bf
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1def658 com.sybase.jdbc2.jdbc.SybStatement@ff366c
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Wed Aug 15  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@14e1705 com.sybase.jdbc2.jdbc.SybStatement@1c98360
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@2b7711 com.sybase.jdbc2.jdbc.SybStatement@196076f
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@c221d7 com.sybase.jdbc2.jdbc.SybStatement@13be416
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@fb8e1e com.sybase.jdbc2.jdbc.SybStatement@12f8a71
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@2a15d6 com.sybase.jdbc2.jdbc.SybStatement@ffce21
[ Thu Aug 16  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@360733 com.sybase.jdbc2.jdbc.SybStatement@112ce69
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1acc1c2 com.sybase.jdbc2.jdbc.SybStatement@e4d37f
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@f95821 com.sybase.jdbc2.jdbc.SybStatement@91772
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@e2580e com.sybase.jdbc2.jdbc.SybStatement@32069
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-4],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Fri Aug 17  00:00:08 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@144f47b com.sybase.jdbc2.jdbc.SybStatement@ee920
[ Fri Aug 17  00:00:09 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@eb706d com.sybase.jdbc2.jdbc.SybStatement@1222b8e
[ Fri Aug 17  14:01:25 MSD 2012 ],ERROR,[Thread-27], Unable to initialize logging infrastructure for localization
[ Fri Aug 17  14:01:25 MSD 2012 ],ERROR,[Thread-27],No resource is associated with key "Unable to initialize logging infrastructure for localization".
[ Fri Aug 17  14:01:25 MSD 2012 ],ERROR,[Thread-27],Unable to initialize logging infrastructure for localization
[ Fri Aug 17  14:01:25 MSD 2012 ],INFO ,[Thread-27],Calling set MAX_COUNT
[ Fri Aug 17  14:01:25 MSD 2012 ],INFO ,[Thread-27],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@9f5b19 com.sybase.jdbc2.jdbc.SybStatement@15df3f
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1f3b8bc com.sybase.jdbc2.jdbc.SybStatement@1e54e00
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1641957 com.sybase.jdbc2.jdbc.SybStatement@bbaccd
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@14dec09 com.sybase.jdbc2.jdbc.SybStatement@c34fd9
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sat Aug 18  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@af55e7 com.sybase.jdbc2.jdbc.SybStatement@130e03a
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@13849df com.sybase.jdbc2.jdbc.SybStatement@79f0ec
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1b8424e com.sybase.jdbc2.jdbc.SybStatement@93ffa
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@14753da com.sybase.jdbc2.jdbc.SybStatement@1d22889
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@636a7e com.sybase.jdbc2.jdbc.SybStatement@e47e99
[ Sun Aug 19  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@133a7af com.sybase.jdbc2.jdbc.SybStatement@4600f0
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@57240e com.sybase.jdbc2.jdbc.SybStatement@1003d5d
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@bcd14a com.sybase.jdbc2.jdbc.SybStatement@507aaf
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1a685ae com.sybase.jdbc2.jdbc.SybStatement@19297ab
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1238fa5 com.sybase.jdbc2.jdbc.SybStatement@1abd8cb
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Mon Aug 20  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1262671 com.sybase.jdbc2.jdbc.SybStatement@1a5fdb9
[ Mon Aug 20  10:57:29 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for SyslogAnalyzer
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as SyslogAnalyzer-RMELogLevelChange
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],newsyslogqueue queue created with max size 100000
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],processorsyslogqueue queue created with max size 100000
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],Queue for new incoming syslogs created with size 100000
[ Mon Aug 20  10:57:31 MSD 2012 ],INFO ,[main],Queue for action processor created with size 100000
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Calling set MAX_COUNT done
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@690247 com.sybase.jdbc2.jdbc.SybStatement@14a97b
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Action processors created
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@39be68 com.sybase.jdbc2.jdbc.SybStatement@103d246
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@17af46e com.sybase.jdbc2.jdbc.SybStatement@14596d5
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@24c672 com.sybase.jdbc2.jdbc.SybStatement@6078e7
[ Mon Aug 20  10:57:32 MSD 2012 ],INFO ,[main],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@14e40da com.sybase.jdbc2.jdbc.SybStatement@83b00f
[ Mon Aug 20  10:57:38 MSD 2012 ],INFO ,[main],Service started...
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],Created default DB HANDLER
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],in connect to DB ------ RmeSaHandler
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],dsn = rmeng
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],Created default DB HANDLER
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],in connect to DB ------ RmeSaHandler
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],dsn = rmeng
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],Created default DB HANDLER
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],Created default DB HANDLER
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],in connect to DB ------ RmeSaHandler
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],in connect to DB ------ RmeSaHandler
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],dsn = rmeng
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],dsn = rmeng
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],Created default DB HANDLER
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],in connect to DB ------ RmeSaHandler
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],dsn = rmeng
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling set MAX_COUNT done
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],Connection success
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-0],Calling set MAX_COUNT done
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],Connection success
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-1],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@1a5fb5a com.sybase.jdbc2.jdbc.SybStatement@1906df
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],Connection is now false
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],Recreated the statement object
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-1],Calling Stored Procedure !!!!!!!!!!!!!!!!!!!!!! ..............
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-0],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@39bf12 com.sybase.jdbc2.jdbc.SybStatement@12f4538
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],Connection is now false
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],Recreated the statement object
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-2],Calling set MAX_COUNT done
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],Connection success
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-4],Calling set MAX_COUNT done
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],Connection success
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-2],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@16321e6 com.sybase.jdbc2.jdbc.SybStatement@14683c0
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],SYSLOG_20120721 could not be createdSQL Anywhere Error -110: Item 'SYSLOG_20120721' already exists Error code 12006 SQL state 52010
com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -110: Item 'SYSLOG_20120721' already exists
at com.sybase.jdbc2.tds.Tds.processEed(Tds.java:2884)
at com.sybase.jdbc2.tds.Tds.nextResult(Tds.java:2206)
at com.sybase.jdbc2.jdbc.ResultGetter.nextResult(ResultGetter.java:69)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:220)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:203)
at com.sybase.jdbc2.jdbc.SybStatement.executeLoop(SybStatement.java:1766)
at com.sybase.jdbc2.jdbc.SybStatement.execute(SybStatement.java:1758)
at com.sybase.jdbc2.jdbc.SybStatement.execute(SybStatement.java:815)
at com.cisco.nm.rmeng.sa.db.RmeSaDbHandler.createTable(RmeSaDbHandler.java:385)
at com.cisco.nm.rmeng.sa.db.RmeSaTableGenerator.run(RmeSaTableGenerator.java:153)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-0],SYSLOG_20120721 already exists1
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],Connection is now false
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-1],Issue while calling db view procedure
com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -141: Table 'SYSLOG_TODAY' not found
at com.cisco.nm.rmeng.sa.db.RmeSaDbHandler.createTable(RmeSaDbHandler.java:417)
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],Recreated the statement object
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-3],Calling set MAX_COUNT done
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-4],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@21a1e com.sybase.jdbc2.jdbc.SybStatement@e312
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],Connection success
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],Connection is now false
[ Tue Aug 21  00:00:00 MSD 2012 ],INFO ,[Timer-3],Connection and statement are com.sybase.jdbc2.jdbc.SybConnection@3bce70 com.sybase.jdbc2.jdbc.SybStatement@6e56ae
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],SYSLOG_20120721 could not be createdSQL Anywhere Error -110: Item 'SYSLOG_20120721' already exists Error code 12006 SQL state 52010
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-2],SYSLOG_20120721 already exists1
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],Recreated the statement object
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],Connection is now false
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],SYSLOG_20120721 could not be createdSQL Anywhere Error -110: Item 'SYSLOG_20120721' already exists Error code 12006 SQL state 52010
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-4],SYSLOG_20120721 already exists1
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],Recreated the statement object
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],SYSLOG_20120721 could not be createdSQL Anywhere Error -110: Item 'SYSLOG_20120721' already exists Error code 12006 SQL state 52010
[ Tue Aug 21  00:00:00 MSD 2012 ],DEBUG,[Timer-3],SYSLOG_20120721 already exists1
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 55
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 55
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 55 from the device profile cache
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Deleted the 55 from the cache
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:01:39 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 51
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 51
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 51 from the device profile cache
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Deleted the 51 from the cache
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 61
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 61
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 61 from the device profile cache
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Deleted the 61 from the cache
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 54
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 54
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 54 from the device profile cache
[ Tue Aug 21  12:01:52 MSD 2012 ],DEBUG,[Thread-13],Deleted the 54 from the cache
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 53
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 53
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 53 from the device profile cache
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Deleted the 53 from the cache
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:01:54 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 46
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 46
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 46 from the device profile cache
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Deleted the 46 from the cache
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:01:59 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 57
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 57
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 57 from the device profile cache
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Deleted the 57 from the cache
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:02:00 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 60
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 60
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 60 from the device profile cache
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Deleted the 60 from the cache
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:02:03 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 65
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 65
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 65 from the device profile cache
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Deleted the 65 from the cache
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 103
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 103
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 103 from the device profile cache
[ Tue Aug 21  12:02:06 MSD 2012 ],DEBUG,[Thread-13],Deleted the 103 from the cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 67
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 67
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 67 from the device profile cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Deleted the 67 from the cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 68
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 68
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 68 from the device profile cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Deleted the 68 from the cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 66
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 66
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 66 from the device profile cache
[ Tue Aug 21  12:02:07 MSD 2012 ],DEBUG,[Thread-15],Deleted the 66 from the cache
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 45
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 45
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 45 from the device profile cache
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Deleted the 45 from the cache
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:02:10 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 72
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 72
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 72 from the device profile cache
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Deleted the 72 from the cache
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:02:54 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 74
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 74
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 74 from the device profile cache
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Deleted the 74 from the cache
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:02:57 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 71
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 71
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 71 from the device profile cache
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Deleted the 71 from the cache
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 47
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 47
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 47 from the device profile cache
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Deleted the 47 from the cache
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:02:58 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 77
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 77
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 77 from the device profile cache
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Deleted the 77 from the cache
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:02 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 79
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 79
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 79 from the device profile cache
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Deleted the 79 from the cache
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:03 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 76
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 76
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 76 from the device profile cache
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Deleted the 76 from the cache
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 108
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 108
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 108 from the device profile cache
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Deleted the 108 from the cache
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:06 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 107
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 107
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 107 from the device profile cache
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Deleted the 107 from the cache
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 105
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 105
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 105 from the device profile cache
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Deleted the 105 from the cache
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 109
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 109
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 109 from the device profile cache
[ Tue Aug 21  12:03:08 MSD 2012 ],DEBUG,[Thread-13],Deleted the 109 from the cache
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 75
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 75
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 75 from the device profile cache
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Deleted the 75 from the cache
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:12 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 115
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 115
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 115 from the device profile cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Deleted the 115 from the cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 112
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 112
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 112 from the device profile cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-13],Deleted the 112 from the cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 114
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 114
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 114 from the device profile cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Deleted the 114 from the cache
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:15 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 113
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 113
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 113 from the device profile cache
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Deleted the 113 from the cache
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 116
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 116
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 116 from the device profile cache
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Deleted the 116 from the cache
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 110
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 110
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 110 from the device profile cache
[ Tue Aug 21  12:03:17 MSD 2012 ],DEBUG,[Thread-15],Deleted the 110 from the cache
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 111
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 111
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 111 from the device profile cache
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Deleted the 111 from the cache
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:18 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 117
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 117
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 117 from the device profile cache
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Deleted the 117 from the cache
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:20 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 125
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 125
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 125 from the device profile cache
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Deleted the 125 from the cache
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:25 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 123
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 123
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 123 from the device profile cache
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Deleted the 123 from the cache
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:26 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 118
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 118
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 118 from the device profile cache
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Deleted the 118 from the cache
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 122
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 122
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 122 from the device profile cache
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Deleted the 122 from the cache
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:27 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 140
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 140
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 140 from the device profile cache
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Deleted the 140 from the cache
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 124
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 124
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 124 from the device profile cache
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Deleted the 124 from the cache
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:28 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 145
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 145
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 145 from the device profile cache
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Deleted the 145 from the cache
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:03:30 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 150
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 150
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 150 from the device profile cache
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Deleted the 150 from the cache
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:03:31 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 139
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 139
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 139 from the device profile cache
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Deleted the 139 from the cache
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:04:11 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 146
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 146
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 146 from the device profile cache
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Deleted the 146 from the cache
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:04:34 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Preparing to update the profile for the device with the id 82
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Preparing to the update the device profile cache with 82
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Preparing to delete 82 from the device profile cache
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Deleted the 82 from the cache
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Devcei Profile cache updated
[ Tue Aug 21  12:55:16 MSD 2012 ],DEBUG,[Thread-13],Updating the device profile is done
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Preparing to update the profile for the device with the id 83
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Preparing to the update the device profile cache with 83
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Preparing to delete 83 from the device profile cache
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Deleted the 83 from the cache
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Devcei Profile cache updated
[ Tue Aug 21  12:58:22 MSD 2012 ],DEBUG,[Thread-15],Updating the device profile is done
Highlighted
Collaborator
Cisco LMS4.1 Not seen syslogs
do I understand correctly, that the syslog messages are making their way to the file
    NMSROOT\log\syslog.log
(with NMSROOT being the installation path of LMS)
what kind of device is sending the syslog?
can you post the raw syslog message
    - seen on the device
    - from the syslog.log file
for the AnalyzerDebug.log file it is either incomplete or something other is wrong;
again, please insure you have enabled debugging here:
Admin > System > Debug Settings > Config and Image Management Debugging Settings
    Set Application Logging Levels >> SyslogAnalyzer (scroll down)
        set Syslog Analyzer
        and Syslog Analyzer User Interface from INFO to DEBUG
wait a minute and force a syslog messages in the way I described before, then upload the AnalyzerDebug.log file (rather then copy & paste it to the thread)
Highlighted
Beginner
        set Syslog Analyzer
Sorry for long answer. Above syslog debug config, see in screenshot.
Device sending is syslog , Switches 4948, 3500, 3700, 6500, 4500 series, and Pix firewalls ASA firewals.
Sorry for my ignorance, but how i can upload logs, not paste here?
this system Pix log
Aug 22 2012 17:11:20: %PIX-1-105008: (Primary) Testing Interface int 2
Aug 22 2012 17:11:20: %PIX-1-105008: (Primary) Testing Interface int 1
Aug 22 2012 17:11:21: %PIX-1-105009: (Primary) Testing on interface int 2 Passed
Aug 22 2012 17:11:21: %PIX-1-105009: (Primary) Testing on interface int 1 Passed
This CWLMS log, who save in log file, but not seen int Webibterface.
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:20: %PIX-1-105005: (Primary) Lost Failover communications with mate on interface int1
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:20: %PIX-1-105005: (Primary) Lost Failover communications with mate on interface int2
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:20: %PIX-1-105008: (Primary) Testing Interface int 1
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:20: %PIX-1-105008: (Primary) Testing Interface int 2
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:21: %PIX-1-105009: (Primary) Testing on interface int 2 Passed
Aug 22 17:11:21 10.0.8.64 Aug 22 2012 17:11:21: %PIX-1-105009: (Primary) Testing on interface in1 Passed
Highlighted
Collaborator
Re: Cisco LMS4.1 Not seen syslogs
how to upload files to the forum:
the messages you posted are in the correct (EMBLEM) format and timestamping is ok, so they should be processed by LMS;
can you post a screenshot of your settings from
    Monitor > Fault Settings > Syslog > Message Filters
Highlighted
Beginner
Thank you very mutch. I disable filter and syslogs appeared on the devices.
Highlighted
Collaborator
great that it is working now - and don't forget to disable debugging... ;-)
Highlighted
Beginner
thanks, I already forgot about debaggin =)
Content for Community-Ad
