Cisco NAM-2 Module On 7613 Router Problem (Not Ping And No Access)
smartboys
I have NAM-2 module and after installing that module not work correctly
Nam IP Configuration :
root@nam.localdomain# sho ip
IP address:             192.168.253.2
Subnet mask:            255.255.255.0
IP Broadcast:           192.168.253.255
DNS Name:               nam.localdomain
Default Gateway:        192.168.253.1
Nameserver(s):
HTTP server:            Disabled
HTTP secure server:     Disabled
HTTP port:              80
HTTP secure port:       443
TACACS+ configured:     No
Telnet:                 Enabled
SSH:                    Disabled
7613 Vlan Configuration That managment accessed to that with this command : analysis module 13 management-port access-vlan 47
C7613-Core-Site#sh ip int brief vlan 47
Interface              IP-Address      OK? Method Status                Protocol
Vlan47                 192.168.253.1   YES manual up                    up
this is show module of slot 13:
C7613-Core-Site#sh module 13
Mod Ports Card Type                              Model              Serial No.
 13    8  Network Analysis Module                WS-SVC-NAM-2-250S  SAL1652VBN0
Mod MAC addresses                       Hw   Fw            Sw           Status
 13  0018.19ee.2852 to 0018.19ee.2859  4.3   7.2(1)        5.1(2)       Ok
Mod  Online Diag Status
 13  Pass
Router IOS = c7600rsp72043-adventerprisek9-mz.152-4.S6
NAM Maintanance Image = 2.1.(2)
with this configuration NAM Module not ping in router and i can access to that but mac address off module ip address resolved:
C7613-Core-Site#ping 192.168.253.2
Sending 5, 100-byte ICMP Echos to 192.168.253.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
C7613-Core-Site#
C7613-Core-Site#sho arp 192.168.253.2
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.253.2           7   001f.9e1a.fe64  ARPA   Vlan47
Any Idea?!
Vinod Arya
The default management VLAN for NAM is VLAN 1.
To select a different VLAN for management, enter the configuration mode for the NAM and enter a command like the following:
analysis module slot_number management-port access-vlan vlan_number
where slot_number is the slot location of the NAM and vlan_number is the VLAN to assign as the management VLAN.
The following example shows how to select VLAN 5 for management of the NAM in slot 4.
 Switch#
configure terminal
 Enter configuration commands, one per line. End with CNTL/Z.
 Switch(config)#
analysis module 4 management-port access-vlan 5
exit
Please check if you have configured this on the device where NAM is plugged in.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
