edwardwaithaka
Beginner
Cisco NAM2320 SFP+/Twinax compatibility
Is the NAM2320 Compatible with the below Twinax Cables?
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU10M
2 REPLIES 2
Marvin Rhoads
VIP Community Legend
None of the twinax 10 Gbps SFPs are listed on the product data sheet for the 2320.
Sometimes they might work despite them not being certified compatible but sometimes they may not. Given that the NAM is a pretty significant investment, I'd stick with the certified compatible optical transceivers.
altemus
Beginner
Hi Edward,
The Cisco 2300 installation guide contains a warning in the Requirements and Restrictions as well as the Connecting the Ports - Direct Connections section as follows:
WARNING: Do not use a SFP-H10GB-CU5M (Cisco part) cable to connect a switch and a Cisco Prime NAM 2320
appliance.
There may be more details in the bug tracker regarding this issue.
You can find the NAM 2300 Installation and Configuration Guide here: http://www.cisco.com/en/US/partner/docs/net_mgmt/network_analysis_module_appliance/2300/installation/guide/adeins.html#wp1098026
Content for Community-Ad
