Cisco Network Assistant 5.8 with old switches
mlangdon34
Beginner
Beginner
Justed upgraded to CNA 5.8(6), when I try to configure any port's VLAN of one of our old switches (Catalyst 3548-XL IOS 12.0(5)WC17)
I am not able to do it anymore. It just shows the error this message :
Error: Modify Port Mode com.cisco.cpnm.features.dsbu.c3500.vlan.C3500Vlan cannot be cast to com.cisco.features.dsbu.defn.vlan.CommonVlan
Is there any workaround ?
Thank you
Marc
rajevasu
Beginner
Beginner
Hi Marc,
     Could you please upgrade to CNA 5.8(7) and try to reproduce the issue. If you are able to reproduce, could you please list the show inventory output and sh version output, so that I can try from local lab setup.
Thanks & Regards,
Rajesh Vasudevan
Hi Rajesh,
Just upgraded to CNA 5.8(7) and I can reproduce the issue :
sh ver output :
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
etna uptime is 3 minutes
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAB0540Q3JR, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:07:85:93:EB:C0
Motherboard assembly number: 73-3903-11
Power supply part number: 34-0971-01
Motherboard serial number: FAB0540D050
Power supply serial number: PAC053402FJ
Model revision number: N0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAB0540Q3JR
Configuration register is 0xF
Thanks for your help
Marc
Hi Marc,
     We are not having the WS-C3548-XL device in our local lab setup to reproduce the issue. Could you please attach the screen shot when the error is displayed in CNA and their logs, so that we can try to find out the solution.
Thanks & Regards,
Rajesh Vasudevan
Hi Rajesh,
Please find attached the screenshot and the lastest lines of logs
3500 device type supports 802.1P
to load RB:featureCommonRB
to load RB:dsbuCommonRB
to load RB:c3500RB
++: DEBUG:  : NEDS: NetworkEntity  discovered by com.cisco.cpnm.features.dsbu.c3500.discovery.C3500NEDM@18feca1
++: DEBUG:  : CMS: cluster data polling interval preference is 30 minutes
++: DEBUG:  : CMS: led data polling interval preference is 10 minutes
++: DEBUG:  : CMS: ip addresses polling interval preference is 10 minutes
to load RB:c2960RB
++: DEBUG:  : NEDS: NetworkEntity  discovered by com.cisco.cpnm.features.dsbu.c2960.discovery.C2960NEDM@2219b4
WindowEntryParser: Unknown tag entry
to load RB:c2960RB
RPS notification processing
java.lang.ClassCastException: com.cisco.cpnm.features.dsbu.c3500.vlan.C3500Vlan cannot be cast to com.cisco.cpnm.features.dsbu.defn.vlan.CommonVlan
    at com.cisco.cpnm.features.dsbu.defn.vlan.TrunkDetailsTask.getNativeVlans(TrunkDetailsTask.java:1651)
    at com.cisco.cpnm.features.dsbu.defn.vlan.TrunkDetailsTask.updateMirrorFromDevice(TrunkDetailsTask.java:514)
    at com.cisco.cpnm.frmwrk.gen.wd.WDContainer.updateMirrorFromDevice(WDContainer.java:590)
    at com.cisco.cpnm.frmwrk.gen.wd.WDWidget$2.run(WDWidget.java:1179)
    at java.lang.Thread.run(Unknown Source)
