Cisco Network Assistant
frey-telecom
Hi there,
I have a 4510R Device. Also some WS-C3750 Edge Switches connected to them. If I connect with the Cisco Network Assistant I cann see the 4510R Core Switch and all the C3750 Edge Switches. This is ok. But on the Edge Switches are connected some other C3750 Switches, and they are not visible with the Cisco Network Assistant over the 4510R. Just the first switch are visible, all other Switches connected to the Edge Switches are not visible. If I connect directly with the CNA to this Switches, all works. But I will see the whole Network over my Core Switch 4510R. Thanx alot
