Cisco Network Assistant
chris_nelson
I have several Cisco 2960 switches set up on our network. I also have them set up through the Cisco Network Assistant. When I look at the topology, I am not seeing the correct corrections. I have removed all VLANs from the topology other than default 1. I have a switch in one location (switch A) connected to 2 other switches (Switch B and C) in 2 other locations. This switch A connection and Switch B and C should actually connect to switch D. I am not looking at this topology correctly? ( I am looking at this from a physical connection perspective.
There are 2 other switches (E and F) where switch A connects to Switch E and Switch E to Switch F - which is correct.
Any thoughts on this?
THanks
Deepak Kumar
What is CNA version and can you share a Picture?
Regards.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
CNA: version 6.3(4) - see attached switches.jpg for layout as seen through CNA.
The way the switches A B and C should be connected according to our set up here, is they go to another switch not shown on through CNA (its an HP switch in the server room). Switch C then connects to another building through a 2 1x 1GB fibre connection.
Could this be because I do not have the full layout with all switches in CNA?
I have also added a pdf file called network layout as it should look.
