02-17-2014 11:25 PM
Hello Expert,
Good day!
I am looking for a tool that can discover network and give connectivity layout (drawing) between cisco active components and other related information ?? .
Hoping to receive your kind comment ..
02-18-2014 03:27 AM
Hi Saud ,
There are few tools available for that :
you can use anyone of them :
Cisco works LMS.
Solarwinds
whatsup Gold etc...
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
02-18-2014 05:09 AM
Also, depending on the size and type of equipment, you can use the freee Cisco Network Assistant (CNA) tool.
http://www.cisco.com/c/en/us/products/cloud-systems-management/network-assistant/index.html
Some people have reported liking the open source tool wktools although I haven't had a chance to try it.
