Cisco network Registrar 6.1.2
hdepre
We have a problem withour server Cisco Network Registrar backup utilisant "secondary zone").
OS: Windows 2000 SP4
Cisco network Registrar 6.1.2 (jan 2005)
After a non specified time, the server does not respond any more on requests DNS (ns= lookup is local on the server and does even not function anymore. A reload, start/stop of the service does not solve the problem, only a reboot completely solve the problem.
logs where it is working:
X14395: ----- TRANSMITTED -- X14395 -----
X14395: Transmitted to 192.168.205.102 over UDP (size$1)
X14395: <-
X14395: <- HEADER SECTION:
X14395: <- id = 61295
X14395: <- qr = 1 opcode = QUERY (0) aa = 0 tc = 0 rd = =
X14395: <- ra = 1 z = 0 (unused) rcode = NOERROR (0)
X14395: <- qdcount = 1 ancount = 2 nscount = 4 adcount = 4
X14395: <- QUESTIONS (1):
X14395: <- php.my-siemens.com IN A
X14395: <- ANSWERS (2):
X14395: <- php.my-siemens.com 300 IN CNAME equinox.erlm.siemens.de
X14395: <- equinox.erlm.siemens.de 3600 IN A 217.194.35.15
X14395: <- AUTHORITY RECORDS (4):
X14395: <- erlm.siemens.de 3600 IN NS syros.erlm.siemens.de
X14395: <- erlm.siemens.de 3600 IN NS emporio.erlm.siemens.de
When the problem is there:
/2005 14:31:06 name/dns/1 Info Server 0 03593
X414570: ----- TRANSMITTED -- X414570 -----
X414570: Transmitted to 207.46.138.20 over UDP (size2)
X414570: <-
X414570: <- HEADER SECTION:
X414570: <- id = 18341
X414570: <- qr = 0 opcode = QUERY (0) aa = 0 tc = 0 rd ==
X414570: <- ra = 0 z = 0 (unused) rcode = NOERROR (0)
X414570: <- qdcount = 1 ancount = 0 nscount = 0 adcount = 0
X414570: <- QUESTIONS (1):
X414570: <- search.msn.com IN A
X414570: <- ANSWERS (0):
X414570: <- AUTHORITY RECORDS (0):
X414570: <- ADDITIONAL RECORDS (0):
X414570: <-
X414570: ----- END OF TRANSMITTED -- X414570 -----
There are no ANSWERS (0):"
The server master is working fine, the backup he is using the principle
de "secondary zone". We see in the logs the synchronisation is working between the 2 servers.
Many thanks
wong34539
Level 6
Level 6
The problem may be due to database corruption. You can try doing the following steps to resolve this issue.
1. You can validate the database. Here are the steps to do that:
a. stop all servers.
b. change directory to network registrar\data\db
c. run this command: dbcheck -a mcddb
2. Do a keybuild.
run this command: keybuild mcddb
3. Restart your servers.
4. Rebuild your resource record indexes in DNS.
here is the command to do that:
dns rebuildRR-Indexes
5. If the above measures fail to help, backup your database before trying
further diagnostics.
6. Then try dropping the zone having difficulty and re-add it.
In most cases this will resolve the problem. Hope this helps.
