Cisco Operation Manager and Service Monitor on Separate Machine?
ali.aldayani
   Can we install Cisco Unified Operation Manager and Server monitor on separate machines?
  What will be the procedure to do so?
Vinod Arya
Yes You can install Service Monitor in a stand alone server. For Service Monitor to coreside on a system with other applications in the Cisco Prime Unified Communications Management Suite, see the coresidence requirements in
Installation Guide for Cisco Prime Unified Operations Manager 9.0.
Also you can check Coresidence Guidelines and Coexistence Guidelines.
Here you can see the server requirements for a coexistent installation of Service Monitor:
http://www.cisco.com/en/US/docs/net_mgmt/prime/unified_service_monitor/9.0/install/guide/prereq.html#wp1080694
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks Vinod for the reply.
But can you share some doc or procedure to install the Service monitor on a stand alone systm.
