11-20-2013 09:56 AM
When attempting to export devices(either all or using filter) I'm prompted for a file password, create file PW, then whether I OPEN, save, or save as, I'm unable to use open the file...I get an error message "'Error 0x80004005: Unspecified Error'"
Tried different physical clients, different client OS, web browser, version of Excel....All the same results....
Any suggestions would be appreciated.
11-20-2013 03:44 PM
The export is an encrypted zipped csv file. The native Windows explorer does not handle encrypted zip files well.
Try using 7-zip (freeware) to extract.
I just did it successfully on my lab server.
11-21-2013 02:00 AM
Thanks..I'll give it a try....Also many thanks on your other Cisco PI 2.0 information/posts/responses...
