04-29-2014 02:28 AM
Hi all,
I need the information about how to upgarde from PI version 1.4 to the new version 2.1.
Is it possible right now and if not, when will it be possible?
THX!!!
Solved! Go to Solution.
04-29-2014 03:50 AM
There is no upgrade path from version 1.4.x to version 2.1 at present.
04-29-2014 03:50 AM
04-29-2014 05:33 AM
salodh has it correct - 1.4 was always intended for a specific use case and not intended to be an upgradeable release. I doubt an upgrade path will be developed or released.
