02-13-2014 02:41 AM
Hi all,
migrating from LMS 4.2x to PI 2.0 I'm familiar with the UserTracking-Acquisition-Process and
its possible settings like Acquisition-Schedule, PingSweep, Excluded Subnetz, DHCP-Handling and so on.
Now within PI 2.0 it seems that these settings are no longer available to change (Administration>System Settings>Client).
With what parameters does PI 2.0 poll client data and where can these settings be modified?
Maybe anybody passed that problem out there.
Thanks for any feedback.
Lothar
02-13-2014 03:20 AM
Hi Lothar,
we donot have such kind of settings in PI ..
you can check the box [ Poll clients when client traps/syslogs received ] under Administration > Client > Client Discovery it should poll based on receiving the traps. That feature is not enabled by default
**wired clients polling cycle (2 hours default).
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
02-13-2014 04:30 AM
Hi Afroz,
thanks for your feedback.
Are there any plans to implement the wired clients aquisition settings as known from LMS?
In our (LMS)-environment UT-Discovery takes about 1-2hours, so decreasing network-load due
to managment-traffic should be customizable.
Should be worth a thought.
Lothar
02-13-2014 04:50 AM
I am not sure ,if these will be added in future releases..
Thanks-
Afroz
