12-16-2013 06:32 AM
Does Cisco Prime 1.2 have the ability to work with image management? I was told yes but I do not see the options and I have verified I have the correct license...
Solved! Go to Solution.
12-16-2013 08:23 AM
you are in classic theme mode , switch to LifeCycle Theme.
On the top right corner , next ti use name like root , you will see the Drop down option..
Thnaks-
Afroz
[Do rate the useful post]
12-16-2013 07:20 AM
Go to Operate > Device work Center > software Image Management
check the below link:
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.2/user/guide/maint_images.html
Thanks-
Afroz
12-16-2013 07:38 AM
I do not see an operate and the link you supplied only takes me to the Cisco homepage....
12-16-2013 08:23 AM
Thnaks-
Afroz
12-19-2013 09:34 PM
Hope you are able to get to the SWIM option
