Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
215
Highlighted
Cisco Prime 1.3 with very high CPU
I'm running Cisco Prime 1.3 Small deployment in VM 5.1
I see Prime using 8.5Ghz of CPU all the time and I think that is odd. All I have is Prime pulling data from 8 WLCs which have about 500 APs.
Is that normal?!
-HB
1 REPLY 1
Highlighted
Here is what I got from the top command:
PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
6213 root      16   0 5975m 2.9g  16m S 243.4 37.8  13407:32 java
Java is eating the processors, is that a common thing?! any fixes?
-HB
Content for Community-Ad
