02-25-2014 11:14 AM
Hi PI Experts,
The following two jobs keep running for two weeks. Is it normal?
They are under Job Dashboard -> System-Defined.
Not sure what are they for. Cannot find them with google.
Is there any way to stop them from running if it's not normal?
SAM_Poller_22_15_GETVPNPoller_-253935627 | PollerJob | In-Progress | Running | 2014-02-13 12:12 | -- : -- : -- |
SAM_Poller_22_15_GETVPNPoller_961682338 | PollerJob | In-Progress | Running | 2014-02-11 12:10 | -- : -- : -- |
Cedar
02-25-2014 02:12 PM
Btw, under Administration -> System Settings -> Background Tasks, I did not see tasks related to these two jobs.
Cedar
02-25-2014 02:45 PM
It wouldn't surprise me if these jobs should be constantly running.
I'll take a look at my 2.0 box tomorrow morning and will reply back.
02-25-2014 03:04 PM
Thanks Rob.
Look forward to your feedback.
Cedar
02-26-2014 05:33 AM
My 2.0 box has 4 SAM_Poller Jobs all of which have a Last Run status of Success
SAM_Poller_700_15_CPU_622922702
SAM_Poller_700_15_DVAVAILABILITY_2064595572
SAM_Poller_700_15_ENVTEMP_-477657161
SAM_Poller_700_15_MEMORY_-1199548056
The names of mine indicate Memory, Envmonitoring, CPU and Availability-
By the looks of the names on your two processes that aren't finishing it appears they have something to do with VPN.
This raises the question: are you monitoring any devices that are VPN capable? If no, perhaps you could disable that functionality on the monitored device...
02-26-2014 02:52 PM
Hi Rob,
I would like to get them disabled. Can you please advise how?
Cedar
