Cisco prime 2.2 GUI login problem
Today for lab simulation I installed cisco prime 2.2 in esxi 5.5, installation successful but I am not able to login GUI of cisco prime, it   give an error "invalid username and password ".
I tried the below steps:
NCS stop
NCS DB reinitdb
NCS start
but no luck to login to cisco prime 2.2, please advice.
Marvin Rhoads
First time login to the GUI should use the username "root". Are you using that?
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/administrator/guide/PIAdminBook/ServerHardening.html#48600
I tried username - root, password - used during installation
but still have the same problem.
Have you tried changing the password from the cli:
conf t
username root password plain <new password> role admin
end
The getting the error as below when I am trying the new password
% Error: Unable to create user, username is reserved by the system..
