Cisco prime 2.2
thusharadennis
Dear Team,
whether the cisco prime is able to fetch the syslogs from the device which are synchorinsed in that.
if possible please explain how the SNMP able to capture those logs.
TD
Marvin Rhoads
Syslogs are distinct from SNMP. Syslog messages are sent from the client to the server based on settings local to the host. The server passively listens - on udp/61 in the case of Prime Infrastructure.
SNMP is totally different in that there are both client-initiated traps and server-initiated polling. That happens (by default) via udp/161 and 162.
The two mechanisms use different agents at both ends of the conversation.
