05-19-2016 06:20 AM
Can anyone tell me how to display a workgroup bridge and its clients on Prime Infrastructure 3.0? In the older versions, when you clicked on the WGB and went to its details page, at the bottom, you could see the clients that were associated to that bridge. I can't find anything like that in 3.0.
05-20-2016 09:25 AM
Hi Chris ,
it is a BUG
CSCuz29632 Wired WGB client details not shown in client details page
It is resolved in 3.1
Thanks-
Afroz
***Ratings Encourages Contributors ***
05-21-2016 07:44 AM
Afroj,
Well, I upgraded to 3.1. I search on the WGB username. Click on the clients, then on one of the usernames. It pops the details page up, I see under Client Attributes> Session it shows Number of Wired Guest Client(s) as 2, but I still do not see where those are listed anywhere. This makes it very difficult as we have thousands on Work Group Bridges deployed and need to be able to see the guest wired clients behind each bridge.
Christopher Tuskan
05-21-2016 09:10 AM
I would advise to raise the TAC case to further investigate the issue.
Thanks-
Afroz
