Cisco Prime 3.1.5 Upgrade Failed
ricky.mcelwee
Trying to upgrade to Prime 3.1.5 and I am receiving an error
"Operation has failed: Device Pack 6 or higher should be deployed before installing this UBF (PI 3.1.5)"
I have Device Pack 10 installed. Below are all of the installed Packages
Prime Infrastructure 3.1 Device Pack 10   Device Support   10.0   Installed   2017-04-17 10:25 EDT
Prime Infrastructure 3.1 Device Pack 4    Device Support    4.0   Installed   2016-10-04 12:46 EDT
PI 3.1.3 Maintenance Release              Critical Fixes  3.0.0   Installed   2016-10-04 11:53 EDT
Has anyone had this issue and if so, how have you resolved it?
I ran into the same thing just yesterday.
I opened a case and the TAC engineer tells me there's a known bugID with a patch they can provide to work around. I have a WebEx scheduled for next week to verify and apply it.
7 Replies 7
Mark Elsen
 - Please re-check installed packages ; by ssh-ing to the Prime server and post the full output of
                      ncs # show version
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Can't see why it's doing this here as well.
Version information of installed applications
Cisco Prime Infrastructure
Version : 3.1.0
Build : 3.1.0.0.132
Critical Fixes:
        PI 3.1.3  Maintenance Release ( 3.0.0 )
Device Support:
        Prime Infrastructure 3.1 Device Pack 4 ( 4.0 )
        Prime Infrastructure 3.1 Device Pack 10 ( 10.0 )
Hello, do you get a solution ?
Thank you
ricky.mcelwee
Worked with TAC yesterday and there is a patch that fixes the Device Pack 6 error. We had a little issue with them getting the file to copy to the shell or it would have only taken them about 15 minutes to complete the fix.
[@ricky.mcelwee]  ,
Thanks for the update. Did you happen to get the BugID?
I did not get the BugID, but the file they sent me was CSCvd93629-patch.zip
