06-02-2021 03:21 PM
Hi guys,
I have recently upgraded Cisco PI from 3.8 to 3.9 and getting a pop-up message "Cisco Prime 3.9 Mandatory Oracle Patch is not installed. Please install the patch for the latest Oracle update. You may contact your System Administrator for further assistance."
Well in this case I am admin :). I am struggling to find this patch but...
Cloud and Systems Management>Routing and Switching Management>Network Management Solutions>Prime Infrastructure>Prime Infrastructure 3.9>Prime Infrastructure Patches- 3.9.1
The only patch listed under above hierarchy is PI_3_9_1-1.0.21.ubf, which i applied but still getting the same message.
Can someone from help find this patch or explain what i am missing?
Thank you very much in advance.
Solved! Go to Solution.
06-04-2021 09:30 AM
Hello Ishamlla,
I owe you a coffee, Thank you
I was looking under 3.9.1.
Your screenshot helped immensely
06-02-2021 03:41 PM
you may need to try this patch i guess here - this is part of the upgrade. ( we are not sure what stage of this upgrade now )
PI_3_9_Oct_Oracle_patch-1.0.8.ubf
read the release notes :
06-04-2021 09:27 AM
Thank you Balaji,
My issue is i cannot find the patch to download.
06-02-2021 04:44 PM
The correct steps to upgrade to PI 3.9 should be:
06-04-2021 09:32 AM
Thank you @Leo Laohoo
My issue was finding the patch which is resolved now. Thank you for response
06-03-2021 01:44 AM
06-04-2021 09:30 AM
Hello Ishamlla,
06-04-2021 10:09 AM
Glad our suggestion helped. and you well sorted.
