Cisco Prime Auth/priv
steve switzer
Hi All
I am trying to put 2 new Nexus 5600 switches on Cisco Prime
The snmp works as i have tested it elsewhere
However when i put the switches on i get the following ...
SNMP Failure :Invlaid security level
Steve
Leo Laohoo
I presume you are using SNMPv2 and the SNMP community you've specified is the RW?
No i am using snmp v3 and i am testing it to make sure it works elsewhere
which it does.
This doesnt seem to be working on the 5600 switch
Steve
Marvin Rhoads
When configuring SNMPv3 (the type of SNMP that uses Authentication and Privacy) on a Nexus, you need to specify the SNMP user on the switch something like this:
snmp-server user <username> network-admin auth md5 <auth key> priv <priv key> localizedkey
I've used that syntax successfully with Nexus 5596's and Prime Infrastructure 2.1. I've not had a chance to do it with a 5600 series but it should work the same.
