11-02-2018 09:16 AM
When Prime backs up switch configuration automatically how is it doing this TFTP/FTP/SFTP or via SNMP?
We have a requirement to encrypt the traffic and to backup regularly but I can't see anywhere to control the schedule or the method of backup.
11-02-2018 11:00 AM
Look at the example document :
if you looking secure, then SFTP is best option.
11-05-2018 05:09 AM
go to Administration / Servers / TFTP/FTP/SFTP Servers
you can add multiple entries to the same IP-address with a different protocol to use
create an entry with the correct IP-address and server-type SFTP and a name to recognize it as sftp-server
then select this reference to be used for configuration backup
11-05-2018 05:24 AM
I think I may have confused the matter by mentioning SFTP.
After looking into it I believe that Cisco Prime pulls the configuration of devices it knows about (switches, routers, etc...) using whatever settings you chose during Discovery i.e SNMPv3 and SSH.
Which means I need to implement SNMPv3 and SSH on all our network devices to ensure encryption.
11-05-2018 05:31 AM
yes that is correct
you need ssh/https/snmpv3 to issue the command for config backup
AND you need a sftp server to receive the config over an encrypted connection.
alternatively you can send an encrypted configuration over a "normal" tftp/ftp connection
11-05-2018 05:37 AM
Does the configuration backup not get saved to the Cisco Prime box?
I thought you only needed an SFTP server if you were intending to save the configuration to an off-box repository?
11-05-2018 07:01 AM
according to this doc Cisco Prime uses an integral TFTP/FTP server
this suggests if you want to use SFTP you need to configure an external server
