Cisco Prime HA secondary
Jose Lucas
is there any way to manually  change HA status on Secondary Prime 2 after initial setup?
CLI commands does not have any option to add high availability configuration after being removed.
Thanks.
Hi Jose ,
unfortunately There is no cli to reactivate it  .   HA was NOT  deactivated properrly as in the .xml file we can still see the Entries.
everything from
should be removed after running the "ncs
ha remove"
what is the output of " ncs ha status " ? on both primary and secondary
To remove HA : " ncs ha remove "  without qoutes
Try to run the  "ncs ha remove " command on bot the server and then try to configure the HA on primary and see how it works.
ASAIK  .After removing the HA configuration from CLI . To re-enable the  HA setup , we need to run the  setup again and
there we need to mentioned that it is a secondary server and from the then configure the Primary to point to it.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
11 Replies 11
AFROJ AHMAD
Hi Jose,
How about GUI .
Go to Administration >system settings > High Availability > HA Configuration
haSettings.xml >> file have the HA config
/opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config/
Thanks-
Afroz
Hi Afroz,
I thinks HA configuration from GUI can only be done from Primary Server.
Trying to operate with second option "hasetting.xml", wich parameter do you mean do I need to modify?
Here we have current config:
ade # cat haSettings.xml
ade #
The problem is that the secondary server was installed in HA but was deactivated later (ncs HA remove).
There is no command in the NCS to reactivate it?
Many thanks.
Hi Jose ,
everything from
ha remove"
Thanks-
Afroz
You were right: I have applied "ncs ha remove" and configure again from GUI on Primary Server and now,
CPI-01/admin# ncs ha status
[State] Primary Active [Failover Type] automatic
CPI-02/admin# ncs ha status
[Server] CPI-01(192.168.1.5) [State] Secondary Syncing [Failover Type] automatic
Services on primary server appears to be ok
CPI-01/admin# ncs sta
start   status
CPI-01/admin# ncs status
Health Monitor Server is running.
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is running.
Plug and Play Gateway is running.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
...but is not the same on Secondary Server
CPI-02/admin# ncs status
Ftp Server is Stopped
Tftp Server is Stopped
Matlab Server is Stopped
NMS Server is stopped.
CNS Gateway with port 11011 is down
CNS Gateway SSL with port 11012 is down
CNS Gateway with port 11013 is down
CNS Gateway SSL with port 11014 is down
Plug and Play Gateway Broker with port 61617 is down
Plug and Play Gateway config, image and resource are down on https
Plug and Play Gateway is stopped.
SAM Daemon is not running ...
DA Daemon is not running ...
Syslog Daemon is not running ...
Finally, how to do start "setup" again on a CIP thas has been already configured?
Many Thanks!
ASAIk , we need to run the setup again for secondary and mentoned this as SECONDARY during the SET ONLY.
Thanks-
Afroz
how can i change HA from automatic to manual using CLI, currently machine is running on secondary server
mtenorio
@Jose Lucas you can from the linux shell
type "shell"
go to the following directory:
/opt/CSCOlumos/bin
There is a script named: hamode.sh
-bash-4.1# ./hamode.sh primary
HA mode is : secondary
Setting HA mode to 'primary'
Changing HA mode will result in *LOSS* of any data currently on the system
Enter 'yes' to proceed ....
yes
I tried this and its working
ade # ./hamode.sh primary
No input arguments are allowed to this script.
ade #
I an not able to execute the command on the secondary.
I can move to the file structure..
I get a permission denied if I run the script on the secondary...
essc01-epnm/admin# shell
Enter shell access password :
Starting bash shell ...
ade #
ade # /opt/CSCOlumos/bin
sh: /opt/CSCOlumos/bin: Is a directory
ade #
sh: ./hamode.sh: Permission denied
ade #
mtenorio
type "shell"
/opt/CSCOlumos/bin
yes
