Cisco Prime Infra 2.2 + Third Party Inventory and configuration backup
Sankar Aniyan
Hi All,
 I am having a doubt related to Cisco prime solution capability to do a discovery and config backup for non-cisco devices.
Requirement is to use Cisco prime to do a discovery, inventory and take configuration backup for non-cisco devices. Is it something possible out of the box ?
If not possible out of the box, is there any method to do that using any custom API ?
Can we monitor 3rd party( Non-cisco) devices using Cisco Prime 2.2 ?
Skr
Ashok Kumar
Below is supported-device list, check if your device is listed there.
http://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
