I am new to the NCS implementations and configurations. I have one very specific case with Cisco Prime Infrastructure 1.2 and autonomnous APs and several issues with Cisco VSS on 6500 switches.
So here is the version from Prime:
NCS/admin# show version
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.1.038
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: NCS
Version information of installed applications
Cisco Prime Network Control System
Version : 1.2.1.012
IOS version on our APs (which are autonomnous) is:
AP-N-1>show ver
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 03:23 by prod_rel_team
Well the issue what we have now is that access point has been added but its not recognized by the NCS prime. I have tried all three versions of SNMP but I get the same result. The SNMP configuration is valid since I use the same for my switching infrastructure. When I enter "debug snmp packets" and "terminal monitor" I can see the SNMP communication between Prime and Aironet 1250 which is standalone.
When I switch to Lifecycle theme and go to Operate > Device Monitor Center I see all devices I have added. The Aironet 1250 is reachable but under collection status I get Managed with Warnings. When I hover over with my mouse I get "None available".
I have successfully added my switching infrastructure in total, which is operating perfectly for Catalyst 2960/3650/3750/4500 series but for 6500 under VSS I have some warnings. The device is recognized by the system which is excellent and all is operational. I get the following errors under Collection Status:
feature_sensor | SNMP request timed out |
feature_powerSupplyFanStatus-6k | SNMP request timed out |
IdentityCapability | The device is unreachable. |
feature_flashdevice | SNMP request timed out |
sam_ipsla_feature | The device is unreachable. |
What can be done to resolve these issues ? I have attached a screenshot of this particular issue. The affected access point is 172.16.165.241.
Predrag Petrovic
Upgrade NCS to the latest version(1.3).
HTH,
Rajeesh P
Hi rajeeshp,
Currently I am not allowed to upgrade it because of internal procedures involved in upgrading a specific piece of software (obtaining permissions from various departments). Is it free to upgrade from 1.2 to 1.3 or there is a specific charge for that.
Predrag Petrovic
Even with the upgrade problem is still present.
Predrag Petrovic
Issue has been resolved by TAC. Our access points (LWAPP and Standalone / Autonomous) were converted from dual-mode APs (2.4GHz and 5.2GHz) to 5.2GHz. Patch has been delivered by Cisco.
Predrag Petrovic
