Cisco Prime Infrastructure 1.2 is not working https & ncs
Hi, I have just deploy Cisco Prime Infrastructure 1.2 in a virtual appliance (Vmware Esxi 5.1). Console is ok & setup is also completed. but there is no NCS application. only app is shwoing: NCSPNP
Cannot access from https also.
Please suggest how to Starting Prime Infrastructure Serve
Marvin Rhoads
From what you describe, it sounds like you have installed the Plug and Play (PNP) ova image. You need to install the Prime Infrastructure image.
See the screenshot below for details (click to enlarge):
