Cisco Prime Infrastructure 2.0 Trial Web Interface
John McNumara
I have installed the Cisco Prime Infrastructure 2.0 Trial, however the VM is not advertising any services on TCP port 80 or 443.
What all is required to access Cisco Prime's web GUI?
Thank you
13 Replies 13
Marvin Rhoads
Can you log in on console (via ssh or from Vshpere client console interface)?
If so, please verify the server is running properly there ("ncs status" command).
prime/admin#ncs status
sh: /opt/CSCOlumos/bin/wcsadmin.sh: No such file or directory
What ova file did you build from?
Your error message seems to imply you didn't use the Prime Insfrastructure 2.0 image (PI-VA-2.0.0.0.294-Express.ova).
I used: PI-VA-2.0.0.0.294-Express.ova
cbs-prime# sh ver
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.6.003-px-build
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: prime
Version information of installed applications
Hmm.
For some reason your application did not install. Otherwise it would show up after "Version information of installed applications"
I removed the VM, unzipped the download and re-deployed the OVF with the same results.
Is there a compatibility issue with ESXi 5.1.0?
ESXi 5.1 should be fine with PI 2.0.
Did you run setup after deploying the OVA as noted in the quick start guide?
I saw this yesterday-
The customer was trying to deploy w/ not enough CPUs available.
bret
Level 3
Level 3
Were you able to get this working. I am having the same issue and I used the PI-VA-2.0.0.0.294-Express.ova image.
Hostname: PA508CISCOPIS1
webx1Cisco
Same error, same setup as you guys.
In my case I had to re-deploy the OVA and let the recommended specs as is (4 CPU and 12 gigs ram).
The first boot took 20-25 minutes with 4 cores (intel xeon) server ? Not impressed at all.....
We had the same issue with the PI-VA-2.0.0.0.294-Express.ova and it seems that the VM needs Internet connectivity (full outgoing https and dns) during the initial deployment.
After redeploying it a couple of times on our internal VMware cluster with the same results (ClassNotFound Exception for the wcsadmin) we just gave it a run and deployed it in the DMZ.
During the final steps of the initial configuration (after the system reboot) it connected over https to an Akamai IP (we figured, it may need to download some packages...?). After that everything was working.
Finally we moved the VM to our internal VMware Cluster and it's still running smoothly without any internet connectivity.
Just another fact, I don't think it's related but anyway: the cluster on which the initial deployment failed is running on AMD Opteron CPUs while the DMZ VMWare cluster is running on Intel Xeons.
