Hi all,
I'm facing a strange issue with CPI 2.1.1 and N5K 5596UP NX-OS 5.2(1)N1(8a), for some reason I'm getting a SNMP Connectivity Failed, here are my T-SHOOT that I've done so far:
1. increasing the timeout and retries - didn't help.
2. change from SNMP v3 to SNMP v2 - didn't help.
3. tried to stop the SNMP process in N5K with the command: no snmp-server protocol disable - its seems that the command not working.
4. stop/start the process.
5. reload the CPI.
also the odd thing is that I have an exact N5K and they are in VPC and don't have any issue with it.
please anyone have an idea?
thanks
The command is incorrect, which should be # no snmp-server protocol enable and not disable. Please login to PI and go to root shell and try to do a snmp poll on the device from there if it fails/succeed.
syntax : snmpwalk -v 2c -c <community> <IP_Add> <OID>
example : snmpwalk -v2c -c publis 1.1.1.1 system
-Thanks
Vinod
