CB90021204
Beginner
Cisco Prime Infrastructure 2.1 Custom Reports
Hi, I need to generate a custom Guest User report from Cisco Prime Infrastructure 2.1. It needs to have a couple more fields added to the existing "Guest User Association" report.
Is it possible to connect to the Cisco Prime Infrastructure Database and Generate custom reports? Is there any documentation on this?
1 REPLY 1
Marvin Rhoads
VIP Community Legend
Programmatic access to PI's data is via the REST API.
Check the help menu on your PI server to see documentation regarding the supported tables and fields that can be queried via that method.
