Cisco Prime Infrastructure 2.1 to setup Discovered Devices in Dashboard Detail auto refresh in 3 minutes
Tang-Suan Tan
Hi all:
I found out that the discovered devices (after successful scanning) in the main Dashboard Detail cannot or take very long time to auto-refreshing the status change.
May I know is there any way by Command Line at the "Root" (I am using an OVA version) or by setting inside the Prime Infrastructure with GUI method to do scheduled Refreshing on the Dashboard Detail?
Thanks!
Best regards,
tangsuan
Tang-Suan Tan
Hi all:
I have tried using Designing Monitoring Template to set the Health Check Polling time from default 15 minutes to 5 minutes and also tried also 1 minute.
The result is 5 minutes is working but 1 minute is not working.
May I know any one can help on this?
Many thanks!
Best regards,
tangsuan
