I'm afraid this is supported officially. There are only two options :
> Installing as a virtual appliance - on an ESXi server.
> Using Cisco Physical Appliance
Installing directly on another hardware, be it UCS or other physical boxes is not supported. I am not sure if anyone would have tried to install and if there is a procedure to do so.
I can you want to try to burn the image as iso on DVD and install on your UCS box, it may have support issues from TAC whenever you'll reach out.
-Thanks
Vinod
**Encourage Contributors. RATE Them**
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
