10-22-2018 12:37 PM
I have a can't open the web interface for the secondary cisco prime and below the #ncs status
cisco-prime-sec/admin# ncs status
Exception in thread "main" java.util.NoSuchElementException
at java.util.Scanner.throwFor(Unknown Source)
at java.util.Scanner.next(Unknown Source)
at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAv ailabilityConfig.java:212)
at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAv ailabilityConfig.java:194)
at com.cisco.common.ha.config.HighAvailabilityConfig.<init>(HighAvailabi lityConfig.java:174)
at com.cisco.common.ha.config.HighAvailabilityConfig.getInstance(HighAva ilabilityConfig.java:183)
at com.cisco.packaging.HMAdmin.initHealthMonitorApi(HMAdmin.java:404)
at com.cisco.packaging.HMAdmin.hmServerStatus(HMAdmin.java:299)
at com.cisco.packaging.HMAdmin.status(HMAdmin.java:170)
at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:914)
at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:888)
at com.cisco.packaging.WCSAdmin.runMain(WCSAdmin.java:294)
at com.cisco.packaging.WCSAdmin.main(WCSAdmin.java:1123)
CNS Gateway with port 11011 is down
CNS Gateway SSL with port 11012 is down
CNS Gateway with port 11013 is down
CNS Gateway SSL with port 11014 is down
Plug and Play Gateway Broker with port 61617 is down
Plug and Play Gateway config, image and resource are down on https
Plug and Play Gateway is stopped.
SAM Daemon is stopped.
DA Daemon is stopped.
and tried to restart ncs but bad luck to reach the web interface.
How can I fix this issue?
10-24-2018 02:00 AM
- Try to reboot the prime server (too)
M.
10-30-2018 04:51 AM
10-30-2018 05:41 AM
- Check this thread :
https://community.cisco.com/t5/network-management/pi-not-start-java-error/td-p/3217613
M.
