Cisco Prime Infrastructure 3.1
Richard Lopez
I was wondering if i am able to distribute code from cisco prime to a 4507 with dual supervisors. And if i can would it push the code down to the secondary supervisor.
Leo Laohoo
Even if it could, don't even try.
If a chassis has dual-supervisor then it probably means it's very important. Upgrading the IOS is easy on a 4500:
1. Copy the IOS to the primary supervisor engine;
2. Copy the IOS to the secondary supervisor engine;
3. Change the boot variable string;
NOTE: Erase ALL the old boot variable string, put the new one pointing to the new IOS file, put another one pointing to the old IOS.
4.  Check the config-registry is 0x2102;
5.  Save the config; and
OPTIONAL:  Export the config out of the chassis.
6. Reboot.
Make sure you read the Release Notes carefully. There are cases where before the new IOS can be loaded a ROMmon upgrade is mandatory.
just was wondering if there was an easier way to deploy code to the 4500s.
@Leo Laohoo already provided best easy way to upgrade. hope that is the simple way to upgrade, rather complicated with ISSU.
BB
Francesco Molino
Prime doesn't support software deployment on 4500 with dual supervisor.
ISSU could be a way if both images (old and new) are compatible but lot of my customers have had bad experience with it.
I personally user Leo's method which is the best and ensure everything goes well add expected.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
