Cisco prime infrastructure 3.6
rvarela1223
Cisco prime running very slowly.  Checked and found that ncs stop then ncs start did not work.
When I ran ncs start received this error: cisco prime cat: write error: No space left on device.  Ran ncs cleanup and no luck.
Checked in discussion community about how to fix and when I ran df -h lists out that /var/ is 100% full.  when I list out the files it shows that the /var/dev/mapper/smosvg-varvol has 0% free space
Attempted to follow instructions from this discussion thread:  https://community.cisco.com/t5/other-wireless-mobility-subjects/pi-3-2-var-full-100/td-p/3314386
. SSH to your Prime Infrastructure
2. Login and then typ: shell and login again
3. Run sudo su -
4. run df -h to check the diskspace
5. run cd /var/cache/logwatch/
6. run ls -l to view files
7. run rm -rf logwatch.{filename} to delete a file or logwatch.* to delete all
But when I run step 5 i get no such file/directory.
Can anyone provide some instructions on resolving this?
8 Replies 8
marce1000
 - Check for other big directories in /var with a command as for instance :
                       #  du -a /var/ | sort -n -r | head -n 20
  and or subsequently find the largest file(s) with :
                       #   find /var -type f -printf "%s\t%p\n" | sort -n | tail -20
  You will still have to deterimine as to whether these can  be safely deleted.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
M
Thanks for the information.  I am trying to do a yum cleanup and hopefully when it completes I will try your instructions
thanks
share the following output:
df -h
du -h --max-depth=6 / var | grep [0-9]G | sort -k2
based on above output, clean the files and ensure to enable logrotation on these segment.
This is what I get:
ade # df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/smosvg-rootvol 3.8G 171M 3.5G 5% /
devtmpfs 7.9G 0 7.9G 0% /dev
tmpfs 7.9G 0 7.9G 0% /dev/shm
tmpfs 7.9G 377M 7.5G 5% /run
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
/dev/mapper/smosvg-usrvol 6.7G 1.4G 5.0G 22% /usr
/dev/sda2 93M 1.6M 87M 2% /storedconfig
/dev/sda1 477M 128M 324M 29% /boot
/dev/mapper/smosvg-recvol 120M 1.6M 113M 2% /recovery
/dev/mapper/smosvg-home 120M 1.6M 112M 2% /home
/dev/mapper/smosvg-altrootvol 120M 1.6M 113M 2% /altroot
/dev/mapper/smosvg-localdiskvol 132G 60M 125G 1% /localdisk
/dev/mapper/smosvg-optvol 705G 325G 345G 49% /opt
/dev/mapper/smosvg-tmpvol 2.0G 3.1M 1.9G 1% /tmp
/dev/mapper/smosvg-storeddatavol 9.6G 1.9G 7.2G 21% /storeddata
/dev/mapper/smosvg-varvol 3.8G 3.8G 0 100% /var
ade # du -h --max-depth=6 /var| grep[0-9]G | sort -k2
sh: grep[0-9]G: command not found
du: cannot read directory '/var/spool/mqueue': Permission denied
Apologies re-ran the 2nd command and get this:
du: cannot read directory '/usr/libexec/initscripts/legacy-actions/auditd': Permission denied
du: cannot read directory '/usr/share/polkit-1/rules.d': Permission denied
du: cannot read directory '/usr/lost+found': Permission denied
du: cannot read directory '/proc/tty/driver': Permission denied
du: cannot read directory '/proc/1/task/1/fd': Permission denied
du: cannot read directory '/proc/1/task/1/fdinfo': Permission denied
du: cannot read directory '/proc/1/task/1/ns': Permission denied
du: cannot read directory '/proc/1/fd': Permission denied
du: cannot read directory '/proc/1/map_files': Permission denied
du: cannot read directory '/proc/1/fdinfo': Permission denied
du: cannot read directory '/proc/1/ns': Permission denied
du: cannot read directory '/proc/2/task/2/fd': Permission denied
du: cannot read directory '/proc/2/task/2/fdinfo': Permission denied
du: cannot read directory '/proc/2/task/2/ns': Permission denied
du: cannot read directory '/proc/2/fd': Permission denied
du: cannot read directory '/proc/2/map_files': Permission denied
du: cannot read directory '/proc/2/fdinfo': Permission denied
du: cannot read directory '/proc/2/ns': Permission denied
du: cannot read directory '/proc/3/task/3/fd': Permission denied
du: cannot read directory '/proc/3/task/3/fdinfo': Permission denied
du: cannot read directory '/proc/3/task/3/ns': Permission denied
du: cannot read directory '/proc/3/fd': Permission denied
du: cannot read directory '/proc/3/map_files': Permission denied
du: cannot read directory '/proc/3/fdinfo': Permission denied
du: cannot read directory '/proc/3/ns': Permission denied
du: cannot read directory '/proc/5/task/5/fd': Permission denied
du: cannot read directory '/proc/5/task/5/fdinfo': Permission denied
du: cannot read directory '/proc/5/task/5/ns': Permission denied
du: cannot read directory '/proc/5/fd': Permission denied
du: cannot read directory '/proc/5/map_files': Permission denied
du: cannot read directory '/proc/5/fdinfo': Permission denied
du: cannot read directory '/proc/5/ns': Permission denied
du: cannot read directory '/proc/6/task/6/fd': Permission denied
du: cannot read directory '/proc/6/task/6/fdinfo': Permission denied
du: cannot read directory '/proc/6/task/6/ns': Permission denied
du: cannot read directory '/proc/6/fd': Permission denied
du: cannot read directory '/proc/6/map_files': Permission denied
du: cannot read directory '/proc/6/fdinfo': Permission denied
du: cannot read directory '/proc/6/ns': Permission denied
du: cannot read directory '/proc/8/task/8/fd': Permission denied
du: cannot read directory '/proc/8/task/8/fdinfo': Permission denied
du: cannot read directory '/proc/8/task/8/ns': Permission denied
du: cannot read directory '/proc/8/fd': Permission denied
du: cannot read directory '/proc/8/map_files': Permission denied
du: cannot read directory '/proc/8/fdinfo': Permission denied
du: cannot read directory '/proc/8/ns': Permission denied
du: cannot read directory '/proc/9/task/9/fd': Permission denied
du: cannot read directory '/proc/9/task/9/fdinfo': Permission denied
du: cannot read directory '/proc/9/task/9/ns': Permission denied
du: cannot read directory '/proc/9/fd': Permission denied
du: cannot read directory '/proc/9/map_files': Permission denied
du: cannot read directory '/proc/9/fdinfo': Permission denied
du: cannot read directory '/proc/9/ns': Permission denied
du: cannot read directory '/proc/10/task/10/fd': Permission denied
du: cannot read directory '/proc/10/task/10/fdinfo': Permission denied
du: cannot read directory '/proc/10/task/10/ns': Permission denied
du: cannot read directory '/proc/10/fd': Permission denied
du: cannot read directory '/proc/10/map_files': Permission denied
du: cannot read directory '/proc/10/fdinfo': Permission denied
du: cannot read directory '/proc/10/ns': Permission denied
du: cannot read directory '/proc/11/task/11/fd': Permission denied
du: cannot read directory '/proc/11/task/11/fdinfo': Permission denied
du: cannot read directory '/proc/11/task/11/ns': Permission denied
du: cannot read directory '/proc/11/fd': Permission denied
du: cannot read directory '/proc/11/map_files': Permission denied
du: cannot read directory '/proc/11/fdinfo': Permission denied
du: cannot read directory '/proc/11/ns': Permission denied
du: cannot read directory '/proc/14/task/14/fd': Permission denied
du: cannot read directory '/proc/14/task/14/fdinfo': Permission denied
du: cannot read directory '/proc/14/task/14/ns': Permission denied
du: cannot read directory '/proc/14/fd': Permission denied
du: cannot read directory '/proc/14/map_files': Permission denied
du: cannot read directory '/proc/14/fdinfo': Permission denied
du: cannot read directory '/proc/14/ns': Permission denied
du: cannot read directory '/proc/15/task/15/fd': Permission denied
du: cannot read directory '/proc/15/task/15/fdinfo': Permission denied
du: cannot read directory '/proc/15/task/15/ns': Permission denied
du: cannot read directory '/proc/15/fd': Permission denied
du: cannot read directory '/proc/15/map_files': Permission denied
du: cannot read directory '/proc/15/fdinfo': Permission denied
du: cannot read directory '/proc/15/ns': Permission denied
du: cannot read directory '/proc/17/task/17/fd': Permission denied
du: cannot read directory '/proc/17/task/17/fdinfo': Permission denied
du: cannot read directory '/proc/17/task/17/ns': Permission denied
du: cannot read directory '/proc/17/fd': Permission denied
du: cannot read directory '/proc/17/map_files': Permission denied
du: cannot read directory '/proc/17/fdinfo': Permission denied
du: cannot read directory '/proc/17/ns': Permission denied
du: cannot read directory '/proc/19/task/19/fd': Permission denied
du: cannot read directory '/proc/19/task/19/fdinfo': Permission denied
du: cannot read directory '/proc/19/task/19/ns': Permission denied
du: cannot read directory '/proc/19/fd': Permission denied
du: cannot read directory '/proc/19/map_files': Permission denied
du: cannot read directory '/proc/19/fdinfo': Permission denied
du: cannot read directory '/proc/19/ns': Permission denied
du: cannot read directory '/proc/20/task/20/fd': Permission denied
du: cannot read directory '/proc/20/task/20/fdinfo': Permission denied
du: cannot read directory '/proc/20/task/20/ns': Permission denied
du: cannot read directory '/proc/20/fd': Permission denied
du: cannot read directory '/proc/20/map_files': Permission denied
du: cannot read directory '/proc/20/fdinfo': Permission denied
du: cannot read directory '/proc/20/ns': Permission denied
du: cannot read directory '/proc/22/task/22/fd': Permission denied
du: cannot read directory '/proc/22/task/22/fdinfo': Permission denied
du: cannot read directory '/proc/22/task/22/ns': Permission denied
du: cannot read directory '/proc/22/fd': Permission denied
du: cannot read directory '/proc/22/map_files': Permission denied
du: cannot read directory '/proc/22/fdinfo': Permission denied
du: cannot read directory '/proc/22/ns': Permission denied
du: cannot read directory '/proc/24/task/24/fd': Permission denied
du: cannot read directory '/proc/24/task/24/fdinfo': Permission denied
du: cannot read directory '/proc/24/task/24/ns': Permission denied
du: cannot read directory '/proc/24/fd': Permission denied
du: cannot read directory '/proc/24/map_files': Permission denied
du: cannot read directory '/proc/24/fdinfo': Permission denied
du: cannot read directory '/proc/24/ns': Permission denied
du: cannot read directory '/proc/25/task/25/fd': Permission denied
du: cannot read directory '/proc/25/task/25/fdinfo': Permission denied
du: cannot read directory '/proc/25/task/25/ns': Permission denied
du: cannot read directory '/proc/25/fd': Permission denied
du: cannot read directory '/proc/25/map_files': Permission denied
du: cannot read directory '/proc/25/fdinfo': Permission denied
du: cannot read directory '/proc/25/ns': Permission denied
du: cannot read directory '/proc/27/task/27/fd': Permission denied
du: cannot read directory '/proc/27/task/27/fdinfo': Permission denied
du: cannot read directory '/proc/27/task/27/ns': Permission denied
du: cannot read directory '/proc/27/fd': Permission denied
du: cannot read directory '/proc/27/map_files': Permission denied
du: cannot read directory '/proc/27/fdinfo': Permission denied
du: cannot read directory '/proc/27/ns': Permission denied
du: cannot read directory '/proc/29/task/29/fd': Permission denied
du: cannot read directory '/proc/29/task/29/fdinfo': Permission denied
du: cannot read directory '/proc/29/task/29/ns': Permission denied
du: cannot read directory '/proc/29/fd': Permission denied
du: cannot read directory '/proc/29/map_files': Permission denied
du: cannot read directory '/proc/29/fdinfo': Permission denied
du: cannot read directory '/proc/29/ns': Permission denied
du: cannot read directory '/proc/30/task/30/fd': Permission denied
du: cannot read directory '/proc/30/task/30/fdinfo': Permission denied
du: cannot read directory '/proc/30/task/30/ns': Permission denied
du: cannot read directory '/proc/30/fd': Permission denied
du: cannot read directory '/proc/30/map_files': Permission denied
du: cannot read directory '/proc/30/fdinfo': Permission denied
du: cannot read directory '/proc/30/ns': Permission denied
du: cannot read directory '/proc/32/task/32/fd': Permission denied
du: cannot read directory '/proc/32/task/32/fdinfo': Permission denied
du: cannot read directory '/proc/32/task/32/ns': Permission denied
du: cannot read directory '/proc/32/fd': Permission denied
du: cannot read directory '/proc/32/map_files': Permission denied
du: cannot read directory '/proc/32/fdinfo': Permission denied
du: cannot read directory '/proc/32/ns': Permission denied
du: cannot read directory '/proc/34/task/34/fd': Permission denied
du: cannot read directory '/proc/34/task/34/fdinfo': Permission denied
du: cannot read directory '/proc/34/task/34/ns': Permission denied
du: cannot read directory '/proc/34/fd': Permission denied
du: cannot read directory '/proc/34/map_files': Permission denied
du: cannot read directory '/proc/34/fdinfo': Permission denied
du: cannot read directory '/proc/34/ns': Permission denied
du: cannot read directory '/proc/35/task/35/fd': Permission denied
du: cannot read directory '/proc/35/task/35/fdinfo': Permission denied
du: cannot read directory '/proc/35/task/35/ns': Permission denied
du: cannot read directory '/proc/35/fd': Permission denied
du: cannot read directory '/proc/35/map_files': Permission denied
du: cannot read directory '/proc/35/fdinfo': Permission denied
du: cannot read directory '/proc/35/ns': Permission denied
du: cannot read directory '/proc/37/task/37/fd': Permission denied
du: cannot read directory '/proc/37/task/37/fdinfo': Permission denied
du: cannot read directory '/proc/37/task/37/ns': Permission denied
du: cannot read directory '/proc/37/fd': Permission denied
du: cannot read directory '/proc/37/map_files': Permission denied
du: cannot read directory '/proc/37/fdinfo': Permission denied
du: cannot read directory '/proc/37/ns': Permission denied
du: cannot read directory '/proc/39/task/39/fd': Permission denied
du: cannot read directory '/proc/39/task/39/fdinfo': Permission denied
du: cannot read directory '/proc/39/task/39/ns': Permission denied
du: cannot read directory '/proc/39/fd': Permission denied
du: cannot read directory '/proc/39/map_files': Permission denied
du: cannot read directory '/proc/39/fdinfo': Permission denied
du: cannot read directory '/proc/39/ns': Permission denied
du: cannot read directory '/proc/40/task/40/fd': Permission denied
du: cannot read directory '/proc/40/task/40/fdinfo': Permission denied
du: cannot read directory '/proc/40/task/40/ns': Permission denied
du: cannot read directory '/proc/40/fd': Permission denied
du: cannot read directory '/proc/40/map_files': Permission denied
du: cannot read directory '/proc/40/fdinfo': Permission denied
du: cannot read directory '/proc/40/ns': Permission denied
du: cannot read directory '/proc/42/task/42/fd': Permission denied
du: cannot read directory '/proc/42/task/42/fdinfo': Permission denied
du: cannot read directory '/proc/42/task/42/ns': Permission denied
du: cannot read directory '/proc/42/fd': Permission denied
du: cannot read directory '/proc/42/map_files': Permission denied
du: cannot read directory '/proc/42/fdinfo': Permission denied
du: cannot read directory '/proc/42/ns': Permission denied
du: cannot read directory '/proc/44/task/44/fd': Permission denied
du: cannot read directory '/proc/44/task/44/fdinfo': Permission denied
du: cannot read directory '/proc/44/task/44/ns': Permission denied
du: cannot read directory '/proc/44/fd': Permission denied
du: cannot read directory '/proc/44/map_files': Permission denied
du: cannot read directory '/proc/44/fdinfo': Permission denied
du: cannot read directory '/proc/44/ns': Permission denied
du: cannot read directory '/proc/45/task/45/fd': Permission denied
du: cannot read directory '/proc/45/task/45/fdinfo': Permission denied
du: cannot read directory '/proc/45/task/45/ns': Permission denied
du: cannot read directory '/proc/45/fd': Permission denied
du: cannot read directory '/proc/45/map_files': Permission denied
du: cannot read directory '/proc/45/fdinfo': Permission denied
du: cannot read directory '/proc/45/ns': Permission denied
du: cannot read directory '/proc/47/task/47/fd': Permission denied
du: cannot read directory '/proc/47/task/47/fdinfo': Permission denied
du: cannot read directory '/proc/47/task/47/ns': Permission denied
du: cannot read directory '/proc/47/fd': Permission denied
du: cannot read directory '/proc/47/map_files': Permission denied
du: cannot read directory '/proc/47/fdinfo': Permission denied
du: cannot read directory '/proc/47/ns': Permission denied
du: cannot read directory '/proc/49/task/49/fd': Permission denied
du: cannot read directory '/proc/49/task/49/fdinfo': Permission denied
du: cannot read directory '/proc/49/task/49/ns': Permission denied
du: cannot read directory '/proc/49/fd': Permission denied
du: cannot read directory '/proc/49/map_files': Permission denied
du: cannot read directory '/proc/49/fdinfo': Permission denied
du: cannot read directory '/proc/49/ns': Permission denied
du: cannot read directory '/proc/50/task/50/fd': Permission denied
du: cannot read directory '/proc/50/task/50/fdinfo': Permission denied
du: cannot read directory '/proc/50/task/50/ns': Permission denied
du: cannot read directory '/proc/50/fd': Permission denied
du: cannot read directory '/proc/50/map_files': Permission denied
du: cannot read directory '/proc/50/fdinfo': Permission denied
du: cannot read directory '/proc/50/ns': Permission denied
du: cannot read directory '/proc/52/task/52/fd': Permission denied
du: cannot read directory '/proc/52/task/52/fdinfo': Permission denied
du: cannot read directory '/proc/52/task/52/ns': Permission denied
du: cannot read directory '/proc/52/fd': Permission denied
du: cannot read directory '/proc/52/map_files': Permission denied
du: cannot read directory '/proc/52/fdinfo': Permission denied
du: cannot read directory '/proc/52/ns': Permission denied
du: cannot read directory '/proc/55/task/55/fd': Permission denied
du: cannot read directory '/proc/55/task/55/fdinfo': Permission denied
du: cannot read directory '/proc/55/task/55/ns': Permission denied
du: cannot read directory '/proc/55/fd': Permission denied
du: cannot read directory '/proc/55/map_files': Permission denied
du: cannot read directory '/proc/55/fdinfo': Permission denied
du: cannot read directory '/proc/55/ns': Permission denied
du: cannot read directory '/proc/56/task/56/fd': Permission denied
du: cannot read directory '/proc/56/task/56/fdinfo': Permission denied
du: cannot read directory '/proc/56/task/56/ns': Permission denied
du: cannot read directory '/proc/56/fd': Permission denied
du: cannot read directory '/proc/56/map_files': Permission denied
du: cannot read directory '/proc/56/fdinfo': Permission denied
du: cannot read directory '/proc/56/ns': Permission denied
du: cannot read directory '/proc/58/task/58/fd': Permission denied
du: cannot read directory '/proc/58/task/58/fdinfo': Permission denied
du: cannot read directory '/proc/58/task/58/ns': Permission denied
du: cannot read directory '/proc/58/fd': Permission denied
du: cannot read directory '/proc/58/map_files': Permission denied
du: cannot read directory '/proc/58/fdinfo': Permission denied
du: cannot read directory '/proc/58/ns': Permission denied
du: cannot read directory '/proc/60/task/60/fd': Permission denied
du: cannot read directory '/proc/60/task/60/fdinfo': Permission denied
du: cannot read directory '/proc/60/task/60/ns': Permission denied
du: cannot read directory '/proc/60/fd': Permission denied
du: cannot read directory '/proc/60/map_files': Permission denied
du: cannot read directory '/proc/60/fdinfo': Permission denied
du: cannot read directory '/proc/60/ns': Permission denied
du: cannot read directory '/proc/61/task/61/fd': Permission denied
du: cannot read directory '/proc/61/task/61/fdinfo': Permission denied
du: cannot read directory '/proc/61/task/61/ns': Permission denied
du: cannot read directory '/proc/61/fd': Permission denied
du: cannot read directory '/proc/61/map_files': Permission denied
du: cannot read directory '/proc/61/fdinfo': Permission denied
du: cannot read directory '/proc/61/ns': Permission denied
du: cannot read directory '/proc/63/task/63/fd': Permission denied
du: cannot read directory '/proc/63/task/63/fdinfo': Permission denied
du: cannot read directory '/proc/63/task/63/ns': Permission denied
du: cannot read directory '/proc/63/fd': Permission denied
du: cannot read directory '/proc/63/map_files': Permission denied
du: cannot read directory '/proc/63/fdinfo': Permission denied
du: cannot read directory '/proc/63/ns': Permission denied
du: cannot read directory '/proc/65/task/65/fd': Permission denied
du: cannot read directory '/proc/65/task/65/fdinfo': Permission denied
du: cannot read directory '/proc/65/task/65/ns': Permission denied
du: cannot read directory '/proc/65/fd': Permission denied
du: cannot read directory '/proc/65/map_files': Permission denied
du: cannot read directory '/proc/65/fdinfo': Permission denied
du: cannot read directory '/proc/65/ns': Permission denied
du: cannot read directory '/proc/66/task/66/fd': Permission denied
du: cannot read directory '/proc/66/task/66/fdinfo': Permission denied
du: cannot read directory '/proc/66/task/66/ns': Permission denied
du: cannot read directory '/proc/66/fd': Permission denied
du: cannot read directory '/proc/66/map_files': Permission denied
du: cannot read directory '/proc/66/fdinfo': Permission denied
du: cannot read directory '/proc/66/ns': Permission denied
du: cannot read directory '/proc/68/task/68/fd': Permission denied
du: cannot read directory '/proc/68/task/68/fdinfo': Permission denied
du: cannot read directory '/proc/68/task/68/ns': Permission denied
du: cannot read directory '/proc/68/fd': Permission denied
du: cannot read directory '/proc/68/map_files': Permission denied
du: cannot read directory '/proc/68/fdinfo': Permission denied
du: cannot read directory '/proc/68/ns': Permission denied
du: cannot read directory '/proc/70/task/70/fd': Permission denied
du: cannot read directory '/proc/70/task/70/fdinfo': Permission denied
du: cannot read directory '/proc/70/task/70/ns': Permission denied
du: cannot read directory '/proc/70/fd': Permission denied
du: cannot read directory '/proc/70/map_files': Permission denied
du: cannot read directory '/proc/70/fdinfo': Permission denied
du: cannot read directory '/proc/70/ns': Permission denied
du: cannot read directory '/proc/71/task/71/fd': Permission denied
du: cannot read directory '/proc/71/task/71/fdinfo': Permission denied
du: cannot read directory '/proc/71/task/71/ns': Permission denied
du: cannot read directory '/proc/71/fd': Permission denied
du: cannot read directory '/proc/71/map_files': Permission denied
du: cannot read directory '/proc/71/fdinfo': Permission denied
du: cannot read directory '/proc/71/ns': Permission denied
du: cannot read directory '/proc/73/task/73/fd': Permission denied
du: cannot read directory '/proc/73/task/73/fdinfo': Permission denied
du: cannot read directory '/proc/73/task/73/ns': Permission denied
du: cannot read directory '/proc/73/fd': Permission denied
du: cannot read directory '/proc/73/map_files': Permission denied
du: cannot read directory '/proc/73/fdinfo': Permission denied
du: cannot read directory '/proc/73/ns': Permission denied
du: cannot read directory '/proc/75/task/75/fd': Permission denied
du: cannot read directory '/proc/75/task/75/fdinfo': Permission denied
du: cannot read directory '/proc/75/task/75/ns': Permission denied
du: cannot read directory '/proc/75/fd': Permission denied
du: cannot read directory '/proc/75/map_files': Permission denied
du: cannot read directory '/proc/75/fdinfo': Permission denied
du: cannot read directory '/proc/75/ns': Permission denied
du: cannot read directory '/proc/76/task/76/fd': Permission denied
du: cannot read directory '/proc/76/task/76/fdinfo': Permission denied
du: cannot read directory '/proc/76/task/76/ns': Permission denied
du: cannot read directory '/proc/76/fd': Permission denied
du: cannot read directory '/proc/76/map_files': Permission denied
du: cannot read directory '/proc/76/fdinfo': Permission denied
du: cannot read directory '/proc/76/ns': Permission denied
du: cannot read directory '/proc/78/task/78/fd': Permission denied
du: cannot read directory '/proc/78/task/78/fdinfo': Permission denied
du: cannot read directory '/proc/78/task/78/ns': Permission denied
du: cannot read directory '/proc/78/fd': Permission denied
du: cannot read directory '/proc/78/map_files': Permission denied
du: cannot read directory '/proc/78/fdinfo': Permission denied
du: cannot read directory '/proc/78/ns': Permission denied
du: cannot read directory '/proc/80/task/80/fd': Permission denied
du: cannot read directory '/proc/80/task/80/fdinfo': Permission denied
du: cannot read directory '/proc/80/task/80/ns': Permission denied
du: cannot read directory '/proc/80/fd': Permission denied
du: cannot read directory '/proc/80/map_files': Permission denied
du: cannot read directory '/proc/80/fdinfo': Permission denied
du: cannot read directory '/proc/80/ns': Permission denied
du: cannot read directory '/proc/81/task/81/fd': Permission denied
du: cannot read directory '/proc/81/task/81/fdinfo': Permission denied
du: cannot read directory '/proc/81/task/81/ns': Permission denied
du: cannot read directory '/proc/81/fd': Permission denied
du: cannot read directory '/proc/81/map_files': Permission denied
du: cannot read directory '/proc/81/fdinfo': Permission denied
du: cannot read directory '/proc/81/ns': Permission denied
du: cannot read directory '/proc/83/task/83/fd': Permission denied
du: cannot read directory '/proc/83/task/83/fdinfo': Permission denied
du: cannot read directory '/proc/83/task/83/ns': Permission denied
du: cannot read directory '/proc/83/fd': Permission denied
du: cannot read directory '/proc/83/map_files': Permission denied
du: cannot read directory '/proc/83/fdinfo': Permission denied
du: cannot read directory '/proc/83/ns': Permission denied
du: cannot read directory '/proc/85/task/85/fd': Permission denied
du: cannot read directory '/proc/85/task/85/fdinfo': Permission denied
du: cannot read directory '/proc/85/task/85/ns': Permission denied
du: cannot read directory '/proc/85/fd': Permission denied
du: cannot read directory '/proc/85/map_files': Permission denied
du: cannot read directory '/proc/85/fdinfo': Permission denied
du: cannot read directory '/proc/85/ns': Permission denied
du: cannot read directory '/proc/86/task/86/fd': Permission denied
du: cannot read directory '/proc/86/task/86/fdinfo': Permission denied
du: cannot read directory '/proc/86/task/86/ns': Permission denied
du: cannot read directory '/proc/86/fd': Permission denied
du: cannot read directory '/proc/86/map_files': Permission denied
du: cannot read directory '/proc/86/fdinfo': Permission denied
du: cannot read directory '/proc/86/ns': Permission denied
du: cannot read directory '/proc/88/task/88/fd': Permission denied
du: cannot read directory '/proc/88/task/88/fdinfo': Permission denied
du: cannot read directory '/proc/88/task/88/ns': Permission denied
du: cannot read directory '/proc/88/fd': Permission denied
du: cannot read directory '/proc/88/map_files': Permission denied
du: cannot read directory '/proc/88/fdinfo': Permission denied
du: cannot read directory '/proc/88/ns': Permission denied
du: cannot read directory '/proc/91/task/91/fd': Permission denied
du: cannot read directory '/proc/91/task/91/fdinfo': Permission denied
du: cannot read directory '/proc/91/task/91/ns': Permission denied
du: cannot read directory '/proc/91/fd': Permission denied
du: cannot read directory '/proc/91/map_files': Permission denied
du: cannot read directory '/proc/91/fdinfo': Permission denied
du: cannot read directory '/proc/91/ns': Permission denied
du: cannot read directory '/proc/92/task/92/fd': Permission denied
du: cannot read directory '/proc/92/task/92/fdinfo': Permission denied
du: cannot read directory '/proc/92/task/92/ns': Permission denied
du: cannot read directory '/proc/92/fd': Permission denied
du: cannot read directory '/proc/92/map_files': Permission denied
du: cannot read directory '/proc/92/fdinfo': Permission denied
du: cannot read directory '/proc/92/ns': Permission denied
du: cannot read directory '/proc/93/task/93/fd': Permission denied
du: cannot read directory '/proc/93/task/93/fdinfo': Permission denied
du: cannot read directory '/proc/93/task/93/ns': Permission denied
du: cannot read directory '/proc/93/fd': Permission denied
du: cannot read directory '/proc/93/map_files': Permission denied
du: cannot read directory '/proc/93/fdinfo': Permission denied
du: cannot read directory '/proc/93/ns': Permission denied
du: cannot read directory '/proc/94/task/94/fd': Permission denied
du: cannot read directory '/proc/94/task/94/fdinfo': Permission denied
du: cannot read directory '/proc/94/task/94/ns': Permission denied
du: cannot read directory '/proc/94/fd': Permission denied
du: cannot read directory '/proc/94/map_files': Permission denied
du: cannot read directory '/proc/94/fdinfo': Permission denied
du: cannot read directory '/proc/94/ns': Permission denied
du: cannot read directory '/proc/95/task/95/fd': Permission denied
du: cannot read directory '/proc/95/task/95/fdinfo': Permission denied
du: cannot read directory '/proc/95/task/95/ns': Permission denied
du: cannot read directory '/proc/95/fd': Permission denied
du: cannot read directory '/proc/95/map_files': Permission denied
du: cannot read directory '/proc/95/fdinfo': Permission denied
du: cannot read directory '/proc/95/ns': Permission denied
du: cannot read directory '/proc/96/task/96/fd': Permission denied
du: cannot read directory '/proc/96/task/96/fdinfo': Permission denied
du: cannot read directory '/proc/96/task/96/ns': Permission denied
du: cannot read directory '/proc/96/fd': Permission denied
du: cannot read directory '/proc/96/map_files': Permission denied
du: cannot read directory '/proc/96/fdinfo': Permission denied
du: cannot read directory '/proc/96/ns': Permission denied
du: cannot read directory '/proc/97/task/97/fd': Permission denied
du: cannot read directory '/proc/97/task/97/fdinfo': Permission denied
du: cannot read directory '/proc/97/task/97/ns': Permission denied
du: cannot read directory '/proc/97/fd': Permission denied
du: cannot read directory '/proc/97/map_files': Permission denied
du: cannot read directory '/proc/97/fdinfo': Permission denied
du: cannot read directory '/proc/97/ns': Permission denied
du: cannot read directory '/proc/98/task/98/fd': Permission denied
du: cannot read directory '/proc/98/task/98/fdinfo': Permission denied
du: cannot read directory '/proc/98/task/98/ns': Permission denied
du: cannot read directory '/proc/98/fd': Permission denied
du: cannot read directory '/proc/98/map_files': Permission denied
du: cannot read directory '/proc/98/fdinfo': Permission denied
du: cannot read directory '/proc/98/ns': Permission denied
du: cannot read directory '/proc/99/task/99/fd': Permission denied
du: cannot read directory '/proc/99/task/99/fdinfo': Permission denied
du: cannot read directory '/proc/99/task/99/ns': Permission denied
du: cannot read directory '/proc/99/fd': Permission denied
du: cannot read directory '/proc/99/map_files': Permission denied
du: cannot read directory '/proc/99/fdinfo': Permission denied
du: cannot read directory '/proc/99/ns': Permission denied
du: cannot read directory '/proc/100/task/100/fd': Permission denied
du: cannot read directory '/proc/100/task/100/fdinfo': Permission denied
du: cannot read directory '/proc/100/task/100/ns': Permission denied
du: cannot read directory '/proc/100/fd': Permission denied
du: cannot read directory '/proc/100/map_files': Permission denied
du: cannot read directory '/proc/100/fdinfo': Permission denied
du: cannot read directory '/proc/100/ns': Permission denied
du: cannot read directory '/proc/101/task/101/fd': Permission denied
du: cannot read directory '/proc/101/task/101/fdinfo': Permission denied
du: cannot read directory '/proc/101/task/101/ns': Permission denied
du: cannot read directory '/proc/101/fd': Permission denied
du: cannot read directory '/proc/101/map_files': Permission denied
du: cannot read directory '/proc/101/fdinfo': Permission denied
du: cannot read directory '/proc/101/ns': Permission denied
du: cannot read directory '/proc/107/task/107/fd': Permission denied
du: cannot read directory '/proc/107/task/107/fdinfo': Permission denied
du: cannot read directory '/proc/107/task/107/ns': Permission denied
du: cannot read directory '/proc/107/fd': Permission denied
du: cannot read directory '/proc/107/map_files': Permission denied
du: cannot read directory '/proc/107/fdinfo': Permission denied
du: cannot read directory '/proc/107/ns': Permission denied
du: cannot read directory '/proc/108/task/108/fd': Permission denied
du: cannot read directory '/proc/108/task/108/fdinfo': Permission denied
du: cannot read directory '/proc/108/task/108/ns': Permission denied
du: cannot read directory '/proc/108/fd': Permission denied
du: cannot read directory '/proc/108/map_files': Permission denied
du: cannot read directory '/proc/108/fdinfo': Permission denied
du: cannot read directory '/proc/108/ns': Permission denied
du: cannot read directory '/proc/109/task/109/fd': Permission denied
du: cannot read directory '/proc/109/task/109/fdinfo': Permission denied
du: cannot read directory '/proc/109/task/109/ns': Permission denied
du: cannot read directory '/proc/109/fd': Permission denied
du: cannot read directory '/proc/109/map_files': Permission denied
du: cannot read directory '/proc/109/fdinfo': Permission denied
du: cannot read directory '/proc/109/ns': Permission denied
du: cannot read directory '/proc/110/task/110/fd': Permission denied
du: cannot read directory '/proc/110/task/110/fdinfo': Permission denied
du: cannot read directory '/proc/110/task/110/ns': Permission denied
du: cannot read directory '/proc/110/fd': Permission denied
du: cannot read directory '/proc/110/map_files': Permission denied
du: cannot read directory '/proc/110/fdinfo': Permission denied
du: cannot read directory '/proc/110/ns': Permission denied
du: cannot read directory '/proc/111/task/111/fd': Permission denied
du: cannot read directory '/proc/111/task/111/fdinfo': Permission denied
du: cannot read directory '/proc/111/task/111/ns': Permission denied
du: cannot read directory '/proc/111/fd': Permission denied
du: cannot read directory '/proc/111/map_files': Permission denied
du: cannot read directory '/proc/111/fdinfo': Permission denied
du: cannot read directory '/proc/111/ns': Permission denied
du: cannot read directory '/proc/119/task/119/fd': Permission denied
du: cannot read directory '/proc/119/task/119/fdinfo': Permission denied
du: cannot read directory '/proc/119/task/119/ns': Permission denied
du: cannot read directory '/proc/119/fd': Permission denied
du: cannot read directory '/proc/119/map_files': Permission denied
du: cannot read directory '/proc/119/fdinfo': Permission denied
du: cannot read directory '/proc/119/ns': Permission denied
du: cannot read directory '/proc/121/task/121/fd': Permission denied
du: cannot read directory '/proc/121/task/121/fdinfo': Permission denied
du: cannot read directory '/proc/121/task/121/ns': Permission denied
du: cannot read directory '/proc/121/fd': Permission denied
du: cannot read directory '/proc/121/map_files': Permission denied
du: cannot read directory '/proc/121/fdinfo': Permission denied
du: cannot read directory '/proc/121/ns': Permission denied
du: cannot read directory '/proc/122/task/122/fd': Permission denied
du: cannot read directory '/proc/122/task/122/fdinfo': Permission denied
du: cannot read directory '/proc/122/task/122/ns': Permission denied
du: cannot read directory '/proc/122/fd': Permission denied
du: cannot read directory '/proc/122/map_files': Permission denied
du: cannot read directory '/proc/122/fdinfo': Permission denied
du: cannot read directory '/proc/122/ns': Permission denied
du: cannot read directory '/proc/123/task/123/fd': Permission denied
du: cannot read directory '/proc/123/task/123/fdinfo': Permission denied
du: cannot read directory '/proc/123/task/123/ns': Permission denied
du: cannot read directory '/proc/123/fd': Permission denied
du: cannot read directory '/proc/123/map_files': Permission denied
du: cannot read directory '/proc/123/fdinfo': Permission denied
du: cannot read directory '/proc/123/ns': Permission denied
du: cannot read directory '/proc/125/task/125/fd': Permission denied
du: cannot read directory '/proc/125/task/125/fdinfo': Permission denied
du: cannot read directory '/proc/125/task/125/ns': Permission denied
du: cannot read directory '/proc/125/fd': Permission denied
du: cannot read directory '/proc/125/map_files': Permission denied
du: cannot read directory '/proc/125/fdinfo': Permission denied
du: cannot read directory '/proc/125/ns': Permission denied
du: cannot read directory '/proc/139/task/139/fd': Permission denied
du: cannot read directory '/proc/139/task/139/fdinfo': Permission denied
du: cannot read directory '/proc/139/task/139/ns': Permission denied
du: cannot read directory '/proc/139/fd': Permission denied
du: cannot read directory '/proc/139/map_files': Permission denied
du: cannot read directory '/proc/139/fdinfo': Permission denied
du: cannot read directory '/proc/139/ns': Permission denied
du: cannot read directory '/proc/140/task/140/fd': Permission denied
du: cannot read directory '/proc/140/task/140/fdinfo': Permission denied
du: cannot read directory '/proc/140/task/140/ns': Permission denied
du: cannot read directory '/proc/140/fd': Permission denied
du: cannot read directory '/proc/140/map_files': Permission denied
du: cannot read directory '/proc/140/fdinfo': Permission denied
du: cannot read directory '/proc/140/ns': Permission denied
du: cannot read directory '/proc/175/task/175/fd': Permission denied
du: cannot read directory '/proc/175/task/175/fdinfo': Permission denied
du: cannot read directory '/proc/175/task/175/ns': Permission denied
du: cannot read directory '/proc/175/fd': Permission denied
du: cannot read directory '/proc/175/map_files': Permission denied
du: cannot read directory '/proc/175/fdinfo': Permission denied
du: cannot read directory '/proc/175/ns': Permission denied
du: cannot read directory '/proc/315/task/315/fd': Permission denied
du: cannot read directory '/proc/315/task/315/fdinfo': Permission denied
du: cannot read directory '/proc/315/task/315/ns': Permission denied
du: cannot read directory '/proc/315/fd': Permission denied
du: cannot read directory '/proc/315/map_files': Permission denied
du: cannot read directory '/proc/315/fdinfo': Permission denied
du: cannot read directory '/proc/315/ns': Permission denied
du: cannot read directory '/proc/373/task/373/fd': Permission denied
du: cannot read directory '/proc/373/task/373/fdinfo': Permission denied
du: cannot read directory '/proc/373/task/373/ns': Permission denied
du: cannot read directory '/proc/373/fd': Permission denied
du: cannot read directory '/proc/373/map_files': Permission denied
du: cannot read directory '/proc/373/fdinfo': Permission denied
du: cannot read directory '/proc/373/ns': Permission denied
du: cannot read directory '/proc/393/task/393/fd': Permission denied
du: cannot read directory '/proc/393/task/393/fdinfo': Permission denied
du: cannot read directory '/proc/393/task/393/ns': Permission denied
du: cannot read directory '/proc/393/fd': Permission denied
du: cannot read directory '/proc/393/map_files': Permission denied
du: cannot read directory '/proc/393/fdinfo': Permission denied
du: cannot read directory '/proc/393/ns': Permission denied
du: cannot read directory '/proc/394/task/394/fd': Permission denied
du: cannot read directory '/proc/394/task/394/fdinfo': Permission denied
du: cannot read directory '/proc/394/task/394/ns': Permission denied
du: cannot read directory '/proc/394/fd': Permission denied
du: cannot read directory '/proc/394/map_files': Permission denied
du: cannot read directory '/proc/394/fdinfo': Permission denied
du: cannot read directory '/proc/394/ns': Permission denied
du: cannot read directory '/proc/395/task/395/fd': Permission denied
du: cannot read directory '/proc/395/task/395/fdinfo': Permission denied
du: cannot read directory '/proc/395/task/395/ns': Permission denied
du: cannot read directory '/proc/395/fd': Permission denied
du: cannot read directory '/proc/395/map_files': Permission denied
du: cannot read directory '/proc/395/fdinfo': Permission denied
du: cannot read directory '/proc/395/ns': Permission denied
du: cannot read directory '/proc/396/task/396/fd': Permission denied
du: cannot read directory '/proc/396/task/396/fdinfo': Permission denied
du: cannot read directory '/proc/396/task/396/ns': Permission denied
du: cannot read directory '/proc/396/fd': Permission denied
du: cannot read directory '/proc/396/map_files': Permission denied
du: cannot read directory '/proc/396/fdinfo': Permission denied
du: cannot read directory '/proc/396/ns': Permission denied
du: cannot read directory '/proc/397/task/397/fd': Permission denied
du: cannot read directory '/proc/397/task/397/fdinfo': Permission denied
du: cannot read directory '/proc/397/task/397/ns': Permission denied
du: cannot read directory '/proc/397/fd': Permission denied
du: cannot read directory '/proc/397/map_files': Permission denied
du: cannot read directory '/proc/397/fdinfo': Permission denied
du: cannot read directory '/proc/397/ns': Permission denied
du: cannot read directory '/proc/399/task/399/fd': Permission denied
du: cannot read directory '/proc/399/task/399/fdinfo': Permission denied
du: cannot read directory '/proc/399/task/399/ns': Permission denied
du: cannot read directory '/proc/399/fd': Permission denied
du: cannot read directory '/proc/399/map_files': Permission denied
du: cannot read directory '/proc/399/fdinfo': Permission denied
du: cannot read directory '/proc/399/ns': Permission denied
du: cannot read directory '/proc/400/task/400/fd': Permission denied
du: cannot read directory '/proc/400/task/400/fdinfo': Permission denied
du: cannot read directory '/proc/400/task/400/ns': Permission denied
du: cannot read directory '/proc/400/fd': Permission denied
du: cannot read directory '/proc/400/map_files': Permission denied
du: cannot read directory '/proc/400/fdinfo': Permission denied
du: cannot read directory '/proc/400/ns': Permission denied
du: cannot read directory '/proc/406/task/406/fd': Permission denied
du: cannot read directory '/proc/406/task/406/fdinfo': Permission denied
du: cannot read directory '/proc/406/task/406/ns': Permission denied
du: cannot read directory '/proc/406/fd': Permission denied
du: cannot read directory '/proc/406/map_files': Permission denied
du: cannot read directory '/proc/406/fdinfo': Permission denied
du: cannot read directory '/proc/406/ns': Permission denied
du: cannot read directory '/proc/407/task/407/fd': Permission denied
du: cannot read directory '/proc/407/task/407/fdinfo': Permission denied
du: cannot read directory '/proc/407/task/407/ns': Permission denied
du: cannot read directory '/proc/407/fd': Permission denied
du: cannot read directory '/proc/407/map_files': Permission denied
du: cannot read directory '/proc/407/fdinfo': Permission denied
du: cannot read directory '/proc/407/ns': Permission denied
du: cannot read directory '/proc/408/task/408/fd': Permission denied
du: cannot read directory '/proc/408/task/408/fdinfo': Permission denied
du: cannot read directory '/proc/408/task/408/ns': Permission denied
du: cannot read directory '/proc/408/fd': Permission denied
du: cannot read directory '/proc/408/map_files': Permission denied
du: cannot read directory '/proc/408/fdinfo': Permission denied
du: cannot read directory '/proc/408/ns': Permission denied
du: cannot read directory '/proc/409/task/409/fd': Permission denied
du: cannot read directory '/proc/409/task/409/fdinfo': Permission denied
du: cannot read directory '/proc/409/task/409/ns': Permission denied
du: cannot read directory '/proc/409/fd': Permission denied
du: cannot read directory '/proc/409/map_files': Permission denied
du: cannot read directory '/proc/409/fdinfo': Permission denied
du: cannot read directory '/proc/409/ns': Permission denied
du: cannot read directory '/proc/472/task/472/fd': Permission denied
du: cannot read directory '/proc/472/task/472/fdinfo': Permission denied
du: cannot read directory '/proc/472/task/472/ns': Permission denied
du: cannot read directory '/proc/472/fd': Permission denied
du: cannot read directory '/proc/472/map_files': Permission denied
du: cannot read directory '/proc/472/fdinfo': Permission denied
du: cannot read directory '/proc/472/ns': Permission denied
du: cannot read directory '/proc/519/task/519/fd': Permission denied
du: cannot read directory '/proc/519/task/519/fdinfo': Permission denied
du: cannot read directory '/proc/519/task/519/ns': Permission denied
du: cannot read directory '/proc/519/fd': Permission denied
du: cannot read directory '/proc/519/map_files': Permission denied
du: cannot read directory '/proc/519/fdinfo': Permission denied
du: cannot read directory '/proc/519/ns': Permission denied
du: cannot read directory '/proc/520/task/520/fd': Permission denied
du: cannot read directory '/proc/520/task/520/fdinfo': Permission denied
du: cannot read directory '/proc/520/task/520/ns': Permission denied
du: cannot read directory '/proc/520/fd': Permission denied
du: cannot read directory '/proc/520/map_files': Permission denied
du: cannot read directory '/proc/520/fdinfo': Permission denied
du: cannot read directory '/proc/520/ns': Permission denied
du: cannot read directory '/proc/530/task/530/fd': Permission denied
du: cannot read directory '/proc/530/task/530/fdinfo': Permission denied
du: cannot read directory '/proc/530/task/530/ns': Permission denied
du: cannot read directory '/proc/530/fd': Permission denied
du: cannot read directory '/proc/530/map_files': Permission denied
du: cannot read directory '/proc/530/fdinfo': Permission denied
du: cannot read directory '/proc/530/ns': Permission denied
du: cannot read directory '/proc/531/task/531/fd': Permission denied
du: cannot read directory '/proc/531/task/531/fdinfo': Permission denied
du: cannot read directory '/proc/531/task/531/ns': Permission denied
du: cannot read directory '/proc/531/fd': Permission denied
du: cannot read directory '/proc/531/map_files': Permission denied
du: cannot read directory '/proc/531/fdinfo': Permission denied
du: cannot read directory '/proc/531/ns': Permission denied
du: cannot read directory '/proc/538/task/538/fd': Permission denied
du: cannot read directory '/proc/538/task/538/fdinfo': Permission denied
du: cannot read directory '/proc/538/task/538/ns': Permission denied
du: cannot read directory '/proc/538/fd': Permission denied
du: cannot read directory '/proc/538/map_files': Permission denied
du: cannot read directory '/proc/538/fdinfo': Permission denied
du: cannot read directory '/proc/538/ns': Permission denied
du: cannot read directory '/proc/539/task/539/fd': Permission denied
du: cannot read directory '/proc/539/task/539/fdinfo': Permission denied
du: cannot read directory '/proc/539/task/539/ns': Permission denied
du: cannot read directory '/proc/539/fd': Permission denied
du: cannot read directory '/proc/539/map_files': Permission denied
du: cannot read directory '/proc/539/fdinfo': Permission denied
du: cannot read directory '/proc/539/ns': Permission denied
du: cannot read directory '/proc/556/task/556/fd': Permission denied
du: cannot read directory '/proc/556/task/556/fdinfo': Permission denied
du: cannot read directory '/proc/556/task/556/ns': Permission denied
du: cannot read directory '/proc/556/fd': Permission denied
du: cannot read directory '/proc/556/map_files': Permission denied
du: cannot read directory '/proc/556/fdinfo': Permission denied
du: cannot read directory '/proc/556/ns': Permission denied
du: cannot read directory '/proc/557/task/557/fd': Permission denied
du: cannot read directory '/proc/557/task/557/fdinfo': Permission denied
du: cannot read directory '/proc/557/task/557/ns': Permission denied
du: cannot read directory '/proc/557/fd': Permission denied
du: cannot read directory '/proc/557/map_files': Permission denied
du: cannot read directory '/proc/557/fdinfo': Permission denied
du: cannot read directory '/proc/557/ns': Permission denied
du: cannot read directory '/proc/583/task/583/fd': Permission denied
du: cannot read directory '/proc/583/task/583/fdinfo': Permission denied
du: cannot read directory '/proc/583/task/583/ns': Permission denied
du: cannot read directory '/proc/583/fd': Permission denied
du: cannot read directory '/proc/583/map_files': Permission denied
du: cannot read directory '/proc/583/fdinfo': Permission denied
du: cannot read directory '/proc/583/ns': Permission denied
du: cannot read directory '/proc/584/task/584/fd': Permission denied
du: cannot read directory '/proc/584/task/584/fdinfo': Permission denied
du: cannot read directory '/proc/584/task/584/ns': Permission denied
du: cannot read directory '/proc/584/fd': Permission denied
du: cannot read directory '/proc/584/map_files': Permission denied
du: cannot read directory '/proc/584/fdinfo': Permission denied
du: cannot read directory '/proc/584/ns': Permission denied
du: cannot read directory '/proc/589/task/589/fd': Permission denied
du: cannot read directory '/proc/589/task/589/fdinfo': Permission denied
du: cannot read directory '/proc/589/task/589/ns': Permission denied
du: cannot read directory '/proc/589/fd': Permission denied
du: cannot read directory '/proc/589/map_files': Permission denied
du: cannot read directory '/proc/589/fdinfo': Permission denied
du: cannot read directory '/proc/589/ns': Permission denied
du: cannot read directory '/proc/590/task/590/fd': Permission denied
du: cannot read directory '/proc/590/task/590/fdinfo': Permission denied
du: cannot read directory '/proc/590/task/590/ns': Permission denied
du: cannot read directory '/proc/590/fd': Permission denied
du: cannot read directory '/proc/590/map_files': Permission denied
du: cannot read directory '/proc/590/fdinfo': Permission denied
du: cannot read directory '/proc/590/ns': Permission denied
du: cannot read directory '/proc/650/task/650/fd': Permission denied
du: cannot read directory '/proc/650/task/650/fdinfo': Permission denied
du: cannot read directory '/proc/650/task/650/ns': Permission denied
du: cannot read directory '/proc/650/fd': Permission denied
du: cannot read directory '/proc/650/map_files': Permission denied
du: cannot read directory '/proc/650/fdinfo': Permission denied
du: cannot read directory '/proc/650/ns': Permission denied
du: cannot read directory '/proc/678/task/678/fd': Permission denied
du: cannot read directory '/proc/678/task/678/fdinfo': Permission denied
du: cannot read directory '/proc/678/task/678/ns': Permission denied
du: cannot read directory '/proc/678/fd': Permission denied
du: cannot read directory '/proc/678/map_files': Permission denied
du: cannot read directory '/proc/678/fdinfo': Permission denied
du: cannot read directory '/proc/678/ns': Permission denied
du: cannot read directory '/proc/686/task/686/fd': Permission denied
du: cannot read directory '/proc/686/task/686/fdinfo': Permission denied
du: cannot read directory '/proc/686/task/686/ns': Permission denied
du: cannot read directory '/proc/686/fd': Permission denied
du: cannot read directory '/proc/686/map_files': Permission denied
du: cannot read directory '/proc/686/fdinfo': Permission denied
du: cannot read directory '/proc/686/ns': Permission denied
du: cannot read directory '/proc/1827/task/1827/fd': Permission denied
du: cannot read directory '/proc/1827/task/1827/fdinfo': Permission denied
du: cannot read directory '/proc/1827/task/1827/ns': Permission denied
du: cannot read directory '/proc/1827/fd': Permission denied
du: cannot read directory '/proc/1827/map_files': Permission denied
du: cannot read directory '/proc/1827/fdinfo': Permission denied
du: cannot read directory '/proc/1827/ns': Permission denied
du: cannot read directory '/proc/1847/task/1847/fd': Permission denied
du: cannot read directory '/proc/1847/task/1847/fdinfo': Permission denied
du: cannot read directory '/proc/1847/task/1847/ns': Permission denied
du: cannot read directory '/proc/1847/fd': Permission denied
du: cannot read directory '/proc/1847/map_files': Permission denied
du: cannot read directory '/proc/1847/fdinfo': Permission denied
du: cannot read directory '/proc/1847/ns': Permission denied
du: cannot read directory '/proc/1858/task/1858/fd': Permission denied
du: cannot read directory '/proc/1858/task/1858/fdinfo': Permission denied
du: cannot read directory '/proc/1858/task/1858/ns': Permission denied
du: cannot read directory '/proc/1858/fd': Permission denied
du: cannot read directory '/proc/1858/map_files': Permission denied
du: cannot read directory '/proc/1858/fdinfo': Permission denied
du: cannot read directory '/proc/1858/ns': Permission denied
du: cannot read directory '/proc/1966/task/1966/fd': Permission denied
du: cannot read directory '/proc/1966/task/1966/fdinfo': Permission denied
du: cannot read directory '/proc/1966/task/1966/ns': Permission denied
du: cannot read directory '/proc/1966/fd': Permission denied
du: cannot read directory '/proc/1966/map_files': Permission denied
du: cannot read directory '/proc/1966/fdinfo': Permission denied
du: cannot read directory '/proc/1966/ns': Permission denied
du: cannot read directory '/proc/1971/task/1971/fd': Permission denied
du: cannot read directory '/proc/1971/task/1971/fdinfo': Permission denied
du: cannot read directory '/proc/1971/task/1971/ns': Permission denied
du: cannot read directory '/proc/1971/fd': Permission denied
du: cannot read directory '/proc/1971/map_files': Permission denied
du: cannot read directory '/proc/1971/fdinfo': Permission denied
du: cannot read directory '/proc/1971/ns': Permission denied
du: cannot read directory '/proc/1972/task/1972/fd': Permission denied
du: cannot read directory '/proc/1972/task/1972/fdinfo': Permission denied
du: cannot read directory '/proc/1972/task/1972/ns': Permission denied
du: cannot read directory '/proc/1972/fd': Permission denied
du: cannot read directory '/proc/1972/map_files': Permission denied
du: cannot read directory '/proc/1972/fdinfo': Permission denied
du: cannot read directory '/proc/1972/ns': Permission denied
du: cannot read directory '/proc/2233/task/2233/fd': Permission denied
du: cannot read directory '/proc/2233/task/2233/fdinfo': Permission denied
du: cannot read directory '/proc/2233/task/2233/ns': Permission denied
du: cannot read directory '/proc/2233/fd': Permission denied
du: cannot read directory '/proc/2233/map_files': Permission denied
du: cannot read directory '/proc/2233/fdinfo': Permission denied
du: cannot read directory '/proc/2233/ns': Permission denied
du: cannot read directory '/proc/2387/task/2387/fd': Permission denied
du: cannot read directory '/proc/2387/task/2387/fdinfo': Permission denied
du: cannot read directory '/proc/2387/task/2387/ns': Permission denied
du: cannot read directory '/proc/2387/fd': Permission denied
du: cannot read directory '/proc/2387/map_files': Permission denied
du: cannot read directory '/proc/2387/fdinfo': Permission denied
du: cannot read directory '/proc/2387/ns': Permission denied
du: cannot read directory '/proc/2730/task/2730/fd': Permission denied
du: cannot read directory '/proc/2730/task/2730/fdinfo': Permission denied
du: cannot read directory '/proc/2730/task/2730/ns': Permission denied
du: cannot read directory '/proc/2730/fd': Permission denied
du: cannot read directory '/proc/2730/map_files': Permission denied
du: cannot read directory '/proc/2730/fdinfo': Permission denied
du: cannot read directory '/proc/2730/ns': Permission denied
du: cannot read directory '/proc/2732/task/2732/fd': Permission denied
du: cannot read directory '/proc/2732/task/2732/fdinfo': Permission denied
du: cannot read directory '/proc/2732/task/2732/ns': Permission denied
du: cannot read directory '/proc/2732/fd': Permission denied
du: cannot read directory '/proc/2732/map_files': Permission denied
du: cannot read directory '/proc/2732/fdinfo': Permission denied
du: cannot read directory '/proc/2732/ns': Permission denied
du: cannot read directory '/proc/3215/task/3215/fd': Permission denied
du: cannot read directory '/proc/3215/task/3215/fdinfo': Permission denied
du: cannot read directory '/proc/3215/task/3215/ns': Permission denied
du: cannot read directory '/proc/3215/fd': Permission denied
du: cannot read directory '/proc/3215/map_files': Permission denied
du: cannot read directory '/proc/3215/fdinfo': Permission denied
du: cannot read directory '/proc/3215/ns': Permission denied
du: cannot read directory '/proc/3216/task/3216/fd': Permission denied
du: cannot read directory '/proc/3216/task/3216/fdinfo': Permission denied
du: cannot read directory '/proc/3216/task/3216/ns': Permission denied
du: cannot read directory '/proc/3216/fd': Permission denied
du: cannot read directory '/proc/3216/map_files': Permission denied
du: cannot read directory '/proc/3216/fdinfo': Permission denied
du: cannot read directory '/proc/3216/ns': Permission denied
du: cannot read directory '/proc/3220/task/3220/fd': Permission denied
du: cannot read directory '/proc/3220/task/3220/fdinfo': Permission denied
du: cannot read directory '/proc/3220/task/3220/ns': Permission denied
du: cannot read directory '/proc/3220/fd': Permission denied
du: cannot read directory '/proc/3220/map_files': Permission denied
du: cannot read directory '/proc/3220/fdinfo': Permission denied
du: cannot read directory '/proc/3220/ns': Permission denied
du: cannot read directory '/proc/3221/task/3221/fd': Permission denied
du: cannot read directory '/proc/3221/task/3221/fdinfo': Permission denied
du: cannot read directory '/proc/3221/task/3221/ns': Permission denied
du: cannot read directory '/proc/3221/fd': Permission denied
du: cannot read directory '/proc/3221/map_files': Permission denied
du: cannot read directory '/proc/3221/fdinfo': Permission denied
du: cannot read directory '/proc/3221/ns': Permission denied
du: cannot read directory '/proc/3224/task/3224/fd': Permission denied
du: cannot read directory '/proc/3224/task/3224/fdinfo': Permission denied
du: cannot read directory '/proc/3224/task/3224/ns': Permission denied
du: cannot read directory '/proc/3224/fd': Permission denied
du: cannot read directory '/proc/3224/map_files': Permission denied
du: cannot read directory '/proc/3224/fdinfo': Permission denied
du: cannot read directory '/proc/3224/ns': Permission denied
du: cannot read directory '/proc/3226/task/3226/fd': Permission denied
du: cannot read directory '/proc/3226/task/3226/fdinfo': Permission denied
du: cannot read directory '/proc/3226/task/3226/ns': Permission denied
du: cannot read directory '/proc/3226/fd': Permission denied
du: cannot read directory '/proc/3226/map_files': Permission denied
du: cannot read directory '/proc/3226/fdinfo': Permission denied
du: cannot read directory '/proc/3226/ns': Permission denied
du: cannot read directory '/proc/3230/task/3230/fd': Permission denied
du: cannot read directory '/proc/3230/task/3230/fdinfo': Permission denied
du: cannot read directory '/proc/3230/task/3230/ns': Permission denied
du: cannot read directory '/proc/3230/fd': Permission denied
du: cannot read directory '/proc/3230/map_files': Permission denied
du: cannot read directory '/proc/3230/fdinfo': Permission denied
du: cannot read directory '/proc/3230/ns': Permission denied
du: cannot read directory '/proc/3232/task/3232/fd': Permission denied
du: cannot read directory '/proc/3232/task/3232/fdinfo': Permission denied
du: cannot read directory '/proc/3232/task/3232/ns': Permission denied
du: cannot read directory '/proc/3232/fd': Permission denied
du: cannot read directory '/proc/3232/map_files': Permission denied
du: cannot read directory '/proc/3232/fdinfo': Permission denied
du: cannot read directory '/proc/3232/ns': Permission denied
du: cannot read directory '/proc/3234/task/3234/fd': Permission denied
du: cannot read directory '/proc/3234/task/3234/fdinfo': Permission denied
du: cannot read directory '/proc/3234/task/3234/ns': Permission denied
du: cannot read directory '/proc/3234/fd': Permission denied
du: cannot read directory '/proc/3234/map_files': Permission denied
du: cannot read directory '/proc/3234/fdinfo': Permission denied
du: cannot read directory '/proc/3234/ns': Permission denied
du: cannot read directory '/proc/3236/task/3236/fd': Permission denied
du: cannot read directory '/proc/3236/task/3236/fdinfo': Permission denied
du: cannot read directory '/proc/3236/task/3236/ns': Permission denied
du: cannot read directory '/proc/3236/fd': Permission denied
du: cannot read directory '/proc/3236/map_files': Permission denied
du: cannot read directory '/proc/3236/fdinfo': Permission denied
du: cannot read directory '/proc/3236/ns': Permission denied
du: cannot read directory '/proc/3241/task/3241/fd': Permission denied
du: cannot read directory '/proc/3241/task/3241/fdinfo': Permission denied
du: cannot read directory '/proc/3241/task/3241/ns': Permission denied
du: cannot read directory '/proc/3241/fd': Permission denied
du: cannot read directory '/proc/3241/map_files': Permission denied
du: cannot read directory '/proc/3241/fdinfo': Permission denied
du: cannot read directory '/proc/3241/ns': Permission denied
du: cannot read directory '/proc/3244/task/3244/fd': Permission denied
du: cannot read directory '/proc/3244/task/3244/fdinfo': Permission denied
du: cannot read directory '/proc/3244/task/3244/ns': Permission denied
du: cannot read directory '/proc/3244/fd': Permission denied
du: cannot read directory '/proc/3244/map_files': Permission denied
du: cannot read directory '/proc/3244/fdinfo': Permission denied
du: cannot read directory '/proc/3244/ns': Permission denied
du: cannot read directory '/proc/3247/task/3247/fd': Permission denied
du: cannot read directory '/proc/3247/task/3247/fdinfo': Permission denied
du: cannot read directory '/proc/3247/task/3247/ns': Permission denied
du: cannot read directory '/proc/3247/fd': Permission denied
du: cannot read directory '/proc/3247/map_files': Permission denied
du: cannot read directory '/proc/3247/fdinfo': Permission denied
du: cannot read directory '/proc/3247/ns': Permission denied
du: cannot read directory '/proc/3249/task/3249/fd': Permission denied
du: cannot read directory '/proc/3249/task/3249/fdinfo': Permission denied
du: cannot read directory '/proc/3249/task/3249/ns': Permission denied
du: cannot read directory '/proc/3249/fd': Permission denied
du: cannot read directory '/proc/3249/map_files': Permission denied
du: cannot read directory '/proc/3249/fdinfo': Permission denied
du: cannot read directory '/proc/3249/ns': Permission denied
du: cannot read directory '/proc/3254/task/3254/fd': Permission denied
du: cannot read directory '/proc/3254/task/3254/fdinfo': Permission denied
du: cannot read directory '/proc/3254/task/3254/ns': Permission denied
du: cannot read directory '/proc/3254/fd': Permission denied
du: cannot read directory '/proc/3254/map_files': Permission denied
du: cannot read directory '/proc/3254/fdinfo': Permission denied
du: cannot read directory '/proc/3254/ns': Permission denied
du: cannot read directory '/proc/3256/task/3256/fd': Permission denied
du: cannot read directory '/proc/3256/task/3256/fdinfo': Permission denied
du: cannot read directory '/proc/3256/task/3256/ns': Permission denied
du: cannot read directory '/proc/3256/fd': Permission denied
du: cannot read directory '/proc/3256/map_files': Permission denied
du: cannot read directory '/proc/3256/fdinfo': Permission denied
du: cannot read directory '/proc/3256/ns': Permission denied
du: cannot read directory '/proc/3260/task/3260/fd': Permission denied
du: cannot read directory '/proc/3260/task/3260/fdinfo': Permission denied
du: cannot read directory '/proc/3260/task/3260/ns': Permission denied
du: cannot read directory '/proc/3260/fd': Permission denied
du: cannot read directory '/proc/3260/map_files': Permission denied
du: cannot read directory '/proc/3260/fdinfo': Permission denied
du: cannot read directory '/proc/3260/ns': Permission denied
du: cannot read directory '/proc/3267/task/3267/fd': Permission denied
du: cannot read directory '/proc/3267/task/3267/fdinfo': Permission denied
du: cannot read directory '/proc/3267/task/3267/ns': Permission denied
du: cannot read directory '/proc/3267/fd': Permission denied
du: cannot read directory '/proc/3267/map_files': Permission denied
du: cannot read directory '/proc/3267/fdinfo': Permission denied
du: cannot read directory '/proc/3267/ns': Permission denied
du: cannot read directory '/proc/3272/task/3272/fd': Permission denied
du: cannot read directory '/proc/3272/task/3272/fdinfo': Permission denied
du: cannot read directory '/proc/3272/task/3272/ns': Permission denied
du: cannot read directory '/proc/3272/fd': Permission denied
du: cannot read directory '/proc/3272/map_files': Permission denied
du: cannot read directory '/proc/3272/fdinfo': Permission denied
du: cannot read directory '/proc/3272/ns': Permission denied
du: cannot read directory '/proc/3275/task/3275/fd': Permission denied
du: cannot read directory '/proc/3275/task/3275/fdinfo': Permission denied
du: cannot read directory '/proc/3275/task/3275/ns': Permission denied
du: cannot read directory '/proc/3275/fd': Permission denied
du: cannot read directory '/proc/3275/map_files': Permission denied
du: cannot read directory '/proc/3275/fdinfo': Permission denied
du: cannot read directory '/proc/3275/ns': Permission denied
du: cannot read directory '/proc/3330/task/3330/fd': Permission denied
du: cannot read directory '/proc/3330/task/3330/fdinfo': Permission denied
du: cannot read directory '/proc/3330/task/3330/ns': Permission denied
du: cannot read directory '/proc/3330/fd': Permission denied
du: cannot read directory '/proc/3330/map_files': Permission denied
du: cannot read directory '/proc/3330/fdinfo': Permission denied
du: cannot read directory '/proc/3330/ns': Permission denied
du: cannot read directory '/proc/3331/task/3331/fd': Permission denied
du: cannot read directory '/proc/3331/task/3331/fdinfo': Permission denied
du: cannot read directory '/proc/3331/task/3331/ns': Permission denied
du: cannot read directory '/proc/3331/fd': Permission denied
du: cannot read directory '/proc/3331/map_files': Permission denied
du: cannot read directory '/proc/3331/fdinfo': Permission denied
du: cannot read directory '/proc/3331/ns': Permission denied
du: cannot read directory '/proc/3333/task/3333/fd': Permission denied
du: cannot read directory '/proc/3333/task/3333/fdinfo': Permission denied
du: cannot read directory '/proc/3333/task/3333/ns': Permission denied
du: cannot read directory '/proc/3333/fd': Permission denied
du: cannot read directory '/proc/3333/map_files': Permission denied
du: cannot read directory '/proc/3333/fdinfo': Permission denied
du: cannot read directory '/proc/3333/ns': Permission denied
du: cannot read directory '/proc/3334/task/3334/fd': Permission denied
du: cannot read directory '/proc/3334/task/3334/fdinfo': Permission denied
du: cannot read directory '/proc/3334/task/3334/ns': Permission denied
du: cannot read directory '/proc/3334/fd': Permission denied
du: cannot read directory '/proc/3334/map_files': Permission denied
du: cannot read directory '/proc/3334/fdinfo': Permission denied
du: cannot read directory '/proc/3334/ns': Permission denied
du: cannot read directory '/proc/3339/task/3339/fd': Permission denied
du: cannot read directory '/proc/3339/task/3339/fdinfo': Permission denied
du: cannot read directory '/proc/3339/task/3339/ns': Permission denied
du: cannot read directory '/proc/3339/fd': Permission denied
du: cannot read directory '/proc/3339/map_files': Permission denied
du: cannot read directory '/proc/3339/fdinfo': Permission denied
du: cannot read directory '/proc/3339/ns': Permission denied
du: cannot read directory '/proc/3340/task/3340/fd': Permission denied
du: cannot read directory '/proc/3340/task/3340/fdinfo': Permission denied
du: cannot read directory '/proc/3340/task/3340/ns': Permission denied
du: cannot read directory '/proc/3340/fd': Permission denied
du: cannot read directory '/proc/3340/map_files': Permission denied
du: cannot read directory '/proc/3340/fdinfo': Permission denied
du: cannot read directory '/proc/3340/ns': Permission denied
du: cannot read directory '/proc/3347/task/3347/fd': Permission denied
du: cannot read directory '/proc/3347/task/3347/fdinfo': Permission denied
du: cannot read directory '/proc/3347/task/3347/ns': Permission denied
du: cannot read directory '/proc/3347/fd': Permission denied
du: cannot read directory '/proc/3347/map_files': Permission denied
du: cannot read directory '/proc/3347/fdinfo': Permission denied
du: cannot read directory '/proc/3347/ns': Permission denied
du: cannot read directory '/proc/3348/task/3348/fd': Permission denied
du: cannot read directory '/proc/3348/task/3348/fdinfo': Permission denied
du: cannot read directory '/proc/3348/task/3348/ns': Permission denied
du: cannot read directory '/proc/3348/fd': Permission denied
du: cannot read directory '/proc/3348/map_files': Permission denied
du: cannot read directory '/proc/3348/fdinfo': Permission denied
du: cannot read directory '/proc/3348/ns': Permission denied
du: cannot read directory '/proc/3350/task/3350/fd': Permission denied
du: cannot read directory '/proc/3350/task/3350/fdinfo': Permission denied
du: cannot read directory '/proc/3350/task/3350/ns': Permission denied
du: cannot read directory '/proc/3350/fd': Permission denied
du: cannot read directory '/proc/3350/map_files': Permission denied
du: cannot read directory '/proc/3350/fdinfo': Permission denied
du: cannot read directory '/proc/3350/ns': Permission denied
du: cannot read directory '/proc/3351/task/3351/fd': Permission denied
du: cannot read directory '/proc/3351/task/3351/fdinfo': Permission denied
du: cannot read directory '/proc/3351/task/3351/ns': Permission denied
du: cannot read directory '/proc/3351/fd': Permission denied
du: cannot read directory '/proc/3351/map_files': Permission denied
du: cannot read directory '/proc/3351/fdinfo': Permission denied
du: cannot read directory '/proc/3351/ns': Permission denied
du: cannot read directory '/proc/3356/task/3356/fd': Permission denied
du: cannot read directory '/proc/3356/task/3356/fdinfo': Permission denied
du: cannot read directory '/proc/3356/task/3356/ns': Permission denied
du: cannot read directory '/proc/3356/fd': Permission denied
du: cannot read directory '/proc/3356/map_files': Permission denied
du: cannot read directory '/proc/3356/fdinfo': Permission denied
du: cannot read directory '/proc/3356/ns': Permission denied
du: cannot read directory '/proc/3357/task/3357/fd': Permission denied
du: cannot read directory '/proc/3357/task/3357/fdinfo': Permission denied
du: cannot read directory '/proc/3357/task/3357/ns': Permission denied
du: cannot read directory '/proc/3357/fd': Permission denied
du: cannot read directory '/proc/3357/map_files': Permission denied
du: cannot read directory '/proc/3357/fdinfo': Permission denied
du: cannot read directory '/proc/3357/ns': Permission denied
du: cannot read directory '/proc/3363/task/3363/fd': Permission denied
du: cannot read directory '/proc/3363/task/3363/fdinfo': Permission denied
du: cannot read directory '/proc/3363/task/3363/ns': Permission denied
du: cannot read directory '/proc/3363/fd': Permission denied
du: cannot read directory '/proc/3363/map_files': Permission denied
du: cannot read directory '/proc/3363/fdinfo': Permission denied
du: cannot read directory '/proc/3363/ns': Permission denied
du: cannot read directory '/proc/3364/task/3364/fd': Permission denied
du: cannot read directory '/proc/3364/task/3364/fdinfo': Permission denied
du: cannot read directory '/proc/3364/task/3364/ns': Permission denied
du: cannot read directory '/proc/3364/fd': Permission denied
du: cannot read directory '/proc/3364/map_files': Permission denied
du: cannot read directory '/proc/3364/fdinfo': Permission denied
du: cannot read directory '/proc/3364/ns': Permission denied
du: cannot read directory '/proc/3369/task/3369/fd': Permission denied
du: cannot read directory '/proc/3369/task/3369/fdinfo': Permission denied
du: cannot read directory '/proc/3369/task/3369/ns': Permission denied
du: cannot read directory '/proc/3369/fd': Permission denied
du: cannot read directory '/proc/3369/map_files': Permission denied
du: cannot read directory '/proc/3369/fdinfo': Permission denied
du: cannot read directory '/proc/3369/ns': Permission denied
du: cannot read directory '/proc/3370/task/3370/fd': Permission denied
du: cannot read directory '/proc/3370/task/3370/fdinfo': Permission denied
du: cannot read directory '/proc/3370/task/3370/ns': Permission denied
du: cannot read directory '/proc/3370/fd': Permission denied
du: cannot read directory '/proc/3370/map_files': Permission denied
du: cannot read directory '/proc/3370/fdinfo': Permission denied
du: cannot read directory '/proc/3370/ns': Permission denied
du: cannot read directory '/proc/3409/task/3409/fd': Permission denied
du: cannot read directory '/proc/3409/task/3409/fdinfo': Permission denied
du: cannot read directory '/proc/3409/task/3409/ns': Permission denied
du: cannot read directory '/proc/3409/task/3410/fd': Permission denied
du: cannot read directory '/proc/3409/task/3410/fdinfo': Permission denied
du: cannot read directory '/proc/3409/task/3410/ns': Permission denied
du: cannot read directory '/proc/3409/fd': Permission denied
du: cannot read directory '/proc/3409/map_files': Permission denied
du: cannot read directory '/proc/3409/fdinfo': Permission denied
du: cannot read directory '/proc/3409/ns': Permission denied
du: cannot read directory '/proc/3413/task/3413/fd': Permission denied
du: cannot read directory '/proc/3413/task/3413/fdinfo': Permission denied
du: cannot read directory '/proc/3413/task/3413/ns': Permission denied
du: cannot read directory '/proc/3413/fd': Permission denied
du: cannot read directory '/proc/3413/map_files': Permission denied
du: cannot read directory '/proc/3413/fdinfo': Permission denied
du: cannot read directory '/proc/3413/ns': Permission denied
du: cannot read directory '/proc/3415/task/3415/fd': Permission denied
du: cannot read directory '/proc/3415/task/3415/fdinfo': Permission denied
du: cannot read directory '/proc/3415/task/3415/ns': Permission denied
du: cannot read directory '/proc/3415/fd': Permission denied
du: cannot read directory '/proc/3415/map_files': Permission denied
du: cannot read directory '/proc/3415/fdinfo': Permission denied
du: cannot read directory '/proc/3415/ns': Permission denied
du: cannot read directory '/proc/3441/task/3441/fd': Permission denied
du: cannot read directory '/proc/3441/task/3441/fdinfo': Permission denied
du: cannot read directory '/proc/3441/task/3441/ns': Permission denied
du: cannot read directory '/proc/3441/fd': Permission denied
du: cannot read directory '/proc/3441/map_files': Permission denied
du: cannot read directory '/proc/3441/fdinfo': Permission denied
du: cannot read directory '/proc/3441/ns': Permission denied
du: cannot read directory '/proc/3445/task/3445/fd': Permission denied
du: cannot read directory '/proc/3445/task/3445/fdinfo': Permission denied
du: cannot read directory '/proc/3445/task/3445/ns': Permission denied
du: cannot read directory '/proc/3445/fd': Permission denied
du: cannot read directory '/proc/3445/map_files': Permission denied
du: cannot read directory '/proc/3445/fdinfo': Permission denied
du: cannot read directory '/proc/3445/ns': Permission denied
du: cannot read directory '/proc/3450/task/3450/fd': Permission denied
du: cannot read directory '/proc/3450/task/3450/fdinfo': Permission denied
du: cannot read directory '/proc/3450/task/3450/ns': Permission denied
du: cannot read directory '/proc/3450/fd': Permission denied
du: cannot read directory '/proc/3450/map_files': Permission denied
du: cannot read directory '/proc/3450/fdinfo': Permission denied
du: cannot read directory '/proc/3450/ns': Permission denied
du: cannot read directory '/proc/3451/task/3451/fd': Permission denied
du: cannot read directory '/proc/3451/task/3451/fdinfo': Permission denied
du: cannot read directory '/proc/3451/task/3451/ns': Permission denied
du: cannot read directory '/proc/3451/fd': Permission denied
du: cannot read directory '/proc/3451/map_files': Permission denied
du: cannot read directory '/proc/3451/fdinfo': Permission denied
du: cannot read directory '/proc/3451/ns': Permission denied
du: cannot read directory '/proc/3452/task/3452/fd': Permission denied
du: cannot read directory '/proc/3452/task/3452/fdinfo': Permission denied
du: cannot read directory '/proc/3452/task/3452/ns': Permission denied
du: cannot read directory '/proc/3452/fd': Permission denied
du: cannot read directory '/proc/3452/map_files': Permission denied
du: cannot read directory '/proc/3452/fdinfo': Permission denied
du: cannot read directory '/proc/3452/ns': Permission denied
du: cannot read directory '/proc/3453/task/3453/fd': Permission denied
du: cannot read directory '/proc/3453/task/3453/fdinfo': Permission denied
du: cannot read directory '/proc/3453/task/3453/ns': Permission denied
du: cannot read directory '/proc/3453/task/3466/fd': Permission denied
du: cannot read directory '/proc/3453/task/3466/fdinfo': Permission denied
du: cannot read directory '/proc/3453/task/3466/ns': Permission denied
du: cannot read directory '/proc/3453/fd': Permission denied
du: cannot read directory '/proc/3453/map_files': Permission denied
du: cannot read directory '/proc/3453/fdinfo': Permission denied
du: cannot read directory '/proc/3453/ns': Permission denied
du: cannot read directory '/proc/3455/task/3455/fd': Permission denied
du: cannot read directory '/proc/3455/task/3455/fdinfo': Permission denied
du: cannot read directory '/proc/3455/task/3455/ns': Permission denied
du: cannot read directory '/proc/3455/fd': Permission denied
du: cannot read directory '/proc/3455/map_files': Permission denied
du: cannot read directory '/proc/3455/fdinfo': Permission denied
du: cannot read directory '/proc/3455/ns': Permission denied
du: cannot read directory '/proc/3459/task/3459/fd': Permission denied
du: cannot read directory '/proc/3459/task/3459/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3459/ns': Permission denied
du: cannot read directory '/proc/3459/task/3460/fd': Permission denied
du: cannot read directory '/proc/3459/task/3460/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3460/ns': Permission denied
du: cannot read directory '/proc/3459/task/3461/fd': Permission denied
du: cannot read directory '/proc/3459/task/3461/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3461/ns': Permission denied
du: cannot read directory '/proc/3459/task/3462/fd': Permission denied
du: cannot read directory '/proc/3459/task/3462/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3462/ns': Permission denied
du: cannot read directory '/proc/3459/task/3463/fd': Permission denied
du: cannot read directory '/proc/3459/task/3463/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3463/ns': Permission denied
du: cannot read directory '/proc/3459/task/3465/fd': Permission denied
du: cannot read directory '/proc/3459/task/3465/fdinfo': Permission denied
du: cannot read directory '/proc/3459/task/3465/ns': Permission denied
du: cannot read directory '/proc/3459/fd': Permission denied
du: cannot read directory '/proc/3459/map_files': Permission denied
du: cannot read directory '/proc/3459/fdinfo': Permission denied
du: cannot read directory '/proc/3459/ns': Permission denied
du: cannot read directory '/proc/3468/task/3468/fd': Permission denied
du: cannot read directory '/proc/3468/task/3468/fdinfo': Permission denied
du: cannot read directory '/proc/3468/task/3468/ns': Permission denied
du: cannot read directory '/proc/3468/fd': Permission denied
du: cannot read directory '/proc/3468/map_files': Permission denied
du: cannot read directory '/proc/3468/fdinfo': Permission denied
du: cannot read directory '/proc/3468/ns': Permission denied
du: cannot read directory '/proc/3501/task/3501/fd': Permission denied
du: cannot read directory '/proc/3501/task/3501/fdinfo': Permission denied
du: cannot read directory '/proc/3501/task/3501/ns': Permission denied
du: cannot read directory '/proc/3501/fd': Permission denied
du: cannot read directory '/proc/3501/map_files': Permission denied
du: cannot read directory '/proc/3501/fdinfo': Permission denied
du: cannot read directory '/proc/3501/ns': Permission denied
du: cannot read directory '/proc/3773/task/3773/fd': Permission denied
du: cannot read directory '/proc/3773/task/3773/fdinfo': Permission denied
du: cannot read directory '/proc/3773/task/3773/ns': Permission denied
du: cannot read directory '/proc/3773/fd': Permission denied
du: cannot read directory '/proc/3773/map_files': Permission denied
du: cannot read directory '/proc/3773/fdinfo': Permission denied
du: cannot read directory '/proc/3773/ns': Permission denied
du: cannot read directory '/proc/3807/task/3807/fd': Permission denied
du: cannot read directory '/proc/3807/task/3807/fdinfo': Permission denied
du: cannot read directory '/proc/3807/task/3807/ns': Permission denied
du: cannot read directory '/proc/3807/fd': Permission denied
du: cannot read directory '/proc/3807/map_files': Permission denied
du: cannot read directory '/proc/3807/fdinfo': Permission denied
du: cannot read directory '/proc/3807/ns': Permission denied
du: cannot read directory '/proc/3808/task/3808/fd': Permission denied
du: cannot read directory '/proc/3808/task/3808/fdinfo': Permission denied
du: cannot read directory '/proc/3808/task/3808/ns': Permission denied
du: cannot read directory '/proc/3808/fd': Permission denied
du: cannot read directory '/proc/3808/map_files': Permission denied
du: cannot read directory '/proc/3808/fdinfo': Permission denied
du: cannot read directory '/proc/3808/ns': Permission denied
du: cannot read directory '/proc/3809/task/3809/fd': Permission denied
du: cannot read directory '/proc/3809/task/3809/fdinfo': Permission denied
du: cannot read directory '/proc/3809/task/3809/ns': Permission denied
du: cannot read directory '/proc/3809/fd': Permission denied
du: cannot read directory '/proc/3809/map_files': Permission denied
du: cannot read directory '/proc/3809/fdinfo': Permission denied
du: cannot read directory '/proc/3809/ns': Permission denied
du: cannot read directory '/proc/3907/task/3907/fd': Permission denied
du: cannot read directory '/proc/3907/task/3907/fdinfo': Permission denied
du: cannot read directory '/proc/3907/task/3907/ns': Permission denied
du: cannot read directory '/proc/3907/fd': Permission denied
du: cannot read directory '/proc/3907/map_files': Permission denied
du: cannot read directory '/proc/3907/fdinfo': Permission denied
du: cannot read directory '/proc/3907/ns': Permission denied
du: cannot read directory '/proc/3912/task/3912/fd': Permission denied
du: cannot read directory '/proc/3912/task/3912/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3912/ns': Permission denied
du: cannot read directory '/proc/3912/task/3932/fd': Permission denied
du: cannot read directory '/proc/3912/task/3932/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3932/ns': Permission denied
du: cannot read directory '/proc/3912/task/3933/fd': Permission denied
du: cannot read directory '/proc/3912/task/3933/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3933/ns': Permission denied
du: cannot read directory '/proc/3912/task/3934/fd': Permission denied
du: cannot read directory '/proc/3912/task/3934/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3934/ns': Permission denied
du: cannot read directory '/proc/3912/task/3935/fd': Permission denied
du: cannot read directory '/proc/3912/task/3935/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3935/ns': Permission denied
du: cannot read directory '/proc/3912/task/3936/fd': Permission denied
du: cannot read directory '/proc/3912/task/3936/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3936/ns': Permission denied
du: cannot read directory '/proc/3912/task/3937/fd': Permission denied
du: cannot read directory '/proc/3912/task/3937/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3937/ns': Permission denied
du: cannot read directory '/proc/3912/task/3938/fd': Permission denied
du: cannot read directory '/proc/3912/task/3938/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3938/ns': Permission denied
du: cannot read directory '/proc/3912/task/3939/fd': Permission denied
du: cannot read directory '/proc/3912/task/3939/fdinfo': Permission denied
du: cannot read directory '/proc/3912/task/3939/ns': Permission denied
du: cannot read directory '/proc/3912/fd': Permission denied
du: cannot read directory '/proc/3912/map_files': Permission denied
du: cannot read directory '/proc/3912/fdinfo': Permission denied
du: cannot read directory '/proc/3912/ns': Permission denied
du: cannot read directory '/proc/3929/task/3929/fd': Permission denied
du: cannot read directory '/proc/3929/task/3929/fdinfo': Permission denied
du: cannot read directory '/proc/3929/task/3929/ns': Permission denied
du: cannot read directory '/proc/3929/fd': Permission denied
du: cannot read directory '/proc/3929/map_files': Permission denied
du: cannot read directory '/proc/3929/fdinfo': Permission denied
du: cannot read directory '/proc/3929/ns': Permission denied
du: cannot read directory '/proc/3942/task/3942/fd': Permission denied
du: cannot read directory '/proc/3942/task/3942/fdinfo': Permission denied
du: cannot read directory '/proc/3942/task/3942/ns': Permission denied
du: cannot read directory '/proc/3942/fd': Permission denied
du: cannot read directory '/proc/3942/map_files': Permission denied
du: cannot read directory '/proc/3942/fdinfo': Permission denied
du: cannot read directory '/proc/3942/ns': Permission denied
du: cannot read directory '/proc/3946/task/3946/fd': Permission denied
du: cannot read directory '/proc/3946/task/3946/fdinfo': Permission denied
du: cannot read directory '/proc/3946/task/3946/ns': Permission denied
du: cannot read directory '/proc/3946/fd': Permission denied
du: cannot read directory '/proc/3946/map_files': Permission denied
du: cannot read directory '/proc/3946/fdinfo': Permission denied
du: cannot read directory '/proc/3946/ns': Permission denied
du: cannot read directory '/proc/3968/task/3968/fd': Permission denied
du: cannot read directory '/proc/3968/task/3968/fdinfo': Permission denied
du: cannot read directory '/proc/3968/task/3968/ns': Permission denied
du: cannot read directory '/proc/3968/fd': Permission denied
du: cannot read directory '/proc/3968/map_files': Permission denied
du: cannot read directory '/proc/3968/fdinfo': Permission denied
du: cannot read directory '/proc/3968/ns': Permission denied
du: cannot read directory '/proc/3975/task/3975/fd': Permission denied
du: cannot read directory '/proc/3975/task/3975/fdinfo': Permission denied
du: cannot read directory '/proc/3975/task/3975/ns': Permission denied
du: cannot read directory '/proc/3975/fd': Permission denied
du: cannot read directory '/proc/3975/map_files': Permission denied
du: cannot read directory '/proc/3975/fdinfo': Permission denied
du: cannot read directory '/proc/3975/ns': Permission denied
du: cannot read directory '/proc/3976/task/3976/fd': Permission denied
du: cannot read directory '/proc/3976/task/3976/fdinfo': Permission denied
du: cannot read directory '/proc/3976/task/3976/ns': Permission denied
du: cannot read directory '/proc/3976/fd': Permission denied
du: cannot read directory '/proc/3976/map_files': Permission denied
du: cannot read directory '/proc/3976/fdinfo': Permission denied
du: cannot read directory '/proc/3976/ns': Permission denied
du: cannot read directory '/proc/3979/task/3979/fd': Permission denied
du: cannot read directory '/proc/3979/task/3979/fdinfo': Permission denied
du: cannot read directory '/proc/3979/task/3979/ns': Permission denied
du: cannot read directory '/proc/3979/fd': Permission denied
du: cannot read directory '/proc/3979/map_files': Permission denied
du: cannot read directory '/proc/3979/fdinfo': Permission denied
du: cannot read directory '/proc/3979/ns': Permission denied
du: cannot read directory '/proc/4299/task/4299/fd': Permission denied
du: cannot read directory '/proc/4299/task/4299/fdinfo': Permission denied
du: cannot read directory '/proc/4299/task/4299/ns': Permission denied
du: cannot read directory '/proc/4299/fd': Permission denied
du: cannot read directory '/proc/4299/map_files': Permission denied
du: cannot read directory '/proc/4299/fdinfo': Permission denied
du: cannot read directory '/proc/4299/ns': Permission denied
du: cannot read directory '/proc/4460/task/4460/fd': Permission denied
du: cannot read directory '/proc/4460/task/4460/fdinfo': Permission denied
du: cannot read directory '/proc/4460/task/4460/ns': Permission denied
du: cannot read directory '/proc/4460/fd': Permission denied
du: cannot read directory '/proc/4460/map_files': Permission denied
du: cannot read directory '/proc/4460/fdinfo': Permission denied
du: cannot read directory '/proc/4460/ns': Permission denied
du: cannot read directory '/proc/4476/task/4476/fd': Permission denied
du: cannot read directory '/proc/4476/task/4476/fdinfo': Permission denied
du: cannot read directory '/proc/4476/task/4476/ns': Permission denied
du: cannot read directory '/proc/4476/fd': Permission denied
du: cannot read directory '/proc/4476/map_files': Permission denied
du: cannot read directory '/proc/4476/fdinfo': Permission denied
du: cannot read directory '/proc/4476/ns': Permission denied
du: cannot read directory '/proc/4538/task/4538/fd': Permission denied
du: cannot read directory '/proc/4538/task/4538/fdinfo': Permission denied
du: cannot read directory '/proc/4538/task/4538/ns': Permission denied
du: cannot read directory '/proc/4538/fd': Permission denied
du: cannot read directory '/proc/4538/map_files': Permission denied
du: cannot read directory '/proc/4538/fdinfo': Permission denied
du: cannot read directory '/proc/4538/ns': Permission denied
du: cannot read directory '/proc/4667/task/4667/fd': Permission denied
du: cannot read directory '/proc/4667/task/4667/fdinfo': Permission denied
du: cannot read directory '/proc/4667/task/4667/ns': Permission denied
du: cannot read directory '/proc/4667/fd': Permission denied
du: cannot read directory '/proc/4667/map_files': Permission denied
du: cannot read directory '/proc/4667/fdinfo': Permission denied
du: cannot read directory '/proc/4667/ns': Permission denied
du: cannot read directory '/proc/5034/task/5034/fd': Permission denied
du: cannot read directory '/proc/5034/task/5034/fdinfo': Permission denied
du: cannot read directory '/proc/5034/task/5034/ns': Permission denied
du: cannot read directory '/proc/5034/fd': Permission denied
du: cannot read directory '/proc/5034/map_files': Permission denied
du: cannot read directory '/proc/5034/fdinfo': Permission denied
du: cannot read directory '/proc/5034/ns': Permission denied
du: cannot read directory '/proc/5218/task/5218/fd': Permission denied
du: cannot read directory '/proc/5218/task/5218/fdinfo': Permission denied
du: cannot read directory '/proc/5218/task/5218/ns': Permission denied
du: cannot read directory '/proc/5218/fd': Permission denied
du: cannot read directory '/proc/5218/map_files': Permission denied
du: cannot read directory '/proc/5218/fdinfo': Permission denied
du: cannot read directory '/proc/5218/ns': Permission denied
du: cannot read directory '/proc/5246/task/5246/fd': Permission denied
du: cannot read directory '/proc/5246/task/5246/fdinfo': Permission denied
du: cannot read directory '/proc/5246/task/5246/ns': Permission denied
du: cannot read directory '/proc/5246/task/5248/fd': Permission denied
du: cannot read directory '/proc/5246/task/5248/fdinfo': Permission denied
du: cannot read directory '/proc/5246/task/5248/ns': Permission denied
du: cannot read directory '/proc/5246/task/5249/fd': Permission denied
du: cannot read directory '/proc/5246/task/5249/fdinfo': Permission denied
du: cannot read directory '/proc/5246/task/5249/ns': Permission denied
du: cannot read directory '/proc/5246/fd': Permission denied
du: cannot read directory '/proc/5246/map_files': Permission denied
du: cannot read directory '/proc/5246/fdinfo': Permission denied
du: cannot read directory '/proc/5246/ns': Permission denied
du: cannot read directory '/proc/5307/task/5307/fd': Permission denied
du: cannot read directory '/proc/5307/task/5307/fdinfo': Permission denied
du: cannot read directory '/proc/5307/task/5307/ns': Permission denied
du: cannot read directory '/proc/5307/fd': Permission denied
du: cannot read directory '/proc/5307/map_files': Permission denied
du: cannot read directory '/proc/5307/fdinfo': Permission denied
du: cannot read directory '/proc/5307/ns': Permission denied
du: cannot read directory '/proc/5333/task/5333/fd': Permission denied
du: cannot read directory '/proc/5333/task/5333/fdinfo': Permission denied
du: cannot read directory '/proc/5333/task/5333/ns': Permission denied
du: cannot read directory '/proc/5333/fd': Permission denied
du: cannot read directory '/proc/5333/map_files': Permission denied
du: cannot read directory '/proc/5333/fdinfo': Permission denied
du: cannot read directory '/proc/5333/ns': Permission denied
du: cannot read directory '/proc/5445/task/5445/fd': Permission denied
du: cannot read directory '/proc/5445/task/5445/fdinfo': Permission denied
du: cannot read directory '/proc/5445/task/5445/ns': Permission denied
du: cannot read directory '/proc/5445/fd': Permission denied
du: cannot read directory '/proc/5445/map_files': Permission denied
du: cannot read directory '/proc/5445/fdinfo': Permission denied
du: cannot read directory '/proc/5445/ns': Permission denied
du: cannot read directory '/proc/5501/task/5501/fd': Permission denied
du: cannot read directory '/proc/5501/task/5501/fdinfo': Permission denied
du: cannot read directory '/proc/5501/task/5501/ns': Permission denied
du: cannot read directory '/proc/5501/fd': Permission denied
du: cannot read directory '/proc/5501/map_files': Permission denied
du: cannot read directory '/proc/5501/fdinfo': Permission denied
du: cannot read directory '/proc/5501/ns': Permission denied
du: cannot read directory '/proc/5607/task/5607/fd': Permission denied
du: cannot read directory '/proc/5607/task/5607/fdinfo': Permission denied
du: cannot read directory '/proc/5607/task/5607/ns': Permission denied
du: cannot read directory '/proc/5607/fd': Permission denied
du: cannot read directory '/proc/5607/map_files': Permission denied
du: cannot read directory '/proc/5607/fdinfo': Permission denied
du: cannot read directory '/proc/5607/ns': Permission denied
du: cannot read directory '/proc/5879/task/5879/fd': Permission denied
du: cannot read directory '/proc/5879/task/5879/fdinfo': Permission denied
du: cannot read directory '/proc/5879/task/5879/ns': Permission denied
du: cannot read directory '/proc/5879/fd': Permission denied
du: cannot read directory '/proc/5879/map_files': Permission denied
du: cannot read directory '/proc/5879/fdinfo': Permission denied
du: cannot read directory '/proc/5879/ns': Permission denied
du: cannot read directory '/proc/6468/task/6468/fd': Permission denied
du: cannot read directory '/proc/6468/task/6468/fdinfo': Permission denied
du: cannot read directory '/proc/6468/task/6468/ns': Permission denied
du: cannot read directory '/proc/6468/fd': Permission denied
du: cannot read directory '/proc/6468/map_files': Permission denied
du: cannot read directory '/proc/6468/fdinfo': Permission denied
du: cannot read directory '/proc/6468/ns': Permission denied
du: cannot read directory '/proc/6725/task/6725/fd': Permission denied
du: cannot read directory '/proc/6725/task/6725/fdinfo': Permission denied
du: cannot read directory '/proc/6725/task/6725/ns': Permission denied
du: cannot read directory '/proc/6725/fd': Permission denied
du: cannot read directory '/proc/6725/map_files': Permission denied
du: cannot read directory '/proc/6725/fdinfo': Permission denied
du: cannot read directory '/proc/6725/ns': Permission denied
du: cannot read directory '/proc/6888/task/6888/fd': Permission denied
du: cannot read directory '/proc/6888/task/6888/fdinfo': Permission denied
du: cannot read directory '/proc/6888/task/6888/ns': Permission denied
du: cannot read directory '/proc/6888/fd': Permission denied
du: cannot read directory '/proc/6888/map_files': Permission denied
du: cannot read directory '/proc/6888/fdinfo': Permission denied
du: cannot read directory '/proc/6888/ns': Permission denied
du: cannot read directory '/proc/7055/task/7055/fd': Permission denied
du: cannot read directory '/proc/7055/task/7055/fdinfo': Permission denied
du: cannot read directory '/proc/7055/task/7055/ns': Permission denied
du: cannot read directory '/proc/7055/fd': Permission denied
du: cannot read directory '/proc/7055/map_files': Permission denied
du: cannot read directory '/proc/7055/fdinfo': Permission denied
du: cannot read directory '/proc/7055/ns': Permission denied
du: cannot read directory '/proc/7108/task/7108/fd': Permission denied
du: cannot read directory '/proc/7108/task/7108/fdinfo': Permission denied
du: cannot read directory '/proc/7108/task/7108/ns': Permission denied
du: cannot read directory '/proc/7108/fd': Permission denied
du: cannot read directory '/proc/7108/map_files': Permission denied
du: cannot read directory '/proc/7108/fdinfo': Permission denied
du: cannot read directory '/proc/7108/ns': Permission denied
du: cannot read directory '/proc/7145/task/7145/fd': Permission denied
du: cannot read directory '/proc/7145/task/7145/fdinfo': Permission denied
du: cannot read directory '/proc/7145/task/7145/ns': Permission denied
du: cannot read directory '/proc/7145/fd': Permission denied
du: cannot read directory '/proc/7145/map_files': Permission denied
du: cannot read directory '/proc/7145/fdinfo': Permission denied
du: cannot read directory '/proc/7145/ns': Permission denied
du: cannot read directory '/proc/7198/task/7198/fd': Permission denied
du: cannot read directory '/proc/7198/task/7198/fdinfo': Permission denied
du: cannot read directory '/proc/7198/task/7198/ns': Permission denied
du: cannot read directory '/proc/7198/fd': Permission denied
du: cannot read directory '/proc/7198/map_files': Permission denied
du: cannot read directory '/proc/7198/fdinfo': Permission denied
du: cannot read directory '/proc/7198/ns': Permission denied
du: cannot read directory '/proc/7462/task/7462/fd': Permission denied
du: cannot read directory '/proc/7462/task/7462/fdinfo': Permission denied
du: cannot read directory '/proc/7462/task/7462/ns': Permission denied
du: cannot read directory '/proc/7462/fd': Permission denied
du: cannot read directory '/proc/7462/map_files': Permission denied
du: cannot read directory '/proc/7462/fdinfo': Permission denied
du: cannot read directory '/proc/7462/ns': Permission denied
du: cannot read directory '/proc/7779/task/7779/fd': Permission denied
du: cannot read directory '/proc/7779/task/7779/fdinfo': Permission denied
du: cannot read directory '/proc/7779/task/7779/ns': Permission denied
du: cannot read directory '/proc/7779/fd': Permission denied
du: cannot read directory '/proc/7779/map_files': Permission denied
du: cannot read directory '/proc/7779/fdinfo': Permission denied
du: cannot read directory '/proc/7779/ns': Permission denied
du: cannot read directory '/proc/7832/task/7832/fd': Permission denied
du: cannot read directory '/proc/7832/task/7832/fdinfo': Permission denied
du: cannot read directory '/proc/7832/task/7832/ns': Permission denied
du: cannot read directory '/proc/7832/fd': Permission denied
du: cannot read directory '/proc/7832/map_files': Permission denied
du: cannot read directory '/proc/7832/fdinfo': Permission denied
du: cannot read directory '/proc/7832/ns': Permission denied
du: cannot read directory '/proc/7886/task/7886/fd': Permission denied
du: cannot read directory '/proc/7886/task/7886/fdinfo': Permission denied
du: cannot read directory '/proc/7886/task/7886/ns': Permission denied
du: cannot read directory '/proc/7886/fd': Permission denied
du: cannot read directory '/proc/7886/map_files': Permission denied
du: cannot read directory '/proc/7886/fdinfo': Permission denied
du: cannot read directory '/proc/7886/ns': Permission denied
du: cannot read directory '/proc/7919/task/7919/fd': Permission denied
du: cannot read directory '/proc/7919/task/7919/fdinfo': Permission denied
du: cannot read directory '/proc/7919/task/7919/ns': Permission denied
du: cannot read directory '/proc/7919/fd': Permission denied
du: cannot read directory '/proc/7919/map_files': Permission denied
du: cannot read directory '/proc/7919/fdinfo': Permission denied
du: cannot read directory '/proc/7919/ns': Permission denied
du: cannot read directory '/proc/7989/task/7989/fd': Permission denied
du: cannot read directory '/proc/7989/task/7989/fdinfo': Permission denied
du: cannot read directory '/proc/7989/task/7989/ns': Permission denied
du: cannot read directory '/proc/7989/fd': Permission denied
du: cannot read directory '/proc/7989/map_files': Permission denied
du: cannot read directory '/proc/7989/fdinfo': Permission denied
du: cannot read directory '/proc/7989/ns': Permission denied
du: cannot read directory '/proc/8001/task/8001/fd': Permission denied
du: cannot read directory '/proc/8001/task/8001/fdinfo': Permission denied
du: cannot read directory '/proc/8001/task/8001/ns': Permission denied
du: cannot read directory '/proc/8001/fd': Permission denied
du: cannot read directory '/proc/8001/map_files': Permission denied
du: cannot read directory '/proc/8001/fdinfo': Permission denied
du: cannot read directory '/proc/8001/ns': Permission denied
du: cannot read directory '/proc/8060/task/8060/fd': Permission denied
du: cannot read directory '/proc/8060/task/8060/fdinfo': Permission denied
du: cannot read directory '/proc/8060/task/8060/ns': Permission denied
du: cannot read directory '/proc/8060/fd': Permission denied
du: cannot read directory '/proc/8060/map_files': Permission denied
du: cannot read directory '/proc/8060/fdinfo': Permission denied
du: cannot read directory '/proc/8060/ns': Permission denied
du: cannot read directory '/proc/8271/task/8271/fd': Permission denied
du: cannot read directory '/proc/8271/task/8271/fdinfo': Permission denied
du: cannot read directory '/proc/8271/task/8271/ns': Permission denied
du: cannot read directory '/proc/8271/fd': Permission denied
du: cannot read directory '/proc/8271/map_files': Permission denied
du: cannot read directory '/proc/8271/fdinfo': Permission denied
du: cannot read directory '/proc/8271/ns': Permission denied
du: cannot read directory '/proc/8298/task/8298/fd': Permission denied
du: cannot read directory '/proc/8298/task/8298/fdinfo': Permission denied
du: cannot read directory '/proc/8298/task/8298/ns': Permission denied
du: cannot read directory '/proc/8298/fd': Permission denied
du: cannot read directory '/proc/8298/map_files': Permission denied
du: cannot read directory '/proc/8298/fdinfo': Permission denied
du: cannot read directory '/proc/8298/ns': Permission denied
du: cannot read directory '/proc/8437/task/8437/fd': Permission denied
du: cannot read directory '/proc/8437/task/8437/fdinfo': Permission denied
du: cannot read directory '/proc/8437/task/8437/ns': Permission denied
du: cannot read directory '/proc/8437/fd': Permission denied
du: cannot read directory '/proc/8437/map_files': Permission denied
du: cannot read directory '/proc/8437/fdinfo': Permission denied
du: cannot read directory '/proc/8437/ns': Permission denied
du: cannot read directory '/proc/8473/task/8473/fd': Permission denied
du: cannot read directory '/proc/8473/task/8473/fdinfo': Permission denied
du: cannot read directory '/proc/8473/task/8473/ns': Permission denied
du: cannot read directory '/proc/8473/fd': Permission denied
du: cannot read directory '/proc/8473/map_files': Permission denied
du: cannot read directory '/proc/8473/fdinfo': Permission denied
du: cannot read directory '/proc/8473/ns': Permission denied
du: cannot read directory '/proc/8546/task/8546/fd': Permission denied
du: cannot read directory '/proc/8546/task/8546/fdinfo': Permission denied
du: cannot read directory '/proc/8546/task/8546/ns': Permission denied
du: cannot read directory '/proc/8546/fd': Permission denied
du: cannot read directory '/proc/8546/map_files': Permission denied
du: cannot read directory '/proc/8546/fdinfo': Permission denied
du: cannot read directory '/proc/8546/ns': Permission denied
du: cannot read directory '/proc/8668/task/8668/fd': Permission denied
du: cannot read directory '/proc/8668/task/8668/fdinfo': Permission denied
du: cannot read directory '/proc/8668/task/8668/ns': Permission denied
du: cannot read directory '/proc/8668/fd': Permission denied
du: cannot read directory '/proc/8668/map_files': Permission denied
du: cannot read directory '/proc/8668/fdinfo': Permission denied
du: cannot read directory '/proc/8668/ns': Permission denied
du: cannot read directory '/proc/8679/task/8679/fd': Permission denied
du: cannot read directory '/proc/8679/task/8679/fdinfo': Permission denied
du: cannot read directory '/proc/8679/task/8679/ns': Permission denied
du: cannot read directory '/proc/8679/fd': Permission denied
du: cannot read directory '/proc/8679/map_files': Permission denied
du: cannot read directory '/proc/8679/fdinfo': Permission denied
du: cannot read directory '/proc/8679/ns': Permission denied
du: cannot read directory '/proc/8683/task/8683/fd': Permission denied
du: cannot read directory '/proc/8683/task/8683/fdinfo': Permission denied
du: cannot read directory '/proc/8683/task/8683/ns': Permission denied
du: cannot read directory '/proc/8683/fd': Permission denied
du: cannot read directory '/proc/8683/map_files': Permission denied
du: cannot read directory '/proc/8683/fdinfo': Permission denied
du: cannot read directory '/proc/8683/ns': Permission denied
du: cannot read directory '/proc/8701/task/8701/fd': Permission denied
du: cannot read directory '/proc/8701/task/8701/fdinfo': Permission denied
du: cannot read directory '/proc/8701/task/8701/ns': Permission denied
du: cannot read directory '/proc/8701/fd': Permission denied
du: cannot read directory '/proc/8701/map_files': Permission denied
du: cannot read directory '/proc/8701/fdinfo': Permission denied
du: cannot read directory '/proc/8701/ns': Permission denied
du: cannot read directory '/proc/8714/task/8714/fd': Permission denied
du: cannot read directory '/proc/8714/task/8714/fdinfo': Permission denied
du: cannot read directory '/proc/8714/task/8714/ns': Permission denied
du: cannot read directory '/proc/8714/fd': Permission denied
du: cannot read directory '/proc/8714/map_files': Permission denied
du: cannot read directory '/proc/8714/fdinfo': Permission denied
du: cannot read directory '/proc/8714/ns': Permission denied
du: cannot read directory '/proc/8725/task/8725/fd': Permission denied
du: cannot read directory '/proc/8725/task/8725/fdinfo': Permission denied
du: cannot read directory '/proc/8725/task/8725/ns': Permission denied
du: cannot read directory '/proc/8725/fd': Permission denied
du: cannot read directory '/proc/8725/map_files': Permission denied
du: cannot read directory '/proc/8725/fdinfo': Permission denied
du: cannot read directory '/proc/8725/ns': Permission denied
du: cannot read directory '/proc/8729/task/8729/fd': Permission denied
du: cannot read directory '/proc/8729/task/8729/fdinfo': Permission denied
du: cannot read directory '/proc/8729/task/8729/ns': Permission denied
du: cannot read directory '/proc/8729/fd': Permission denied
du: cannot read directory '/proc/8729/map_files': Permission denied
du: cannot read directory '/proc/8729/fdinfo': Permission denied
du: cannot read directory '/proc/8729/ns': Permission denied
du: cannot read directory '/proc/8730/task/8730/fd': Permission denied
du: cannot read directory '/proc/8730/task/8730/fdinfo': Permission denied
du: cannot read directory '/proc/8730/task/8730/ns': Permission denied
du: cannot read directory '/proc/8730/fd': Permission denied
du: cannot read directory '/proc/8730/map_files': Permission denied
du: cannot read directory '/proc/8730/fdinfo': Permission denied
du: cannot read directory '/proc/8730/ns': Permission denied
du: cannot read directory '/proc/8767/task/8767/fd': Permission denied
du: cannot read directory '/proc/8767/task/8767/fdinfo': Permission denied
du: cannot read directory '/proc/8767/task/8767/ns': Permission denied
du: cannot read directory '/proc/8767/fd': Permission denied
du: cannot read directory '/proc/8767/map_files': Permission denied
du: cannot read directory '/proc/8767/fdinfo': Permission denied
du: cannot read directory '/proc/8767/ns': Permission denied
du: cannot access '/proc/8773/task/8773/fd/3': No such file or directory
du: cannot access '/proc/8773/task/8773/fdinfo/3': No such file or directory
du: cannot access '/proc/8773/fd/3': No such file or directory
du: cannot access '/proc/8773/fdinfo/3': No such file or directory
du: cannot read directory '/proc/8779/task/8779/fd': Permission denied
du: cannot read directory '/proc/8779/task/8779/fdinfo': Permission denied
du: cannot read directory '/proc/8779/task/8779/ns': Permission denied
du: cannot read directory '/proc/8779/fd': Permission denied
du: cannot read directory '/proc/8779/map_files': Permission denied
du: cannot read directory '/proc/8779/fdinfo': Permission denied
du: cannot read directory '/proc/8779/ns': Permission denied
du: cannot read directory '/proc/8780/task/8780/fd': Permission denied
du: cannot read directory '/proc/8780/task/8780/fdinfo': Permission denied
du: cannot read directory '/proc/8780/task/8780/ns': Permission denied
du: cannot read directory '/proc/8780/fd': Permission denied
du: cannot read directory '/proc/8780/map_files': Permission denied
du: cannot read directory '/proc/8780/fdinfo': Permission denied
du: cannot read directory '/proc/8780/ns': Permission denied
du: cannot read directory '/proc/10268/task/10268/fd': Permission denied
du: cannot read directory '/proc/10268/task/10268/fdinfo': Permission denied
du: cannot read directory '/proc/10268/task/10268/ns': Permission denied
du: cannot read directory '/proc/10268/fd': Permission denied
du: cannot read directory '/proc/10268/map_files': Permission denied
du: cannot read directory '/proc/10268/fdinfo': Permission denied
du: cannot read directory '/proc/10268/ns': Permission denied
du: cannot read directory '/proc/13023/task/13023/fd': Permission denied
du: cannot read directory '/proc/13023/task/13023/fdinfo': Permission denied
du: cannot read directory '/proc/13023/task/13023/ns': Permission denied
du: cannot read directory '/proc/13023/fd': Permission denied
du: cannot read directory '/proc/13023/map_files': Permission denied
du: cannot read directory '/proc/13023/fdinfo': Permission denied
du: cannot read directory '/proc/13023/ns': Permission denied
du: cannot read directory '/proc/16250/task/16250/fd': Permission denied
du: cannot read directory '/proc/16250/task/16250/fdinfo': Permission denied
du: cannot read directory '/proc/16250/task/16250/ns': Permission denied
du: cannot read directory '/proc/16250/fd': Permission denied
du: cannot read directory '/proc/16250/map_files': Permission denied
du: cannot read directory '/proc/16250/fdinfo': Permission denied
du: cannot read directory '/proc/16250/ns': Permission denied
du: cannot read directory '/proc/18119/task/18119/fd': Permission denied
du: cannot read directory '/proc/18119/task/18119/fdinfo': Permission denied
du: cannot read directory '/proc/18119/task/18119/ns': Permission denied
du: cannot read directory '/proc/18119/fd': Permission denied
du: cannot read directory '/proc/18119/map_files': Permission denied
du: cannot read directory '/proc/18119/fdinfo': Permission denied
du: cannot read directory '/proc/18119/ns': Permission denied
du: cannot read directory '/proc/18169/task/18169/fd': Permission denied
du: cannot read directory '/proc/18169/task/18169/fdinfo': Permission denied
du: cannot read directory '/proc/18169/task/18169/ns': Permission denied
du: cannot read directory '/proc/18169/fd': Permission denied
du: cannot read directory '/proc/18169/map_files': Permission denied
du: cannot read directory '/proc/18169/fdinfo': Permission denied
du: cannot read directory '/proc/18169/ns': Permission denied
du: cannot read directory '/proc/21900/task/21900/fd': Permission denied
du: cannot read directory '/proc/21900/task/21900/fdinfo': Permission denied
du: cannot read directory '/proc/21900/task/21900/ns': Permission denied
du: cannot read directory '/proc/21900/fd': Permission denied
du: cannot read directory '/proc/21900/map_files': Permission denied
du: cannot read directory '/proc/21900/fdinfo': Permission denied
du: cannot read directory '/proc/21900/ns': Permission denied
du: cannot read directory '/proc/26313/task/26313/fd': Permission denied
du: cannot read directory '/proc/26313/task/26313/fdinfo': Permission denied
du: cannot read directory '/proc/26313/task/26313/ns': Permission denied
du: cannot read directory '/proc/26313/fd': Permission denied
du: cannot read directory '/proc/26313/map_files': Permission denied
du: cannot read directory '/proc/26313/fdinfo': Permission denied
du: cannot read directory '/proc/26313/ns': Permission denied
du: cannot read directory '/proc/26748/task/26748/fd': Permission denied
du: cannot read directory '/proc/26748/task/26748/fdinfo': Permission denied
du: cannot read directory '/proc/26748/task/26748/ns': Permission denied
du: cannot read directory '/proc/26748/fd': Permission denied
du: cannot read directory '/proc/26748/map_files': Permission denied
du: cannot read directory '/proc/26748/fdinfo': Permission denied
du: cannot read directory '/proc/26748/ns': Permission denied
du: cannot read directory '/proc/28846/task/28846/fd': Permission denied
du: cannot read directory '/proc/28846/task/28846/fdinfo': Permission denied
du: cannot read directory '/proc/28846/task/28846/ns': Permission denied
du: cannot read directory '/proc/28846/fd': Permission denied
du: cannot read directory '/proc/28846/map_files': Permission denied
du: cannot read directory '/proc/28846/fdinfo': Permission denied
du: cannot read directory '/proc/28846/ns': Permission denied
du: cannot read directory '/proc/30432/task/30432/fd': Permission denied
du: cannot read directory '/proc/30432/task/30432/fdinfo': Permission denied
du: cannot read directory '/proc/30432/task/30432/ns': Permission denied
du: cannot read directory '/proc/30432/fd': Permission denied
du: cannot read directory '/proc/30432/map_files': Permission denied
du: cannot read directory '/proc/30432/fdinfo': Permission denied
du: cannot read directory '/proc/30432/ns': Permission denied
du: cannot read directory '/proc/30685/task/30685/fd': Permission denied
du: cannot read directory '/proc/30685/task/30685/fdinfo': Permission denied
du: cannot read directory '/proc/30685/task/30685/ns': Permission denied
du: cannot read directory '/proc/30685/fd': Permission denied
du: cannot read directory '/proc/30685/map_files': Permission denied
du: cannot read directory '/proc/30685/fdinfo': Permission denied
du: cannot read directory '/proc/30685/ns': Permission denied
du: cannot read directory '/proc/31676/task/31676/fd': Permission denied
du: cannot read directory '/proc/31676/task/31676/fdinfo': Permission denied
du: cannot read directory '/proc/31676/task/31676/ns': Permission denied
du: cannot read directory '/proc/31676/fd': Permission denied
du: cannot read directory '/proc/31676/map_files': Permission denied
du: cannot read directory '/proc/31676/fdinfo': Permission denied
du: cannot read directory '/proc/31676/ns': Permission denied
du: cannot read directory '/storedconfig/lost+found': Permission denied
du: cannot read directory '/home/prime': Permission denied
du: cannot read directory '/home/admin/.gnupg': Permission denied
du: cannot read directory '/opt/CSCOlumos/rcmds': Permission denied
du: cannot read directory '/opt/CSCOlumos/conf/keys': Permission denied
du: cannot read directory '/opt/backup': Permission denied
du: cannot access '/opt/csm/ssl/private': Permission denied
du: cannot access '/opt/csm/ssl/misc': Permission denied
du: cannot access '/opt/csm/ssl/man': Permission denied
du: cannot access '/opt/csm/ssl/openssl.cnf': Permission denied
du: cannot access '/opt/csm/ssl/certs': Permission denied
du: cannot read directory '/opt/lost+found': Permission denied
du: cannot read directory '/tmp/systemd-private-8ef7f42d90a5483e8b61014df4a3db07-ntpd.service-GDWQQv': Permission denied
du: cannot read directory '/boot/efi/EFI/redhat': Permission denied
du: cannot read directory '/boot/lost+found': Permission denied
du: cannot read directory '/boot/grub2': Permission denied
du: cannot read directory '/var/spool/mqueue': Permission denied
du: cannot read directory '/var/spool/squid': Permission denied
du: cannot read directory '/var/spool/clientmqueue': Permission denied
du: cannot read directory '/var/spool/postfix/deferred': Permission denied
du: cannot read directory '/var/spool/postfix/defer': Permission denied
du: cannot read directory '/var/spool/postfix/trace': Permission denied
du: cannot read directory '/var/spool/postfix/private': Permission denied
du: cannot read directory '/var/spool/postfix/flush': Permission denied
du: cannot read directory '/var/spool/postfix/saved': Permission denied
du: cannot read directory '/var/spool/postfix/hold': Permission denied
du: cannot read directory '/var/spool/postfix/maildrop': Permission denied
du: cannot read directory '/var/spool/postfix/incoming': Permission denied
du: cannot read directory '/var/spool/postfix/corrupt': Permission denied
du: cannot read directory '/var/spool/postfix/public': Permission denied
du: cannot read directory '/var/spool/postfix/active': Permission denied
du: cannot read directory '/var/spool/postfix/bounce': Permission denied
du: cannot read directory '/var/spool/cron': Permission denied
du: cannot read directory '/var/tmp/systemd-private-8ef7f42d90a5483e8b61014df4a3db07-ntpd.service-toLs8Z': Permission denied
du: cannot access '/var/log/audit/audit.log.3': Permission denied
du: cannot access '/var/log/audit/audit.log.1': Permission denied
du: cannot access '/var/log/audit/audit.log.4': Permission denied
du: cannot access '/var/log/audit/audit.log': Permission denied
du: cannot access '/var/log/audit/audit.log.2': Permission denied
du: cannot read directory '/var/lib/nfs/statd': Permission denied
du: cannot read directory '/var/lib/machines': Permission denied
du: cannot read directory '/var/lib/rsyslog': Permission denied
du: cannot read directory '/var/lib/gssproxy/rcache': Permission denied
du: cannot read directory '/var/lib/gssproxy/clients': Permission denied
du: cannot read directory '/var/lib/polkit-1': Permission denied
du: cannot read directory '/var/lib/tpm': Permission denied
du: cannot read directory '/var/lib/authconfig': Permission denied
du: cannot read directory '/var/lib/postfix': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/6': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/8': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/5': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/7': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/1': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/3': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/2': Permission denied
du: cannot read directory '/var/lib/yum/history/2019-05-28/4': Permission denied
du: cannot read directory '/var/lib/rpcbind': Permission denied
du: cannot read directory '/var/empty/sshd': Permission denied
du: cannot read directory '/var/cache/ldconfig': Permission denied
du: cannot read directory '/var/lost+found': Permission denied
du: cannot read directory '/var/db/sudo': Permission denied
du: cannot read directory '/storeddata/lost+found': Permission denied
du: cannot read directory '/run/sudo': Permission denied
du: cannot read directory '/run/rpcbind': Permission denied
du: cannot read directory '/run/cryptsetup': Permission denied
du: cannot read directory '/run/lvm': Permission denied
du: cannot read directory '/run/log/journal/64777be938ee4ed8a68d5284c4d9021c': Permission denied
du: cannot read directory '/run/lock/lvm': Permission denied
du: cannot read directory '/run/systemd/inaccessible': Permission denied
du: cannot read directory '/etc/grub.d': Permission denied
du: cannot read directory '/etc/vmware-tools/GuestProxyData/trusted': Permission denied
du: cannot read directory '/etc/pki/rsyslog': Permission denied
du: cannot read directory '/etc/pki/CA/private': Permission denied
du: cannot read directory '/etc/dhcp': Permission denied
du: cannot read directory '/etc/ntp/crypto': Permission denied
du: cannot read directory '/etc/selinux/final': Permission denied
du: cannot read directory '/etc/selinux/targeted/active': Permission denied
du: cannot read directory '/etc/sudoers.d': Permission denied
du: cannot read directory '/etc/polkit-1/localauthority': Permission denied
du: cannot read directory '/etc/polkit-1/rules.d': Permission denied
du: cannot read directory '/etc/firewalld': Permission denied
du: cannot read directory '/etc/audisp': Permission denied
du: cannot read directory '/etc/audit': Permission denied
du: cannot read directory '/etc/lvm/archive': Permission denied
du: cannot read directory '/etc/lvm/backup': Permission denied
du: cannot read directory '/etc/lvm/cache': Permission denied
du: cannot read directory '/altroot/lost+found': Permission denied
du: cannot read directory '/lost+found': Permission denied
du: cannot read directory '/recovery/lost+found': Permission denied
du: cannot read directory '/root': Permission denied
du: cannot read directory '/sys/kernel/debug': Permission denied
du: cannot access 'var': Permission denied
332G /
325G /opt
15G /opt/CSCOlumos
2.1G /opt/CSCOlumos/decap
2.0G /opt/CSCOlumos/decap/data
3.4G /opt/CSCOlumos/logs
3.3G /opt/CSCOlumos/staging
1.9G /opt/CSCOlumos/staging/app
311G /opt/oracle
309G /opt/oracle/base
8.6G /opt/oracle/base/fast_recovery_area
8.4G /opt/oracle/base/fast_recovery_area/WCS
5.4G /opt/oracle/base/fast_recovery_area/WCS/archivelog
3.1G /opt/oracle/base/fast_recovery_area/WCS/onlinelog
295G /opt/oracle/base/oradata
1.4G /opt/oracle/base/oradata/STBYWCS
1.2G /opt/oracle/base/oradata/STBYWCS/datafile
294G /opt/oracle/base/oradata/WCS
293G /opt/oracle/base/oradata/WCS/datafile
4.8G /opt/oracle/base/product
4.8G /opt/oracle/base/product/12.1.0
4.8G /opt/oracle/base/product/12.1.0/dbhome_1
1.9G /opt/oracle/patches
1.6G /opt/oracle/patches/28729169
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47G4y0S8pAFnz2clPou2oASUxjCVfCbBld8
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GJTs7Nk2SEqE3YnPtm5KYlEpd5PWTermX
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GNROWp3Jpv2s5eUiIfBZ02wyfcVcZZTBK
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GarsnGss2Qt14Kj8wNjzkTbyErwVFiGd2
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GcMYMjHJm1bUkBXmp5FMNLE4I3QHGzVx0
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GeXUy0igCb1aqjf5ZKA6Dujh732WkezeJ
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GmG7QY3dsXsh4WVCATMy56DzCn5V8jttZ
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GrSRrQCWbh9xknPOu6y4fMEOBcQilg19N
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GvWxI6iBiRYL5i8daOmCID7NLjPYPfTVx
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47Gx9nUjIBPfi3CcvwaR6aTvzdEb5KV7XAi
0 /run/udev/links/\x2fdisk\x2fby-id\x2fdm-uuid-LVM-pxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GzZhEyEzwJvpjTpIocUUE2W6P8KA0dytN
1.9G /storeddata
1.9G /storeddata/Installed
1.9G /storeddata/Installed/NCS.old
0 /sys/bus/mdio_bus/drivers/Generic 10G PHY
0 /sys/fs/cgroup/devices/system.slice/dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dpxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GarsnGss2Qt14Kj8wNjzkTbyErwVFiGd2.swap
0 /sys/fs/cgroup/systemd/system.slice/dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dpxb8jdGmJzoOc9tMCxlOIdAeZqhLl47GarsnGss2Qt14Kj8wNjzkTbyErwVFiGd2.swap
1.4G /usr
3.8G /var
3.6G /var/log
                               - du -h --max-depth=6 / var | grep [0-9]G | sort -k2
du: cannot read directory '/usr/libexec/initscripts/legacy-actions/auditd': Permission denied
  As far you should ever need these command(s)  again in the future , in step 3) of the initial post issue sudo -s to have a permanent root-shell. I think this problem should disappear then.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
M
Found the problem was the wtmp folder in /var/wtmp/  I manually cleared it by following these directions:
#enter shell:
shell
#get root
sudo su -
#write an empty new wtmp file (this can take a minute)
cat /dev/null > /var/log/wtmp
 from this link:  https://community.cisco.com/t5/network-management/prime-3-5-logrotate-not-working/td-p/3911313
Reloaded and it is now working without an issue.  Thanks
sudo su -   switch to root shell.
Enable log rotation as i explained since otherwise issue reappear.
Add entry /etc/logrotate.conf:
add >  su prime gadmin under weekly word
add> su root guser under both /wtmp and /btmp sections
            var/log/wtmp
              weekly
              su root guser
              compress
              size 1M
              rotate 4
                         var/log/secure
              weekly
              su root guser
              size 1M
              rotate 4
