01-05-2018 07:30 AM - edited 03-01-2019 06:20 PM
I am trying to get CPI version 3.1 working with RADIUS with RSA SecurID tokens and not having any luck with it. The problem that I am seeing is that CPI is sending two Access-Request messages for each authentication attempt from the login page of the WebGUI.
While two Access-Requests are fine for "local" users, it simply does not work with one-time passwords. Has anybody else ran into this and is there a fix for this behavior?
Thanks in advance!
Solved! Go to Solution.
01-15-2018 10:10 AM
I'll answer my own question here so hopefully others see it. There are three bug reports that I found on this, CSCul24955, CSCub28748, and CSCts86208.
It doesn't look like this issue will be fixed anytime soon.
01-15-2018 10:10 AM
