848
Beginner
Cisco Prime Infrastructure and RADIUS auth with RSA SecurID
I am trying to get CPI version 3.1 working with RADIUS with RSA SecurID tokens and not having any luck with it. The problem that I am seeing is that CPI is sending two Access-Request messages for each authentication attempt from the login page of the WebGUI.
While two Access-Requests are fine for "local" users, it simply does not work with one-time passwords. Has anybody else ran into this and is there a fix for this behavior?
Thanks in advance!
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: Cisco Prime Infrastructure and RADIUS auth with RSA SecurID
I'll answer my own question here so hopefully others see it. There are three bug reports that I found on this, CSCul24955, CSCub28748, and CSCts86208.
It doesn't look like this issue will be fixed anytime soon.
1 REPLY 1
Highlighted
Beginner
Content for Community-Ad
July's Community Spotlight Awards
