Cisco Prime Infrastructure disk IOPS issue
I know we should have migrated by now, but we still have 2 physical GEN 2 Prime appliances with Prime 3.10 (primary + secondary).
A couple of days ago the High Availability broke between the Primary and Failover appliances. After doing the Readiness Check for HA, it seems that I’m unable to re-establish the HA connection because the disks IOPS is too low on the primary appliance.
Does anyone of you have some tips on how I could solve this issue?
Helen
Mark Elsen
   - @helencloostermans    You are probably at a dead end here ; perhaps you could reboot the primary appliance
                                          and try again. If that doesn't help and because of the GEN2's no longer supported ;
                                          I would advice to migrate the Prime installation to a VM (with or without HA)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
@Mark Elsen
Hi, I already tried an appliance and CIMC reboot, but unfortunately that didn't help. On the CIMC, all Storage tabs are green and seem ok, but disk IOPS is still too low.
I suppose I'll have to migrate to a VM...
Helen
  - @helencloostermans      Probably the best thing to do indeed. If the issue is related to fragmentation and or prolonged
                                          system usage then a complete re-install could possibly help. But because of  the Gen 2
        it's not worth the effort.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
