Cisco Prime Infrastructure from 2.1.1 to 2.2
tsangsl011
I am upgrading the Cisco Prime Infrastructure from 2.1.1 to 2.2 on PRIME-NCS-APL-K9.
After setting the ftp server, error msg was shown when i applied backup command as follows.
Do you have any solution for this case? Thanks Apart from FTP command backup, Can i backup data from the Prime Web Page?
#repository ftpserver
# url ftp://x.y.z.a
#user username password plain password
#exit
#backup PI-Backup repository ftpserver application NCS
# backup PI-Backup repository ftpserver application NCS
% Creating backup with timestamped filename: PI-Backup-151203-1315.tar.gpg
  Backup Started at : 12/03/15 13:15:58
  Error: There is a problem with operating Database. Please check oracle database documentation for more details.
% Internal error: couldn't create backup file
Patrick Tsang
0 Replies 0
