Highlighted
Beginner
Cisco Prime Infrastructure - Monitoring Firepower SNMPv3 - Alarms message Authentication failed for request from 'Unknown'
Hi all,
is anybody here who use or try Cisco Prime Infrastructure to Monitoring Firepowersystems?
I know Cisco Firepower ist not in supported Device List of PI, but Cisco provide for FXOS a MIB Package which files can upload to Prime and used to Custom Polling with monitoring Polices. With this collect data you can create Generic Dashlets.
But if Cisco Prime should receive SNMPv3 Traps there is probaly the problem that a Minor Alarm message with: Authentication failed for request from 'Unknown' show in Dashboard.
You can assume that the configuration for SNMPv3 in both direction is correct. One direction seems to work fine.
What can I do to find out the correct problem with PI?
I find a Bug for PI 3 which describe basically the same Problem but for other devices.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCuy00761
Thanks Thomas
0 REPLIES 0
Content for Community-Ad
